Question about HP Pavilion dv6000z Notebook
Hp dv6000 laptop screen has rainbow lines on it
Screen flickers at times. i have to manipulate a nd touch the screen to make it clear; can;t see the mouse at the bottom of the screen
  • signature319 Jan 20, 2009
    Well, I had an anger problem and tossed mined to the floor and found the rainbow on its next use. Yeah yeah, I know, "Im an @$*, but I have a portion of the left side clear. Could that be unpluged wires?
  • 51 Answers
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Sounds like there is a bad connection somewhere on your screen.
Is the computer new? If it is, send it back to where it came from for a repair.
If it is not new and it has passed its warranty, then you may have to take the Basel of the screen and see if there are any sockets that are not connected properly. The problem with doing this, with SOME laptops, you have to take off the main cover off the laptop before you can take the Basel off the screen.
If you do need to take it apart, please touch something like a metal plug sockets screw or a unpainted radiator pip before you do this to get rid of any static you gave on you otherwise the is a chance of permanently damaging you computer
the connections inside laptops are usually just thin wires that go into sockets and the clips that secure the cables lift up and the cable can just be pulled out or inserted with ease. If you can open your laptop and check the connections, just firmly push them all in to make sure they are all connected properly
Good Luck
Posted on Dec 27, 2008
Ok you problem is pretty basic but also complex on the same time (4 you). The problem is that one of the wires around the screen has been slightly unplugged. All you have to do is open up the casing around the screen and find the loose wire. Also note that if you LCD was the problem you would see a blank spots. Assuming you don't spots on the screen and only rainbow *colors*. If you're too scared to open it yourself just give to a technician would cost you only 50$-60$
Posted on Apr 25, 2010
I read that if you unpluge and remove the battery then hold down the power button for 30-60 seconds. then repluge the power cord in fire it up and put the batter back in and walla fix and go to go.
Posted on Nov 04, 2009
  • 3 Answers
You can sebd it back to dell and repair it.
Posted on Jan 04, 2009
Hp dv6000 laptop screen blurry
Hello Al,
I hate to inform you but the graphics chip in these laptops are known for doing this. HP is aware of that. Every time some one brings me a Hp Dv6000 laptop about 75% of the problem is the system board or overheating issues.
First try cleaning the laptop screen with laptop screen cleaner
Walmart LCD Display Screen Cleaner for TVs Computers and Cameras
if its still blurry connect a external monitor to your laptop to see if the display is blurry on the external monitor (to get to toggle the video from your laptop you will have to press the Fn key + F4)
If its still blurry then its the graphics card or chip needs to be replaced. They are all integrated with the system board / mother board.
If its clear and images are good then the laptop screen will need to be replaced. hope that helps.
Jan 21, 2014 | HP Pavilion dv6000z Notebook
Tip
How to Disassemble an HP Pavilion DV6000
The HP Pavilion DV6000 is one in a popular line of consumer-oriented laptops produced by HP. Relatively inexpensive, the Pavilion DV6000 is a good all-around value for most users. Taking apart an HP Pavilion DV6000 is not an easy chore and if you plan to use the laptop again, it is important you know what you are doing or you have a large appetite for risk. If the above doesn’t describe you, consider taking the HP in for professional repair or upgrade. Otherwise, follow the steps below to disassemble the HP Pavilion DV6000.
18385245_1.jpg?w=200 1、Prepare a clear workstation. Turn off the laptop and remove all power components including the cord and the battery. (Turn the laptop over and you will find the tab to push and pop out the dv6000 battery.) Also remove any peripheral attachments like card readers and USB devices.
90-04208-003_original-hp-pavilion-dv8000z.jpg?w=250 2、Turn the HP Pavilion dv6000 upside down and unscrew all the screws you find. Try to keep them separate by size so you can put them back in the same spot when and if you decide to reassemble the laptop.
3、Remove the hard drive and memory modules by pulling up on the rectangular compartments. The memory is located in the central compartment (remove by spreading latches and pulling up), and in most HP models the hard drive is located to one side.
4、Remove the optical CD/DVD drive by pulling on the drive face to the left and out of the laptop. Remove the WiFi card by disconnecting the gold connectors on the antenna and pulling the card from its slot.
5、Turn the hp dv6000 back over and remove the keyboard and power panel/media touch pad. Carefully pry the power panel up with a piece of hard plastic near the power button on the left side. Be careful when pulling not to yank the power connection as you might accidentally rip out a wire. Pull back the keyboard to reveal the connections. Disconnect the connections by carefully pulling on the tabs with your thumb and forefinger. If they are tight, wiggle them back and forth while pulling on them to loosen them.
6、Remove the screws that were underneath the power pack/media touch pad. Carefully pry up the top casing and set it aside.
7、Detach all visible connections to the motherboard by pulling gently on them, wiggling them if they are stuck. Gently pull up from the right side of the motherboard and remove. The HP laptop is now fully disassembled.
on Jan 21, 2010 | Computers & Internet
A thin horizontal black line has appeared just below the centre of the screen on my hp pavilion dv6000 (running vista), there is no change when i gently press the screen, so i think the problem isnt with...
As the symptom you indicated above it is the problem with your LCD Panel. It is to be replaced to sort out this issue. To check and confirm the functionality of your Laptop motherboard plz check the Laptop with external display.
Nov 25, 2010 | HP Pavilion dv6000 dv6100 dv6200 dv6300...
Touchsmart tx2z Screen Flickers and Freezes
it seems the touch part is off center because when i touch the screen it reacts one finger over
Jul 09, 2010 | HP TouchSmart tx2z
HP HDX 16 laptop
check in the bios
if it flickers on the bios then needs to send the laptop in for a repair....
if it does not flicker in the bios then needs to
1> update the display driver
2> perform a recovery
regards
DJ
Mar 16, 2010 | HP Pavilion zd8000 Notebook
HP Pavillion DV9500 laptop with rainbow of lines on screen
Yes There are several layers that can crack and you may not feel it on the surface
Apr 29, 2009 | HP Pavilion DV9500T Notebook
Plz help my laptop has no display dv6000
More info please. Does it show a boot screen first then go blank? Does it beep when you turn it on? Has your display flickered recently or have the colors shifted?
Jan 04, 2009 | Computers & Internet
Hp Laptop screen flicker
I am sure that the issue is related to the cable that connects to the LCD Display or the LCD Backlight.
There should be some connection shortage because of which the LCD flickers few times as stated by dan231.
I Recommend you to get the Notebook examined as soon as possible before something really goes wrong...
Dec 05, 2008 | HP Pavilion dv6000z Notebook
HP Pavilion dv6000z Notebook Logo
2,082 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
