Question about Kitchen Ranges
F10 /F30 error codes on 2006 Kenmore Elite Range model 790.4671
Toward the end of the cleaning cycle my range started beeping with the following error codes F10/F30/F10. I turned off the breaker, it will continue to flash error code F10 when turned back on. This is the 2nd time that this has happend. This happend the very first time I cleaned the range. It was still under warranty and was fixed by replacing the Contoller for a total of $244.33 (Part cost). How can I find out what the error codes mean and what might need to be replaced without a expensive repair bill? Thanks, T
  • Teresa Akers Dec 27, 2008
    Sorry, i forgot the model number. I don't have the complete model number, as I can not get into the oven. The model number on my user guide is 790.4671
    Thanks
  • Teresa Akers Dec 29, 2008
    Thank you so much, that fixed the problem.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Offhand on most Kenmore range models, the error codes would indicate that:
  • F10 - runaway temperature
  • F30 - open probe connection
What this tells us is that it is possible for the oven to heat up beyond normal settings/temperature. What this really means is that the control board has lost a sensor and can no longer monitor the temperature of the oven. This being the case and for safety reasons, the control board simply disabled the oven.
Unfortunately, the error code indicates a possible hardware fault, the good news is that it is user repairable and parts are readily available.
"The problem is a sensor switch which is accessible from the back after sheet metal cover is removed. Looking from the back it was located on the upper right with 2 wires connected to it and a red button in the center. Do all this with power breaker OFF! Push in the red button which resets switch and everything will work until you use the self clean again. Easy to replace switch and you can order new one here It cost $10.00 plus handling about $16.00."
Good luck and Thank you for using FixYa.
Posted on Dec 27, 2008
  • 15,935 Answers
Http://www.kenmore.com/shc/s/nb_10154_12604_NB_CustomerCare?adCell=AH
without a model # this is as far as I can help.
  • 3 more comments
  • blueextc3221
    blueextc3221 Dec 27, 2008
    http://www.managemyhome.com/mmh/products...
    enter your model # and you will get your manual
  • blueextc3221
    The problem is a sensor switch which is accessible from the back after sheet metal cover is removed. Looking from the back it was located on the upper right with 2 wires connected to it and a red button in the center. Do all this with power breaker OFF! Push in the red button which resets switch and everything will work until you use the self clean again. Easy to replace switch and you can order new one herehttp://www.appliancepartspros.com/part_d... It cost $10.00 plus handling about $16.00.
  • blueextc3221
    F10 - Runaway Temperature
    F11 - Shorted Keypad
    F12 - Bad Micro Identification
    F13 - Bad EEPROM Identification/Checksum error.
    F30 - Open probe conection
    F31 - Shorted Probe connection
    F40 - Cooktop Lockout error
    F90 - Maximum oven door unlock time exceeded
    F91 - Maximum oven door unlock attempts exceeded
    F92 - Maximum oven door open time exceeded
    F93 - Maximum oven door lock time exceeded
    F94 - Maximum oven door lock attempts exceeded.
    I hope that can help someone in the future.
    btw, our F30 error was caused b/c a wire in a quick-connect came loose. once we tightened it again, the oven worked fine.
  • blueextc3221
    2 bad you already rated my answer. See solution above.
  • blueextc3221
    would have been nice to get paid ;)
My Kenmore electric range model #970-6784 displayed an F10 error during the cleaning cycle and started beeping. I can't clear the error or stop the alarm from beeping. Any Suggestions?
that means the temperature was "run-away" or unable to be controlled safely. To reset, unplug the main power or turn off the main circuit breaker. I would test it again as you may need a repair person if the error happens again. It can relate to a bad temp sensor.
Jan 02, 2018 | Kenmore Kitchen Ranges
Code f10 and f29 came up while On self cleaning what does this mean ?
Washer Error Codes Below is a list of... - Elite Appliance ...
https://www.facebook.com/permalink.php?story_fbid...id...
Right now you will find error codes for Asko, Fisher & Paykel, Frigidaire, GE, Kenmore, LG, Maytag, Samsung, ... Check pump trap and clean. ... Musical series of beeps every 5 seconds and Wash cycle light flashing-Washer is overloaded. ... E47--Board thinks the door PTC circuit is open in spin .... F29--Door unlock error
Range Error Code F10: Troubleshooting Runaway Oven ...
? 2:20
https://www.youtube.com/watch?v=z6tcnpDKDns
Oct 1, 2015 - Uploaded by searspartsdirect
If you see F10 on your range, it means that your electroni. ... exceeds the temperature you set it at in either .
Nov 07, 2015 | Electrolux E30EW85EPS Electric Kitchen...
I continue to get code F11 on my Kenmore Elite Gas Range Oven and therefore, I am unable to unlock / open my oven door. I have pressed and held down the STOP button as well as the oven light button.
Your model number should be much longer than 790 30 Open drawers and doors to look for the whole model number around the frame.
With the whole model number you can get more information at Sears Parts Direct. There are parts diagrams and user manuals and you can order parts.
http://www.searspartsdirect.com/
This site gives instructions for repairing F11 and recommends checking the temperature probe and tells how to do it.
How to fix Frigidaire oven error code F10 F11 F30 F31 etc AskGene com
Sep 10, 2014 | Kenmore ELITE 790 30 FREESTANDING DUAL...
Why does my kenmore range beep and show an error code every time I open the oven door?
See if this helps...
http://link.brightcove.com/services/player/bcpid1910171499001?bckey=AQ~~,AAABAWGODxk~,hLHEX2tm6AFlgSDzRIBPGX7yjI__nHLT&bctid=1974107068001
Also
Sometimes shutting off the circuit breaker that the range or oven is connected to for 30 seconds will clear the fault, error or function code.
Also
F3 or F30 means that there may be a problem with the oven sensor.
Your oven sensor may need to be replaced.
Jul 08, 2014 | Kenmore Kitchen Ranges
Kenmore self cleaning electric range issue with F10 error during self cleaning mode
You most likely have a failed oven sensor or the control / clock has failed. Self clean mode lets the oven get extremely hot and sometimes causes electronics to fail.
Nov 18, 2017 | Kenmore 30" Slide-In Electric Range...
Have a Kenmore Electric Range Model- 790.4671. Ran the self cleaning program. Error occurred at the end of cycle. F10 and F30. Oven will not unlock. Show oven locked and a picture of a lock. Oven is...
Sorry to read about your problem
Your F10 code means Runaway Temperature and f30 means open probe connection. try this and see problem comes back.
1. Unplug the unit or turn the circuit breaker off for 60 seconds.
2. Now, restore the power to the appliance by plugging it back in or turning the circuit breaker back on.
3. Check to see if the error code is still displayed on the range.
Note: General information for resolution to this problem, is based on information provided in question. Contact certified technician if problem persist. Sears Repair 1-800-469-4663
I have tried to help you.Pleas help me by Vote/Rate my response. Thanks.
If you are in the Denver,Co area I can help you out.
Dec 20, 2010 | Kenmore 46713 Stainless Steel Electric...
Kenmore Elite Range/Oven problem.
My kenmore glass top stainless steel slide in range has an error message code F93. I was attempting to allow my range to self clean when this err message appeared. Now I can't get the door unlocked. Help?? We've had a lot of problems with this range. We've had the service tech come out probably 4-5 times for different things. I think I got a lemon. It just turn a year old-we extended the warranty . I've called to complain but I got no help. They said it had to be for the same problem each time. Even the tech said the oven was a lemon but he couldn't help us. Any suggestions?
Jan 29, 2008 | Kenmore 46123 Stainless Steel Electric...
Kenmore Elite slide in range F30 error
I had the same F30 error problem but fixed it. On my professional series Frigidaire, there are 2 resettable red button locations. I discovered that only one is in the rear of the oven. After going to the breaker box and shutting off the power, pull out the stove enough to work, unscrew the rear screws (I didn't unscrew all of them, just enough to work back there). The small red button is on a small black round piece with two purple wires feeding to it. That was not my problem. Mine was the other red button behind the control panel. Pull off all 4 knobs, unscrew by hand the large black rings that are underneath the knobs, pull out the whole panel. Look back and right (below where the right knobs were located) to find the 2nd red small button. Push to reset. Check this one first since it is easier to do.
Dec 27, 2007 | Ovens
Kitchen Ranges Logo
482 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
