Question about Mitsubishi WS-55807 TV
Child lock acciendly put on dont quiet know how margaret
  • 9 more comments
  • broncos05 Dec 27, 2008
    did not fix problem of chid lock mitsubish projection tv pt5051.unable to unlock child lock accidently put on .
    i have tried the qv & 9 buttons together did not work
    the tv switch off after a few minutes tried qv & 9 for the child lock
    tried 0001 did not work screens show child lock and then switches of after two mins
    all that comes up on the screen is child lock nothing else tried suggeston did not work
    the model is correct pt-5051 its on the back of tv
    qv n 9 do not work we do have orginal remote we turn tv on screen is blue n the words child lock comes up only nothing else tv switches of in about i minute or less.
    no did not work tv shows the words child lock .n it switches of after a few seconds it dosent even show to put pin in
  • broncos05 Dec 28, 2008
    no already tried that did do anything got me stumped
    light is on red standby n green when on but tv switches of
  • broncos05 Jan 05, 2009
    problem fixed
  • 837 Answers
You MUST have the original remote and do the following :
On the remote is a button called QV for quick veiw. Press that button at the same time with the 9 button. This will open the lock, But it will return when you turn off the set and turn back on again. If you want it to do a normal turn on , once you open the lock you must go into the menu and remove the lock from the set completely. You may be able to find a friend or a store that might let you borrow an original remote? Sorry to be the bearer of poor news my friend. Good Luck
Posted on Dec 27, 2008
  • 2 more comments
  • Jay Glendenning
    Jay Glendenning Dec 28, 2008
    Ok then unplug the unit from the wall and leave it unplugged for 15-20 minutes. Plug it back in and try to unlock it again .. Let US know
  • Jay Glendenning
    Has there been any change in you ability to get in and unlock the child lock after unplugging the tv?
  • Jay Glendenning
    So your unit doesn't stay on long enough for you to get into the setup/menu once you QV + 9?
  • Jay Glendenning
    Jay Glendenning Jan 06, 2009
    What did you do to fix the problem? The experts here @ FixYa are always interested in the fix coming from us or other sources.
    Genius:
  • 1,239 Answers
HI go to the lock option in the menu screen, either press 0 0 0 0 or 7 7 7 7 that should unlock on lg sets anyway
  • 2 more comments
  • ABHISHEK.C
    ABHISHEK.C Dec 27, 2008
    Additionally, procedures for removing the Child Lock, Panel Lock and TV Lock are in the users manual.
    In some models, for the V-Chip, the original code is 000000, if you want to clear the code, please press the keys VOL + and VOL - on the front panel at the same time.The password of the TV's V-Chip Set up or Movie V-Chip Set up may be changed at any time. Press UP or DOWN to input the password,then press to select OK or Cancel. Press menu to confirm your input.
    Hope this be of initial help/idea. Pls post back as to the exact model and version of your TV, how things turned up or should you need additional information.
    Good luck and kind regards.
    Thank you for using FixYa.
  • ABHISHEK.C
    ABHISHEK.C Dec 28, 2008
    tried HOLDing THE DISPLAY BUTTON FOR 4 SECONDS AND THERE IT IS.
  • ABHISHEK.C
    The factory default password is 1225. User guide
  • ABHISHEK.C
    On your television, it has an initialization code. To get to this menu,
    press menu 2470. The menu will say "Initialize." Highlight this and
    press Enter. This will reset the TV back to factory settings. WARNING:
    This will also delete any user settings, e.g. color, channel settings,
    input labels, or other. After you press "Initialize" the TV will shut
    off and restart automatically. You should be unlocked at this point.
    Hope this helped.
  • 10,594 Answers
0001 is master code to reset child lock in Mitsubishi TV. Try it.
  • 1 more comment
  • Shahid Electronics
    Shahid Electronics Dec 27, 2008
    Let me know exact model of TV as PT5051seems incorrect.
    Kindly intimate exact model number of Mitsubishi TV to look for solution as PT5051 seems incorrect model.
    Shahid Electronics Jan 05, 2009
    Thats great! have nice time.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, to unlock your set requires two steps:
  • 1st get past the lock screen;
  • press the QV(previous channel) and 9 buttons simultaneously;
  • find the menu that covers locking and unlocking;
  • QV/9 (previous channel/9) is a one-time bypass;
  • if you turn the set off, it'll be locked again when you turn it on;
  • first need to LOCK it again, with a pass code you can remember (try 1,1,1,1);
  • Once you lock it, you can exit from all the menus;
  • try to change inputs;
  • It'll ask for a pass code, which you now know!
Good luck and Thank you for using FixYa.
  • Louie  Role
    Louie Role Dec 27, 2008
    Hi again,
    when it ask for the code press on the remote the buttons 9 and QV at the same time, this will bypass the lock, then go to the menu and look for "locks" or "Parental setup" when you go into this it will ask for a code again - push the 9 & QV again. then you can either set a new code or just turn off this feature.
    Cheers.
  • 15,935 Answers
Entry to the V-CHIP LOCK
(Figures 2-3)
The first time you select V-CHIP LOCK
from the MAIN menu, or after you have
canceled your passcode you will see the
screen shown in figure 2. Use the number
buttons on the remote control to input a fourdigit
passcode, then press ENTER. You
can delete a character and move back one
space by pressing CANCEL. You can exit
without inputting a passcode by pressing
MENU or HOME.
  • 3 more comments
  • blueextc3221
    blueextc3221 Dec 27, 2008
    Bypassing the V-Chip Lock
    After you set the lock, you need your
    passcode to view a V-Chip locked program,
    view the locked TV, cancel the
    lock, or enter the V-Chip lock menus.
    If you forget your passcode, you can
    view the locked TV without entering your
    passcode. This is done by pressing the
    number 9 and QV buttons on the remote
    TV control at the same time, when your
    password is requested. This process
    temporarily unlocks the TV.
    When entering the V-Chip Lock menu,
    this process deletes your old passcode
    and prompts you to enter a new passcode.
  • blueextc3221
    When changing or deleting your passcode,
    you must use the remote control
    included with this TV. You cannot use
    a Mitsubishi remote control from another
    component or a “universal” remote.
  • blueextc3221
    blueextc3221 Dec 28, 2008
    Information
     Restoring the factory default settings
    Select “ALL RESET” under the SET UP menu. Note that this also restores other settings to the factory defaults.
  • blueextc3221
    Resetting to the default values
    Use these operations to restore all the settings (PICTURE,
    AUDIO, IMAGE ADJUST, SET UP, etc) to the factory
    default values.
    Refer to pages 15 & 16 for items to be reset.
    Press MENU/ENTER button to access the MAIN MENU.
    Use the  ▲ ▼ buttons to select the SET UP menu and
    then press the MENU/ENTER button.
    Use the ▲ ▼ buttons to select the ALL RESET setting.
    Use the  buttons to turn on or off the ALL RESET button.
    When the “SETTING NOW” screen disappears, then all the
    settings are restored to the default values.
  • blueextc3221
    are any lights on the front panel blinking green or red??
  • 365 Answers
Press down the key with the lock symbol for at least four seconds ,then you can see the option to lock ,unlock etc.try it.thank you
  • JITHIN ANTONY Dec 27, 2008
    can be solved very easily,if you have any doubt i am online you can add comments and i will respond quicker
Turn off child lock
Can you identify the model of the oven you need help with or anything like that? Not all child locks on ovens are configured to function or be utilized the same way.
Sep 22, 2013 | Ovens
I haven't the right remote but have a universal remote and the tv has a child lock i cant seem to erase
I dont know if you can erase the child lock but if your universal remote has a settings button you should be able to turn the child lock off through the setting menu
May 12, 2011 | Samsung Televison & Video
Child proof lock is on and dont know how to turn it off?
Child Lock is activated. Look for a picture of a small child's face on the Facial Panel (usually with picture of a lock) follow the arrows to 2 buttons, press and hold these buttons for 5 - 7 seconds. Child Lock will then deactivate.
Hope this helps
* If you found this solution helpful, please vote positively.
Feb 18, 2011 | KitchenAid Dishwashers
My child put the lock on and i dont know the password
To Unlock the Mobile from the Password or security Lock use the Master Reset Code,You can Check Master Reset Code here
http://www.mobileunlocksolutions.com/unlocking-services/rs1wp6/ for Your mobile and Unlock it.
Dec 17, 2010 | Cell Phones
How do i unlock my lg microwave i dont have an owners manual so i dont know how to unlock it
"Locked" meaning the buttons don't work/non-responsive (Child Safety Locked)? To Unlock/Disengage the Child Safety. Push and hold the "Clear/Off" button for 3 to 4 seconds. The Child Safety is disengaged - problem solved.
Nov 15, 2010 | LG LMVM2277ST Microwave Oven
Cant get child lock off
Hello,look for a button with possibly a lock emblem beside it ..usually has to be held down 3-5 sec to unlock.
Thanks
May 23, 2010 | Siemens WM14S794GB Front Load Washer
My aiko tv is stuck on child lock. I have no remote and dont know how to get the child lock off.
You can try turning it on and pressing all the buttons down at the same time, that sometimes will reset tv's to factory.
May 12, 2010 | Televison & Video
Philips freeview digi box dtr1500
thanks my daughter solved the problem to unlock parental lock or parental pin number she tried four zero digets 0000 no success then she put in four numbers one 1111 and it unlocked the parental lock .hope it can maybe help someone - margaret
Oct 01, 2009 | Philips Universal PH301S Remote Control
Child Lock Code
You will need to go into the parental control and put in 6688 code.This will unlock it.
Feb 06, 2008 | Apex Digital GT2015 20" TV
Mitsubishi WS-55807 TV Logo
47 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
