Sansa clip 2gb lockec
Locked up tight. Screen diplayes a song. Will not play. not recognized by PC connection. Cannot turn off Sansa. Basically can't do anything with it. Before this happened, songs would play exactly 3 min 4 sec and stop.
    President:
  • 948 Answers
First of all, may I ask if you have a mini disc player or a Sansa Clip? Because the Sansa Clip does not play discs of any kind.
If you do indeed have a Sansa Clip you will find the FAQ rather helpful here - http://www.sansa.com/support/sansa_clip/faqs
Question 9 there is regarding devices not recognized by the PC and the solutions are as follows:
The most common reason for this problem is not having the latest Windows Media Player installed, or having a Windows OS version that is not supported by the Sansa player.
The Sansa players support Windows XP SP2 and Windows Vista and above. If your operating system version is supported by the Sansa player:
SOLUTION 1 – Download and install the latest Windows Media Player
SOLUTION 2 – If that didn’t help, and you are running Windows Vista, apply the following hotfix - KB940199
SOLUTION 3 – If that didn’t help, download and Install the MTP Porting Kit (click here)
SOLUTION 4 – If that didn’t help, try connecting the device to the PC using MSC mode
Clip: Go to Settings > USB mode & choose MSC
If none of the solutions work for you, please post the results of your attempts and we can go from there.
Posted on Jan 10, 2009
My Sansa Clip won't work. When I turn it on it says: Not enough space for music DB Please free 30 MB. But when i connect it to my computer it doesn't register. PLEASE HELP ME
Because you drag 7 drop songs or files too much into the sansa clip in MSC mode, it causes like that.
Turn it on, it will show " Not enough.....free 30 MB", and then automatically turn off. Plug it into pc, open my computer, it will be under name "Sansa clip..." or "removable disk ". If your pc does not recognize it, unplug again and replug it.
Open Sansa Clip..., or removable disk, and delete some songs.
Good luck
Apr 30, 2010 | SanDisk Sansa Clip MP3 Player
Download from audible
hi,
Have you tried connecting to the net and then continue to subscribe??
Feb 09, 2008 | SanDisk Sansa Clip MP3 Player
My Sansa Clip screen is not showing up (it is
it is probably defective. take it back to the store and replace it
Mar 21, 2010 | SanDisk Sansa Clip MP3 Player
The screen of my Sansa Clip 2GB showed illegible signs two days ago when I last played it, but I could get songs playing. Through my computer I then cleared all playlists, deleted the songs etc. Then put...
Restoring your player can be done in 2 main steps:
>>1. For updating the firmware, the player should be switched to MSC mode.
This could be done through the menu. When not knowing what the display shows, use the forcing method in next link:
http://kb.sandisk.com/app/answers/detail/a_id/61/sno/0
See the Sansa Clip steps below:
1. Turn device OFF.
2. Slide the Hold switch down to Lock (orange color showing).
3. Press and hold the center button while connecting the device to the PC.
>> 2. Once connected in MSC mode you can use the firmware updater when having Windows operating system, see next page:
http://kb.sandisk.com/app/answers/detail/a_id/300/kw/firmware%20updater/r_id/101834
For others who have MAC or Linux operating system you can not use the firmware updater: firmware should be manually downloaded from Sansa Forums and installed afterwards:
http://forums.sandisk.com/sansa/
If this was helpful I'd appreciate your answer.
When needing more help, just add a comment in this thread.
Mar 03, 2010 | SanDisk Sansa Clip MP3 Player
The screen is dim it is on the last song played it won't do anything won't turn off but won't play either, It worked fine this morning help please It is a sansa clip 2gb I've had it since Sept. 09
Sansa Clip won't turn off right? push up power button and hold it for 10 to 20 second, your device will turn off now.
After that, you should update your new firmware from sandisk forum, you should check Sansa Clip or Sansa Clip+ from the following web,
Good luck
Jan 25, 2010 | SanDisk Sansa Clip MP3 Player
Sansa Clip 2gb not showing songs
Go to this guys tip it is a good tip on your problem, Fixya will not let me copy and paste, it so here is the link. Solve your MP3 Player Connection Problem.
SanDisk Sansa Clip 4GB MP3 Player
go to control panel and click on portable media devices note:will not work on windows xp even if you downgrade to classic using a disk
Feb 07, 2009 | SanDisk Sansa Clip MP3 Player
Sansa Clip 2gb only plays parts of songs
The songs you have loaded have a restrictive license on them that only allows full playback on a computer, not on an mp3 player. If you only download songs in mp3 format, you will never have this problem.
Jan 01, 2009 | SanDisk Sansa Clip MP3 Player
Computer wont recognize sansa clip mp3 player
Reformat clip with disk utility after looking at it like an external disk. Do this by turning it off. Puting it in lock mode. Hold down middle button as you plug it in.
I am mad at my Clip as it did the same thing.
Screen shot here:
Sansa clip not recognized.
Dec 26, 2008 | SanDisk Sansa Clip MP3 Player
Sansa e250 using micro sd card
Go to the knowledge base on the Sansa site and find this (chances are you have an SDHC card in an incompatible unit):
Sansa e200
 - verify the version of the player.  To check, go to SETTINGS > INFO
For 01.xx.xx firmware (e200 version 1) - up to 2GB microSD cards
For 03.xx.xx firmware (e200 version 2) - up to 16GB microSDHC cards
NOTE: Firmware is not interchangeable.
Sansa e200R - up to 2GB microSD cards
Sansa e100 - supports SD cards up to 2GB
Nov 12, 2007 | SanDisk Sansa e250 MP3 Player
140 people viewed this question
 Grubhead
Grubhead
