Question about Refrigerators
GE Side BY Side keeps Running
I have a 2yr old GE Adora DSS25MSSESS that keeps running now for 2 days straight. The digital readout reads 37 for the fridge and 7-10 degrees for the freezer. All items are cold in both sections. The freezer before always read 0 degrees. I hear a whinning but when you open the door it stops. I have tried to reset the freezer to 0 but it keeps going back to 7-10 degrees. I called ge and they suggested to unplug it and wait a min cause it might have static electric in the line. That didnt work. Will it hurt it running all the time till I fix it?
  • 405 Answers
Two reasons I can think of, fan motor because of the whining description you descibed, and possible freon leak. I think the first is the problem!
Posted on Dec 27, 2008
  • David Johnson
    David Johnson Dec 27, 2008
    oh also make sure your condensor is free of dust and lint. This can also cause you this
Refrigerator no cold
Sounds as if it lost its gas in the move. Check for broken pipework or capillary. It might be repairable.
May 16, 2012 | GE Adora (DSF25KGTBG) Side by Side...
Got a decimal point in the minutes and is not starting and is counting in sec not mins front loading washer ge adora 4-5 yrs old
What is the model number that is posted on the machine? On the model number that is posted above I do not see in the database that it has a LED display readout.
Feb 08, 2011 | GE WSXH208A Front Load Washer
I have a GE Adora M# DSF25KGTABG. Set temps on the freezer door to 0 and 37. runs great for a few days then drops down to -9. I have replaced all thermistors and the mother board. What would be the next...
I have the GE Adora DSS25KSTB ss and the temps will not hold to cool temp.
We set it at 0-25 and the refg to 35 and sometimes it will cool to that temp and then sometimes it is a lot warmer.
Dec 29, 2010 | GE Adora DSS25KSTSS Stainless Steel Side...
My G.E Adora refrigerator freezer is not cold enough. Ice cream is melting and refrigerator is at too cold and is freezing food, It is only 5 years old. It is a side by side. Help!
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 18, 2010 | GE Adora (DSF25KGTBG) Side by Side...
I have ge side by side model PSS26SGPASS it just thawed out everything in freezer, reading tc in fridge side now, freezer 37 degrees fridge was up to 50 company coming purchased 6 yrs ago help!
I have the exact problem. My unit is 6 years old too - purchased in 2004. I have located, after cleaning the coil under the unit, this is not the source of the real problem. I took the upper cover off which houses the main logic board to find if I flicked the comp relay "compressor" the compressor then turned on. I took amp readings before and after they were .2 without the compressor running and 1.3 with the compressor on. The main board will need to be replaced. Personally I will try to locate the actual relay and replace it on the board if possible.
Sep 17, 2010 | GE Profile PSS29NGS Side by Side...
The freezer shelves in my ge Dss25KGRC side-by-side refrigerator/freezer keep falling down. It seems as though the shelves shrunk and no longer fit. Could it be that the freezer walls have gotten farther...
I had the same problem with my 3 year old GE Adora side by side. Call GE at 1800-386-1215. They were very helpful! They sent me all new shelves and drawers that were obviously wider because they fit perfect(only took a couple days)! Included in the shipment were spacers that I could of put on the ends just in case I needed more width. GE knows about the issue and is dealing with it on a case by case basis.
May 21, 2010 | Refrigerators
I have a GSS25WST side by side refrigerator/freezer. I have the freezer temp set to 0 and the refrigerator temp set to 37 but according to the "current temperature" reading on the front panel it says the...
The door light switch controls the evaporator fan which circulates the air through out the unit properly. Replace the bad switch and things should go back to normal. WR23x10161 at about 10.00. Good luck. Rick
Mar 10, 2010 | GE GSS25WSTSS 25.4 Cu. Ft. Side-by-Side...
My freezer defrosts too often
replace defrost timer
Oct 12, 2009 | Refrigerators
Refrigerators Logo
200 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
