Question about KitchenAid KHTU165RSS Stainless Steel Kitchen Hood
Vent Hood Problem with hood light module constantly failing. Replaced one over the last year at a cost of 300.00. Please help as we are closely reaching the point of spending more than the hood is worth.
  • Margo Kohl Apr 20, 2007
    Also, I forgot to mention that when the hood was installed it was not installed on a seperate circuit\breaker. And, I'm wondering if that miight me why we are losing so many light modules on our hood.
    President:
  • 1,462 Answers
When a bulb blows, it takes excess current. if breaker is not sized to a hood, then damage to module can occur at time bulb goes
Posted on Apr 20, 2007
I have constant steam coming from the inside of my am1300 dishwasher... not sure why as it doesn't normally especially with the hood up... is there a reset I can try... or any help assist please?
It sounds like the water inlet valve is partially opened. That can happen from sand, dirt, or minerals entering from the house water supply. If it fails to close, the valve needs to be replaced.
Feb 27, 2014 | Dishwashers
EFC90950x lights are not working. Fans are ok. Bulbs changed but lights still not working. Is there a hidden fuse that needs changing?
I have repaired a similar vent hood with this problem. If you have two lamps that are 35 Watts each, order from ebay or Amazon one of the HATCH LIGHTING 80WATT Electronic Transformers. CAT # RS12-80M, 120 Volt. It will cost you about $22 and you use some wire nuts and wire cutters to install it. Please turn off power to the vent hood first!
Nov 02, 2013 | Electrolux Kitchen Ranges
2007 gmc yukon has security light blinking and hood open warning indicator light on but hood is closed. have reset battery and security system will not shut off
The security light is a visual indication that something in the car's antitheft system is failing. In most GM cars and trucks there is a hidden system that most people are unaware even exists. From the moment you put your key in the ignition, there begins a constant line of communication between your key's security chip or transponder, to the ignition's lock cylinder, and then to the car's TDM. (Theft Deterrent Module) The TDM is what tells your computer that the correct key is being used and that it is "OK" to allow the vehicle to start and run. These 3 parts must be in CONSTANT communication. If the key is in the ignition, then these parts are sending important signals to each other. The security light illuminates when that signal gets broken, even just for a second. When the signal breaks, (normally due to a failing/broken part) the car goes into antitheft mode. The car misinterperates this and thinks its being stolen or hotwired because it is NOT getting that signal from YOUR specific key. There is where the security light turns on and shuts down your vehicle. So basically, if that light is on, your system has some sort of failing part. This can start as an intermittent "no start", to your vehicle not running for days at a time, to the vehicle NEVER starting again. The problem is electrical and computer based, so don't count on an easy reset button, or the problem fixing itself. The hard part is isolating which part is the problem. You can spend a thousand dollars through a mechanic very easily. I have had great luck with bypassing the entire system. This way the problem will never return. It actually CAN'T ever return because it is eliminated. This can also be done yourself at a much cheaper cost. Read through this link very carefully. You'll find alot of information and pictures, along with ways to help you fix this.
http://vatspasslockpasskeysecurityhelp.yolasite.com/
May 31, 2012 | 2007 GMC Yukon
Fl3 code. heater working fine when i closed last year. will not start this year. showing fl 3- does not ignite , does not do anything ..help please
3.
Spillage at A.Cold chimney A.Allow heater to operate 5 minutes to create draft action.
draft hood B. Vent pipe pitches down to chimney B. Reinstall vent pipe to pitch up from heater to chimney.
C. Blocked chimney C. Remove blockage.
D. Draft hood altered D. Install factory-provided draft hood.
E. Prefabricated chimney with incorrect cap E. Install a Nationally Recognized Testing Lab (NRTL) listed vent
http://www.jandy-downloads.com/pdfs/Lite2_LJ_IO_H0248900F.pdf
I tried to copy the FL3 write up from the chart but it screwed it up a little. Look at Page 35 of the manual for a clear copy
Jun 10, 2011 | Jandy Lite 2 Natural Gas Pilot Light...
No heat
If electric then the thermostat or the heating element has failed.
If gas: First thing to check is the ignitor underneath the drum. (You have to open the panel to see it) It should glow shortly after the dryer starts, then the flame starts and the ignitor shuts off. If the ignitor does not glow then it or the thermostat is bad. If the ignitor is glowing but the gas does not light then the flame sensor may have to be replaced. If the gas ignites but does not stay on either the flame sensor or the coils are at fault.
See also: http://home.howstuffworks.com/how-to-repair-a-dryer.htm
Dec 02, 2009 | Kenmore Dryers
Battery keeps draining while car sits. Constantly having to recharge. Replaced battery twice in last year. NEED HELP !
Check to see if it's the light under the hood that stay's on when you close the hood. remove the light bulb and see if it still drains. The other places would be the light over the visor and light in the glove box. Other things would be a bad relay like the A/C relay to the compressor being stuck in the on position and A/C clutch engaged all the time. Start with the light's it may take a few days but better then going to the dealer and paying them to do the same thing for a few days and charging you for the service. Keep me posted, be glad to help out.
Jun 04, 2009 | 1996 Chevrolet Corvette
Ge monogram hood has power but not working
I have the same problem, only worse. The fuse is in the stack above the motor. You have to remove the vent decorative cover (that stainless tube that goes to the ceiling) and the fuse is in the low voltage circuit close to or inside the gray box that looks like a transformer (on the left). Mine blew out and I replaced the fuse, which lasted for about two months. I replaced it again and it lasted two days. Then, I replaced the triac with an NTE5679 (over on the right) (replaces ECG5679) about two years ago, and the fuse lasted until today. I do not know what to do now. We did not touch a switch just before the fuse blew. The fan was not running, but the lights were on. I think I will try a slightly larger fuse, but first I may look at replacing the fuse with a breaker that I can install behind the filters, instead of removing the stack cover every time the circuit goes out. Good Luck to you.
Ravenhaven
Apr 12, 2009 | GE ZV750SY Kitchen Hood
Broan Allure QS2 Range Hood
Had same problem & fuse fixed it.
Before buying a new control board (approx $160), check the 3 amp fuse located on the inside of the vent on the control board. You have to take the light/bottom housing & black plastic air chute off to see control board/fuse.
Feb 21, 2008 | Broan-NuTone Allure II QS230SS Kitchen...
Dacor IVS1 Vent Hood - How to change a light bulb?
Buylighting.com, JDR120V-75W-E27CG...also comes in 50 watt. They aren't inexpensive, but if installed properly, will last a while. We have a little suction cup to take them out and put them in. It came with the range hood. If you get fingerprints on a halogen bulb, it can blow out quicker.
Dec 30, 2007 | Kitchen Ranges
Halogen Lights Failing
I had the same experiences with my lights. I placed a 50v bulb and it blew the fuses. The fusees located on the right side of the bottom duct cover. use 5a 125 v fuse GE part # wb27x10542 but you can find a cheaper fuse at Radio Shack. Good luck
Mar 28, 2007 | GE Monogram ZV1050SFSS 42" Island Chimney...
Kitchen Ranges Logo
209 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Carmen Mikulic
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
