Question about Envision H190L Monitor
Resolution to big
I cant get monitor to go to a higher resolution in windows vista stuck at 1024-764
    President:
  • 1,179 Answers
Check your grahics card to make sure it supports higher resolutions. It may be that you have it already set to highest supported by your video card. Hope this helps.
Posted on Dec 27, 2008
Why dark manor game didnot support my monitor risolution
Windows XP
  1. From your desktop, right-click and select Properties.
  2. Click the Settings tab.
  3. Adjust your screen resolution to 1024 x 768 (or higher) and select OK.
  4. Try playing your game again.
Windows Vista
  1. From your desktop, right-click and select Personalize.
  2. Select Display Settings.
  3. Adjust your screen resolution to 1024 x 768 (or higher) and click Apply > OK.
Windows 7 and Windows 8
  1. From your desktop, right-click and select Screen resolution.
  2. Adjust your screen resolution to 1024 x 768 (or higher) and click OK.
  3. Try playing your game again.
Mac
  1. Open up the Apple menu.
  2. Select System Preferences.
  3. Click on the Displays icon.
  4. Select the Display tab to adjust your resolution to 1024 x 768 (or higher).
  5. Reopen your game.
    _
    Try this out it seems to work for some people, if that does not work try this out:
    Switch to Windowed Mode
    If you continue to have trouble playing your game in full screen mode, switch to windowed mode. Under the main menu of the game, select Options, and un-check Full Screen mode (or vica verse if you already have windowed mode on, switch to fullscreen)
    Thanks and I would appreciate a reply if that got fixed or not.
    Good Luck!
Apr 27, 2014 | bigfishgames.com
I cant get correct resolution with windows 7 no apparent drivers of FP 222w under windows 7 (22 inch monitor)
You normally don't need any drivers for LCD monitors. The resolution should be 1440><900 or higher.
Samir
Feb 28, 2011 | BenQ FP222W LCD Monitor
Low resolution of monitor
Right click on your desktop and select Properties (win XP or older), or Personalize (vista and windows 7), and select a higher screen resolution on the settings tab (XP), or by clicking "display settings" (windows vista or 7). If your slider is all the way to the right, make sure you have the latest drivers for your video card, or if the PC is older, you may need a new one that supports the resolution of the monitor.
Feb 06, 2010 | Acer AL1916W 19" LCD Monitor
How to change screen resolution of t43 if it is
That 1024-by-768 value is the MAXIMUM supported by the computer.
The only way to go to a "higher" value is to buy a newer computer.
Nov 18, 2009 | IBM ThinkPad T43 Notebook
My monitor is showing things way to big to fit on the screen How do I fix this ? just rebooted today
right click anywhere on your screen/properties/display for vista and settings for xp. then increase your resolution from whatever it is right now, i.e. 680 by 840 to any thing higher. that will do it.
Sep 17, 2009 | Dell Dimension 2400 PC Desktop
Screen resolution
You will need to load the Video card driver for Vista for the model card you have in the system. Once this is done, you will be able to adjust the resolution.
If you need assistance in finding the video driver, post the details of the make and model video card in the system.
Mar 01, 2009 | 3M Vikuiti eXtended Resolution Video...
Screen size
Most Likely: Your screen resolution needs to be 1024x768.
Less Likely: You have an Appearance scheme such as Large Contrast.
Solution: Access Control Panel, select Display, then Settings tab and then move the slider to the above or higher resolution.
In the Theme or Appearance tab (depending on OS) choose a generic Theme or Color Scheme.
Regards,
Worldvet
May 21, 2008 | Computers & Internet
Anyone know a way to increase the resolution past 1024 x 768?
First, you might want to check what the maximum supported resolution of your monitor is. You can do this by looking it up on the internet or referring to the owners manual. If you cant find that information, in your graphics properties in Windows XP, click the advanced button beneath the color settings and click the monitor tab. Make sure the model listed under 'Monitor Type' matches the monitor you have. If it does, see if the 'Hide modes that this monitor cant display' box is checked. If so, the maximum resolution is limited by your monitor and you may have to upgrade the monitor to go any higher. If the model does not match, you can try the following: click Properties->Driver Tab-> Update Driver and either load the correct ones from the manufacturers web site or use one of the Standard Monitor types provided by the windows Driver library. Be warned though: If you select a standard type with resolution higher than your monitor supports, it will not display correctly at settings higher than 1024x768, and you may have to wait for windows to change the resolution back. Another thing you can try is unchecking the 'Hide modes that this monitor cant display' box, clicking ok, and setting the resolution to something higher than 1024x768, but the same warning applies! If it does not display correctly than you know for sure that the monitor is the limiting factor.
Nov 09, 2007 | Sharp LC 28HM2 28 in. Flat Panel LCD...
Envision H190L Monitor Logo
71 people viewed this question
Top Envision Computers & Internet Experts
Steve
Dimitar Todorov
Paul Bade
Are you an Envision Computer and Internet Expert? Answer questions, earn points and help others
