Question about Kenmore Oasis HE 27082 Top Load Washer
Code errors fixed
Thank you catriver for your help! The hose was pinched a little. It's all fixed now. thanks again!
    President:
  • 1,294 Answers
Off the unsolved list!!
Posted on Apr 20, 2007
I have a Kenmore Elite Oasis HE (Model# 110.27086603). I receive an F1 error code after starting the machine. It takes 2 stop & starts to reset. I then receive the F1 error code again at the rinse...
F1 Error Code
There are four areas of concern that can cause the F1 Error Code. Each area must be sequentially addressed to ensure that the diagnosis is correct and the proper repair is completed.
A) Air leaks in the air pressure switch/sensor hose.
a. Inspect the hose for cracks, pin-holes or loose connection.
b. Replace the hose and harness assembly (W10058730) if it is damaged.
B) Moisture in the air pressure switch/sensor hose.
a. Inspect the hose for evidence of water.
b. Replace the hose and harness assembly (W10058730) if water is detected.
C) Lint or flashing in the air dome hose connection port.
a. Inspect the air dome hose connection port for lint or flashing. Blow through the hose to clear any lint that may be trapped in the hose.
b. Use a small round device (small screwdriver) to ensure that there is nothing blocking the air dome outlet on the tub.
D) The control board needs to be replaced.
a. Replace the control board only after the prior steps have been performed, and not fixed the problem.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Feb 27, 2011 | Washing Machines
I am getting an error code F1 does anyone know what that is. The manual states to call for service? i am trying to avoid that as i have already had this machine repaired 3 times and am very dissappointed...
The F1 error code on this washer indicates a Primary Control Board failure.
It is likely that the machine control board will need to be replaced to correct this problem.
The part number for the machine control board is undetermineable because you have not provided me with the exact model # of your washer.
The procedure for replacing the machine control board is provided HERE
LINK: http://media.fotki.com/1_p,wfgstgtftbtkrrdxgtqsskgwtqkq,vi/gfsfgfsgqxgfqtqtgwf/1/1303472/5961857/image55806img-or.gif
NOTE: Be sure to unplug the washer to disconnect electrical power before accessing internal components.
There is a slight possibility that a problem with the pressure switch hose could be causing this problem.
A pinched or twisted air hose can cause this fault code.
When you open the console, check the air hose connected to the pressure switch on the machine control board.
If it is pinched or crimped, I recommend rerouting the hose to resolve this problem.
This may fix your problem without replacing the control board.
NOTE: You may want to check for this condition before ordering the control board. Most electronic control boards cannot be returned for a refund or credit.
If you find no apparent problems with the air hose on the pressure switch, then replacing the machine control board on this washer should correct your problem. There is a risk involved in replacing this part yourself.
As noted above, you could have a problem with the air pressure hose that is not apparent upon your initial inspection. A service technician would normally need to properly and thoroughly diagnose this problem before replacing the control board.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Sep 12, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
F1 code on Kenmore Elite Oasis. Is there a recall?
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question!!!!!
Nov 08, 2009 | Kenmore 24032\24036 Top Load Washer
F1 error code on Kenmore Oasis He
Apr 25, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
F2 error code on my Kenmore Elite HE3 washer
Based upon your description, the drain pump has either failed or the pump filter has become clogged.
To check the pump, remove the bottom access panel. There you will find access to the pump clean-out.(Large,white screw cap) BE READY TO CATCH LOTS OF WATER. CAREFULLY AND S_L_O_W_L_Y unscrew the pump clean-out, catching and discarding the water. When the water flow finally stops, completely remove the clean-out filter. Inspect the clean-out filter, the drain hose from the tub as well as inside the pump impeller for any additional debris.
If you need further assistance, let me know
Regards,
reg501
Jul 04, 2008 | Kenmore Elite 45986 Front Load Washer
What was part number
May 12, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Frigidaire front load washer (LTF600ES1) Error E20
holla, Im not showing a E20 code on the tech sheet. There is a E21. Water not draining fast enough. Try holding the start/pause and cancel key together for 3 seconds. The door lock, wash, rinse and final spin leds should light. Any error codes should be displayed when holding those keys. If you see a different error code, post it. If not, I would suspect a clogged pump...Catriver.
Aug 04, 2007 | Frigidaire ATF6000ES Front Load Washer
Kenmore Elite Frontload washer
Dea, F02 is the code for long drain. Your filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 screws. The panel will drop and come off. The filter cover is right in front. Get yourself a bunch of towels and unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in. See if the washer comes back to life...Catriver..post back
Apr 28, 2007 | Kenmore Elite 45986 Front Load Washer
F1 and F83 codes
Marsha, F1 is the code for a primary control failure. Since you just replaced main board check to see that all the harnesses are seated correctly. On this model I've found that if you have a pinched or blocked pressure tube,(hose going to the control board) it will give the same error code as a failed control board. Make sure it's not being pinched when replacing the consol. The F83 is the code for door unlock failure. You need to get past the main control board failure first...Catriver..post back.
Apr 20, 2007 | Kenmore Oasis HE 27082 Top Load Washer
E1 and F1 flash, with beeps at 15 sec. intervals, & oven not working
crys, the tech sheet for your model states that you need to replace the electronic control (clock) when this error is flashing. Catriver..post back.
Oct 12, 2006 | Roper FGP300 Gas Kitchen Range
Kenmore Oasis HE 27082 Top Load Washer Logo
Sal De
fordexpert
Whirlpool
Whirlpool
