Back to:
Tags:
Mitsuba DV5 Digital Camera
4.1 camera
posted by willie1 on Apr 20, 2007
i need to know how to hook up the camera to the tv
Comment by willie1, posted on Apr 26, 2007
they was very helpful.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Apr 20, 2007
Helpful (85)
Noggin
Rank:Guru Guru
Rating: 88%, 1586 votes
The camera details are not available online as it is a discounted product, however it is supposed to have a standard RCA video out connection (probably with a yellow insulator).
To connect this to a tv you will need a standard RCA cable - you can get them as a combined 3 part cable with a red and a white one to connect the audio also if the camera has this output - maybe it uses a stereo 2.5mm jack plug on the camera end for which you can get a cable or an adaptor.
At the Tv end, the connection depends on what the tv has available - many have direct RCA input connections, if not and it only has a scart input (large rectangular plug with lots of pins) you can get an adaptor for RCA to scart in any electronics store.
After that you just need to establish how to change the source on your tv to match whichever input you are using, most tvs will have a source button on the remote that you just press until you find the right one - some tvs will select this automatically.
If you are having trouble with this, then please post back with the make and model of the tv you want to use, and if possible take a picture of the connections on the tv and on the camera (use a mirror if you cant borrow another camera) and post the photos back here - then i can tell you exactly which cables you need and how to connect it up.
Hope this helps - please post again with details and/or photos if not :)
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on 4.1 camera:
I don't want to Accept this solution
Can you Help with these Digital Cameras problems?
I have a Mitsuba DV9002, I downloaded the software that...
it was working fine up til yesterday with picassa2. when i...
i just bought this camera. I bought a 1 gb memory card,...
i need installation software
i bough a camrea ata yard sale, the person a bought it...
Loading problems.
Repair Service
Find Digital Camera Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
