Panasonic sa-ak600 dear bluesman525, this is an inquiry regarding your post of august 7, 2008 about a panasonic sa-ak600: "I have the same unit . it will start and play fine but will shut down itselt after about 5 minutes. could it be a chip . unit seems to hae no ext. damage .so it may be a power supply component ..what do I do ?" a solution was submitted on Mar 28, 2008 by zair, "Most likely the regulator IC is defective. Part # C5BA00000105." i was wondering if you tried this solution and if it worked. please contact me with your reply at p-waters@hotmail.com thank you so much.
5 Suggested Answers
zair
  • 82 Answers
SOURCE: Panasonic SA-AK600
Try to power on the unit without the speakers connected. If it works normally without the error showing, then a speaker wire maybe shorted or a speaker defective. If the error F61 is still there, then most likely the Regulator IC is defective in the unit.
Posted on Jun 01, 2008
  • 5 Answers
SOURCE: i have a f61 fault code on my sa-ak600 panasonic audio system
Replace IC500 on power circuit board.
The board at the bottom with heat sink.
STK470-090 voltage regulator Sanyo original.
Posted on Nov 08, 2010
SOURCE: my panasonic sa-ak600 cd player doesn't switch on.
I had the same problem. My unit would turn on, display F61, and turn off. I looked at the manual. It said if you see 'F61', check and correct the Speaker Cords connection. If this does not fix the problem, there is a Power Supply problem. Consult the dealer. Hope this helps.
Posted on Dec 18, 2010
dunnbiker
  • 8546 Answers
SOURCE: Panasonic sa-ak600 F61 shows on
Generally speaking, an amp protects itself from heat, shorts and overloads by refusing to turn on or stay on.
Overloads can be from excessive periods of high output and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced hands-on tech.
Posted on Feb 13, 2011
My Panasonic DVD stereo sa-vk62d does not play any DVD or cd
Check and replace its laser pickup unit. If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Apr 12, 2016 | Panasonic Audio Players & Recorders
Need manual & remote
You can try www.panasonic.com contact customer support, or go to www.ebay.com Type make and model and go through the possible list if available.
Jul 19, 2012 | Panasonic SC-AK600 CD Shelf System
Panasonic SC-AK600 CD player says "no disc" when
Your cd laser lens has got weak.get it replaced.
you can replace only the lens or the whole laser pickup.
Dec 29, 2010 | Panasonic SC-AK600 CD Shelf System
My panasonic sa-ak600 cd player doesn't switch on. I checked the fuse inside the unit and found which was good. hopefully, someone can figure it out. thanks
Oct 04, 2010 | Panasonic SC-AK600 CD Shelf System
Panasonic SA-AK630 can i plug a ipod into it some how ?
for these stereo you have a AUX IN on the back (L and R RCA sockets)
from your manual follow these steps.
1. Press [AUX].
The unit comes on.
2. For listening: Proceed to step 3.
For recording: Press [a, REC] (recording starts).
3. Start playback from the external source. (For details, refer to the
external unit’s instruction manual.)
External unit connections
An analog player with a built-in phono equalizer can be connected.
For details, refer to the instruction manual of the units which are to
be connected.
When units other than those described above are to be connected,
please consult your audio dealer.
Rear panel of
this unit
(R) (L)
R L
then you need a ipod audio cable, available on mac store, but these cabble has 3,5 mm jack connector, need a adapter 3,5mm stereo jack to rca Connectors, and these is available on electronics stores, or professional audio store
try these and post
Jan 29, 2010 | Panasonic SC-AK630 CD Shelf System
My panasonic cd stereo system SC-AK600 keeps telling me that there is no disc even though all five disc trays are loaded, what is wrong with it
sounds like the laser is no longer working. Call partstore at www.partstore.com and let them know what model number you have and that you are looking for a replacement laser for the unit. Replacement is for the mechanically inclined or a technician. The part is static sensitive so I recommend taking the unit to a repair center.
Jan 01, 2010 | Panasonic SC-AK600 CD Shelf System
Radio won't play, display shows only a code of FB-1
Maybe the code error are F 61 for a panasonic sistem that code means bad audio amplifier
Jan 20, 2009 | Audio Players & Recorders
I have a f61 fault code on my sa-ak600 panasonic audio system
Dec 22, 2008 | Panasonic SC-AK300 CD Shelf System
Panasonic SA-AK600
May 30, 2008 | Panasonic SC-AK600 CD Shelf System
Nide code fore a panasonic cd stereo sistem
Jan 15, 2008 | Panasonic SC-AK600 CD Shelf System
165 people viewed this question
 Grubhead
Grubhead
