Question about Toshiba Satellite 1105 Series 14.1" Flat Panel LCD Monitor
Remove the hard drive
On the bottom of the 1105, i see a panel for getting to the battery and the memory, but not for the hard drive. the computer is beyond reasonable repair, and i'd like to pop the hard drive into an external case and use it with another computer. any help? the toshiba manual is useless. thank you!
  • 1019 Answers
SOURCE: Toshiba Hard Drive Crash
if the datas aleady deleted, then you have nothing to lose. Right ?
What you need is a 2.5 to 3.5 inch IDE ribbon cable connector.
this will enable you to put the drive into an IDE slot on the PC internal motherboard ( primary/secondary )
Unless it,s already 3.5"
boot the computer, see if it recognises the drive. And format it.
then you may be able, to re-fit back into the external casing, and use as an external again.
Mike @ compurepair.
Posted on Feb 25, 2008
  • 5 Answers
SOURCE: can't access or play games on my toshiba external hard drive
What does it say when you run it?
Posted on Jun 08, 2009
  • 542 Answers
SOURCE: toshiba 1tb external hard drive won't connect
One or more of the hints below will probably sort out most USB problems with most USB portable / external hard drives and OTHER devices (though not always)
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer.
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
6. If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
7. If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
8. ensure that you have set removable drives for "quick removal" or that you use the "Safly Remove Hardware" option often shown on the lower toolbar.It is possible that files my not be fully written to external devices before they are removed. This corrupts the file itself and even on occasion the drive.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
Hope this gives you the information you need
Posted on Dec 16, 2009
paper bag
  • 72 Answers
SOURCE: My computer isn't recognizing my new Toshiba Roco
If it is new and has not worked at all, you should try using it on another computer that, if possible, has a different operating system. My first option would be to create a partition using a 3rd party partition creator.
Posted on Dec 26, 2009
  • 236 Answers
SOURCE: External Hard Drive stopped working
u might have to format it in safe mode or buy a new one, if you try it on some one elses comp. and it works it ur comp. but it is most of the time a software issue
Posted on May 08, 2010
Toshiba laptop will not go psat the toshiba logo
There are a number of stages to go through. For all these please ensure that the laptop is switched off. First, remove the battery, then plug the mains charger lead in and try to boot, if you get past the splash screen than it is the battery at fault, if not then the next step is to switch the laptop off close the lid and turn it over, on the bottom you should see an access door with either one or two screws, open this access panel up and remove the hard drive, turn the laptop back over and try to boot up again, it should go past the splash screen and the detect that there is no hard drive installed, if it dose not get past the splash screen then turn the laptop back over re install the hard drive, try again to boot up, if still no good then try removing one of the memory chips, these are found under the same access panel. Try again if still no go then remove the other memory chip and replace the first one you took out. If no joy after all these steps, then sorry I have no further suggestions. Good luck.
Feb 03, 2014 | Toshiba Tecra R850 Series Black Notebook...
Bio passwod removal hp laptop
How to Reset an HP Laptop BIOS Password
Reset the password on any HP laptop.
Reset the BIOS password on an HP laptop computer when it has been forgotten or when preparing the laptop for sale to a new owner. Learn how to erase an unknown BIOS password by physically disconnecting the internal batteries. Avoid spending hundreds of dollars at a service center to make changes that can often be performed at home by anyone with the ability to take an HP laptop apart and put it back together again.
Items you will need
  • Small screwdriver set
  • Flashlight
Step 1
Power down the computer if necessary by holding the power button down for six seconds until the power shuts off.
Step 2
Disconnect the power cord from the HP laptop computer. Remove the battery by flipping the computer over onto its cover and releasing the battery clips as indicated by the illustrations on the bottom of the laptop or in the owner's manual. Lift the edge of the battery nearest the clips up first, then pull the battery out of the laptop.
Step 3
Remove the screws that hold the hard drive cover in place and remove the cover. Take the hard drive out of the laptop by removing the two retaining screws and pulling the drive gently away from the connector, then lifting the hard drive bracket or tray out of the computer.
Step 4
Remove the screws that hold the memory compartment cover in place, then remove the cover. Remove the memory modules from the sockets by spreading the metal retaining clips gently apart and allowing the module to spring upward. Pull the memory straight out of the socket at the angle it rests at when sprung from the retaining clips.
Step 5
Remove the Real Time Clock (RTC) coin cell battery from the memory compartment by pressing the retaining clip and pulling the coin cell battery out of the socket.
Step 6
Allow the computer to sit without the battery for an hour, then reinstall the memory and hard drive, but leave the coin cell battery and the main battery out of the system. Connect the AC power adapter to the system and power it on to clear the BIOS password.
Step 7
Power the system back down and remove the power cord to reinstall the coin cell battery and main battery.
hope this helps
Nov 17, 2012 | Microsoft Windows 7 Home Premium 64BIT...
How to set a toshiba hard drive to slave?
Power off the Toshiba laptop. Remove the power cord and the battery.
Turn the laptop upside down and remove the panel where the hard drive goes with a screwdriver.
Depending on the model of Toshiba laptop being worked on, this may include the entire bottom panel, a panel covering both hard drive slots or a panel covering the empty second slave hard drive slot.
Install the second hard drive by inserting it into the open slot.
Replace the opened cover.
Replace the battery and power cord.
Turn on the computer.
The second hard drive is automatically configured as the slave drive.
Depending on the operating system and previous status of the slave hard drive, it may need to be partitioned or formatted before being used by the operating system.
hope this helps
Sep 13, 2012 | Toshiba Computers & Internet
I need to remove the keyboard to fit new memory how do i do this please
You do not remove the keyboard in order to fit your memory (Ram). You have to unscrew the bottom panel of your Laptop. Some laptops come with a section where you open at the bottom so that you can have easy access to fitting in memory. There is usually two panels at the bottom one for the Hard drive and the other for the memory. if you do not have this you then have to unscrew the whole bottom to get to the motherboard and then the memory itself.
Oct 20, 2011 | Computers & Internet
How to remove hardrive from ml3109
Turn the laptop so the bottom is facing up. Make sure you have powered the laptop off and have unplugged the AC adapter and battery. Near the part labeled E there are two small phillips screws. You would need to remove those and the tray at location E will pull out with the hard drive attached. There will be 4 screws(two on each side) holding the hard drive onto the tray, remove those and the hard drive can now be taken out. Reverse the steps using the new hard drive.
Mar 05, 2011 | Gateway Computers & Internet
How to open and change RAM memory and hard drive on Gateway Netbook model number LT2704u?
This netbook is really the Acer Aspire One D255. You have to pop off the keyboard, then remove 4 screws that hold the back panel in place, which will allow you to remove that back panel in order to get to the memory.
Here's a video - blurry but it tells the story:
Mar 01, 2011 | Computers & Internet
I need to install a new hard drive .. how do I do
  1. urn the laptop over. Position your laptop in the direction so that the Toshiba label, on the bottom of the hard panel, is facing you. Your Toshiba label is positioned correctly if it is positioned on the upper-left side of the external hard panel. Remove the battery pack from the bottom your Toshiba laptop to be sure it is powered off.
  2. Step 2 Remove your laptop's external hard panel. This panel is the external plastic layer on the back of your computer to cover and protect your computer's most important hardware components. The screws you need to remove are located on the four outermost corners of the bottom of your laptop. Follow the chart guide listed in Tips for screw and screw driver compatibility and removal. Distance your screws from your workstation to avoid mixing them up and/or losing them.
  3. Step 3 Locate your hard drive panel drawer door when you have totally removed the external hard panel. It is located where the smaller door in the bottom-right panel was before your removed the external hard panel. Your hard drive will be locked into this specific drawer door and the computer itself. Completely unlock the hard drive and remove the drawer from your laptop.
  4. Step 4 Remove the entire hard drive from the drawer door. Hold the hard drive on all sides to ensure that you do not drop it. Place the removed hard drive in an enclosure area to avoid damage of any kind.
Place the new hard drive in and put it back up.
Please let me know if you have any further questions or concerns.
May 04, 2010 | Toshiba Satellite A105-S4334 Notebook
Cant find hard drive location
It is common that the hard drives on laptops are kept beneath where your palms rest when typing. either to the right or left of the mouse. To access it you will have to turn the laptop upside down and remove all the screws you can see...(hint take all panels for memory etc on the bottom off and the battery out as some screws are hidden there) Then flip the laptop back over and very carefully remove the top of the shell (moldeing around the keyboard, mouse, etc) If you lucky one of the panels on the bottom provide an easy access to the hard drive but this is rare and usually in HPs
Nov 02, 2009 | Toshiba P25-S526 Notebook
You didn't explain why you are taking it apart, but the two main reasons are Hard Disk drive Replacement
& memory (RAM) Replacement
The chassis of the computer is built sort of like the frame of a car
so I will detail how to do the two operations below
Hard Disk drive for 7510GX Laptop:
  1. Back up any data you want to transfer to the new hard drive.
  2. Before beginning, review electrostatic discharge (ESD) precautions.
  3. Shut down the computer, and then disconnect the power adapter.
  4. Disconnect the modem and network cables.
  5. Turn the computer over, and then remove the battery.
    1. Slide the battery lock to the unlock position.
    2. Slide the battery release latch.
    3. Lift the battery out of the bay.
  6. Remove the hard drive kit screw.
  7. Slide the hard drive kit out if the computer.
  8. If your new hard drive already includes the hard drive kit bracket, go to step 13. – OR –
Adding or Replacing Memory Modules
  1. Shut down the computer, and then disconnect the power adapter and modem and network cables.
  2. Turn the computer over, and then remove the battery.
  3. Loosen the memory bay cover screw.
  4. Remove the memory bay cover.
  5. To remove a memory module, locate the two clips on each side of a memory module, and then slowly press outward on the two clips at the same until the module tilts upward.
  6. Pull the memory module out of the slot.
  7. Hold the new or replacement module at a 30-degree angle and press it into the empty memory slot. This module is keyed so that it can only be inserted in one direction. If the module does not fit, verify that the notch in the module lines up with the tab in the memory bay.
  8. Gently push down on the SO-DIMM and make sure that the two clips on each side of the SO–DIMM click into place.
  9. Replace the memory bay cover.
  10. Replace the memory bay cover screw.
If you need to do something further, write back.
I hope that helps :)
Apr 16, 2008 | Gateway 7510GX Notebook
Toshiba Satellite 1105 Series 14.1" Flat Panel LCD Monitor Logo
264 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
