Question about Maytag PAV5158A Top Load Washer
Maytag pav51584ww my washing machine fills but won't stop filling i changed the fill level switch but that did not work any sugestions would be helpfull thanks
    President:
  • 1,462 Answers
Check the tube leading away from the fill level switch for splits .take tube offr and check for blockage. this tube goes to the air chamber which may also be clogged. if so clean it thoroughly
Posted on Apr 20, 2007
Top load maytag performa washer won`t stop flling both on wash and rinse cycles.
The switch the tube connects to shuts the water off. Will it cut off on high medium or low level. You can try blowing on the tube to see if it works. It should cut off when you blow.
Oct 15, 2017 | Maytag Performa PAV2200
My maytag home top loading washing machine over fills with water, ie. the switch to stop filling and start washing doesn't go off. I can drain it by setting it to spin.
top loading machines comes with a pressire switch to determine the water level.IT will fill with water till the switch is triggered to stop filling and continue with the next task of washing. there would be a rubber hose connected from the wash bucket to the pressure switch. Check for broken,leaking,bitten by rats hose or probably the switch it self is faulty, which is rather rare.
Aug 24, 2011 | Washing Machines
Maytag pav2300 wont stop filling up. New timer
After the water fill, Switch off the mains, allow little water bleed through the hose that goes to the level switch. As the water flows try fixing into the level switch block.
Clean the water drips to dry and switch on the m/c. It should be alright since you say that the switch is OK when air is blowed!
Apr 01, 2010 | Maytag PAV2300 Top Load Washer
Washer stopped filling. power still on. turning dial to different positions has no effect.
water level sensor not working or load size selector switch failed. could also be a failed water inlet solenoid valve. Turn it to cold wash and see if water fills again, if not turn it to hot wash and see if it fills again.
Nov 21, 2009 | Maytag Washing Machines
Maytag MAV5000 washer, water filling does not stop, small tube in back is hooked up.
Remove the small tube from the water level switch and blow through it to clear any clog in the air dome on the side of the tub.
Remove the small tube from the air dome and blow through it into the water level switch to reset it.
Then set the machine for spin and run spin cycle for 1 minute. Then try your fill again. If it does not work this time, replace the water level switch.
May 21, 2009 | Maytag Washing Machines
Maytag PAV2300 washing machine
You may need a new fill switch.Or you can try to remove the small hose from the outer tube to the water level switch and clean it.That is a short cut that may work but i would go with a new water level control switch hope i helped:)
May 16, 2009 | Maytag Performa PAV2200
GE wcxr1070a washing machine. fills with water
Check the water level switch and the plastic tubing to the switch.
Sometimes soap scum stops up the plastic hose and the water level switch does not close to send power to the timer.
If the plastic hose is good and the water level fills and stops replace the water level switch.
Mar 21, 2009 | GE WCXR1070A
Maytag performa not recognizing when to stop filling with water
be sure the rubber hose runnig from the water level switch to the tub is conected on both ends if not conected to the tub the water will come out the hole the hose is supposed to be conected to and it want stop filling.
Jan 21, 2009 | Maytag Washing Machines
Maytag washer will not stop filling when wash cycle is first selected. Doesn't matter if I choose small, medium, or large load.
How do you get it stop filling? If it stops filling by just shutting the timer off you may have a bad pressure/water level switch, if you have too shut the water off too the machine at the wall then you have a bad inlet water valve.
Jul 30, 2008 | Maytag Washing Machines
Maytag PAV5158A Top Load Washer Logo
47 people viewed this question
Top Maytag Washing Machines Experts
Sheldon Dedek
John Tripp
John Tripp
Donni Steen
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
