Question about Reddy R155D Utility Heater
Reddy heater r155d look-a-like--uses same motor and pump?
I have a reddy heater looking heater that says "Whayne" on the top cover and "master" seems to be the brand on the data sticker. I got it second hand and found the motor was burnt-up and the fuel pump mounted to the back side of the motor was in 20 broken pieces. What do I look for to buy a replacement part. Note: there is an area on the side that probably had a data plate riveted on it but it's missing I think it probably had the model number and serial number on it so I'm unsure of how to order parts.
  • 232 Answers
155 heaters use one of 2 motors. Either 097308-06 or 102001-30 (now 102001-33), depending on your model. They do not interchange or swap betewwn heaters. Go to www.reddyparts.com . Look up each number. Your motor will have a part number printed on it. Search that model and see if there is a replacement.
1/2" Rotor = HA3004
Posted on Feb 06, 2009
Fuel pump seems to have quit, need location of fuel pump Was looking for schematic of R155 Reddy Heater
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
Feb 05, 2011 | Reddy R155D Utility Heater
My heater comes on and after a few seconds goes back off
heatman101
Jan 29, 2011 | Reddy R155D Utility Heater
Reddy heater 155 squealing while running...suggestions?
check your fan motor because it may need lubrication and also make sure your screws are tight in the top cover.
Dec 07, 2010 | Reddy R155D Utility Heater
Is R155D the same as PRO155 ? If so , fine .... Other than that I`m not sure what else you`d need to know !? It`s real old and needs a set of filters... It fires quickly ... sounds normal ... doesn`t run...
You wrote "Is R155D the same as PRO155 ?" Answer- Yes, The R155D is a pro 155, BUT so are many other 155's and not all use the same technology. The newer ones are computerized, the older ones are not.
Yours, the R155D is computerized and uses HSI (hot surface ignitor) technology.
Filters....part number PP214 (complete filter kit).
Read these troubleshooting tips
Nov 13, 2010 | Reddy R155D Utility Heater
Were do you check for a filter? Heater is letting out fume.
Here are a couple of tips that I wrote that tell you how to troubleshoot aTorpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters Torpedo Heater Pump Pressure Adjustment
heatman101
Nov 07, 2010 | Reddy R155D Utility Heater
I have a 35000btu kero type reddy heater and the flame will not light. When I used it last I had a lot of paint dust in the air and it just quit. ( I know the dust is not good for safety) I took the top...
If there is no fuel coming out, then you must troubleshoot to find out why. The air pump has a dual purpose. It pumps air to the nozzle for atomization and sucks fuel frpm the tank.
Start by troubleshooting the pump by setting the pump pressure.
Dec 13, 2008 | Reddy R155D Utility Heater
Reddy R155D Utility Heater Logo
193 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
