Question about Philips Magnavox MRD510/17 Theater System
No S-Video out on AV1 source
MRD-510 surround sound, no manual. running video through S-Video to projector. Plays DVD and shows the video just fine, but when I have my Directv hooked up through the system, using RCA inputs, I can not get video to come out the S-video output. I can get video to come out the RCA outputs on the system, just not the S-video. I dont know if there is something I am just missing, or if there actually is something wrong.. Any help would be appreciated.. Thanks!
SOURCE: No sound when connecting to TV
I just figured it out right now. Press the "AUX/DI" button twice. When you push it once, it selects the "AUX" input and when you push it a second time, the screen will show that you've selected the "DI" input.
Thanks to Phillips for not making a theatre system that automatically selects for you... =P
Posted on Jan 23, 2008
SOURCE: Nice system cheap.
VCR will not play ?
See error message 1 displays.
No error 1 listed in instruction manual nor can I find any in system.
Posted on May 21, 2008
  • 36 Answers
SOURCE: no sound form my magnavox mrd-200
As long as the colored connections are in the correct holes (red with red and so on) then you should have sound if not then the built in amplifier is shot, it is probably better if you get a new system or contact Magnavox for a exchange price on out of warranty units which they have
Posted on Aug 19, 2008
welcomejee
  • 10594 Answers
SOURCE: Lost installation guide for Magnavox MRD 510 Home Theater System
Download MRD-210 User Manual as it might help you to hook up video cables properly. Connections between Tv and Homer theater is not proper in your case.
Posted on Sep 11, 2008
welcomejee
  • 10594 Answers
SOURCE: my sony dav-s-400 system keeps activating headphone port output.
Please change Headphone jack or headphone board because sensor switch built in headphone pin is sending wrong signal to system control so unit switch to headphone output.
Let me know if you need headphone pin or board part number.
Posted on Feb 03, 2009
I have the 3 RCA red, yellow, white cables on back of dvd and to tv. Video only plays when I select video 1 under the input. When when I select video 3 only sound and no video. What else can I try?
Sounds like from the symptoms that you have plugged the white and red cables into AV3 input on the back of the Teleivsion and plugged the yellow cable into AV1 on the back of the Television.
Check the cables are all plugged into AV1 input ports on the back of the Television. Red and White go into the Audio inputs and Yellow goes in the video input. Also make sure you have not plugged cables into component inputs on television look for AV1 in on back of Television .
Mar 08, 2015 | RCA Televison & Video
Sound plays with dvd but cant see the video. what could this be?
please check scart lead a rear of dvd player and also rear of tv make sure there pushed in firmly also try changing AV source from AV1 to AV2 or in some cases AV3
Oct 30, 2011 | Pioneer AVIC-F90BT GPS Receiver
IM tryin to hook up my samsung home theater system to my philips tv. It works when watching dvd, but when i switch to my basic tv cable it doesnt play sound out of my surround sound speakers. How can i...
Check what type of Audio input it has on it. It should either have an Optical Audio input(glowing red while unit is turned on) or an Audio input(red and white jacks) You would run the correct cable from the Audio Output on your tv, To the Audio Input on your surround sound reciever. Let me know if this helps solve your problem.
Mar 04, 2011 | Philips Magnavox MRD20037 System
Blue screen
At least a couple of possibilities, check the yellow video cable that runs from the VCR to the TV, is it plugged into the side of the combo unit that says vcr?
Is your TV on the right source? You could have plugged the audio into say AV2 and the video into AV1, causing a mismatch. Make sure the yellow, red, and white are all plugged into one input section on the TV (AV1, AV2, Video 1, Video 2, etc).
Dec 09, 2008 | Philips MRV700VR DVD Recorder/VCR
Sep 11, 2008 | Philips Magnavox MRD510/17 Theater System
Epson Powerlite 1815p screen projector - DVD playback video jerkiness when there is motion in the video
I am assuming that the DVD plays normally on the display of the Dell 745.
Then the issue(s) may be with the:
1. Networking configuration/set-up of the Dell and/or the Epson;
2. ethernet cable;
3. configuration/set-up of the projector or the Epson itself.
A couple of things you can try:
1. Optimize your networking throughput.
1.1 Increase your PCI Latency Timer to 128 or 255 in the Dell's BIOS/CMOS setup (if present);
1.2 Try running DRTCP.exe and/or TCPOptimizer.exe appropriate to the Dell's OS;
1.3 Disable all other networking activities on the Dell. This may include auto updates, security/antivirus checks, etc. while running the DVD;
1.4 Slim down Dell's startup programs to bare minimum;
1.5 Increase your OS' swap file to roughly double your onboard memory
2. Try running a hub midway between the Dell and the Epson.
3. Verify that it is not the Epson that is problematic by playing a video source to the projector’s Video or S-Video port. If it is, then you have narrowed down the problem to the playing capability of the Epson.
Alternately if all else fails, perhaps you can try using:
1. a DVD player to the projector’s Video or S-Video port; and/or
2. a USB external DVD drive or a CompactFlash card (with a copy of the movie) direct to the 1815p
while settling the main issue.
Hope this be of help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Jan 07, 2008 | Office Equipment & Supplies
Video on game and dvd seem to work
DO you have hdmi monitor turned on?
Jan 05, 2008 | Onkyo TX-SR605 Receiver
No sound from speakers
You probably popped a fuse in the unit..should be on the back of the amp.
you can play dvd through your telle,just run audio video cables OUT of dvd player,and IN to tv (av1),then turn telle to AV1,and wholla...
Dec 30, 2007 | Sony DAV-SA30 System
Hooking up to digital cable box
Darth,
There are 2 ways you can accomplish this.First is the least quality which is via coax.What you want to do is connect the cable service coming from the wall to the input on your cable box.Then the TV output on the cable box goes to the input on your surround sound then the coax goes from the surround sound to the coax input on the TV.The second is to Connect using the RCA AV1 input.what you want to do is look at the back of the digital cable box and locate the OUTPUTS for the RCA jacks(or AV output)connect RCA cables (yellow red white) to the 1st INPUT on your surround sound.depending on models you should have a couple of different INPUTS for a signal.Choose one and plug it in.After that take a second pair of RCA cables and connect them to video OUTPUT on the surround sound and connect them to your AV1 OUTPUT on your TV.With the original remote for your TV,NOT the cable universal one,Look for an INPUT button on the remote.Some are called input some are called SOURCE,TV/VIDEO basically it tells the TV what signal source to look at on the back of the TV.If you dont have the remote put the TV on channel 3 then press the channel down button and when the TV gets to channel 1 press it again and it should start cycling through the AV inputs,choose AV1.
Once you have done this you have correctly
hooked everything up,BUT Like I said depending on the model of surround sound you are going to have to CHOOSE or physically select or "tell" the surround sound receiver which input to RECEIVE the sound through.In general the INPUT on the back of the surround sound will be labeled with something like Video IN,VCR IN, DVD IN and so forth.Make sure the surround sound is selected to Receive the sound coming from the digital box.Sometimes there is a dial on the front of the surround sound that allows you to select which INPUT on on the back becomes active .make sure that what you have selected matches what you have your cable box is connected to.Hope this helps!
Nov 03, 2007 | Pioneer HTD-510 System
Philips Magnavox MRD510/17 Theater System Logo
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
