Question about Toshiba TZ43V61 43" Rear Projection Television
Convergence will not adjust
Double words,there is a rainbow of colors all over the screen,all the colors are off and the convergence adjustment does not help or in some color instances does not work at all, also the tv takes 30 minutes or more to warm up,
  • Toshiba Master
  • 5,138 Answers
You need to replace Both of your STK ICs these are your convergence ics They are Big Black chips with STK on them for Example STK392-110s ect......... you will also need heat sink silicon to put on back of new ones If stks are 110s use 180s better chips. For Parts go to www.electronix.com or Call 1-800-223-3205 if ics are 020s use 040s if not use same number as on ICs.
Posted on Dec 27, 2008
55PW9363 55 in. Rear Projection HDTV-Ready Television: My Phillips big screen has double images and doubl...
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
May 17, 2010 | Philips 55PW9363 55" Rear Projection...
My toshiba 57in rear projection the color is off and when words are on the screen they look doubled?
Sounds like you need to check the convergence. You can in the MENU under PICTURE go down to the CONVERGENCE to make the adjustment, set the RED and BLUE
May 17, 2010 | Toshiba 57H82 57" Rear Projection...
Sometimes I get a rainbow on the bottom of the screen.
Your TV most likely has a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
Using your original remote go-to the tv settings then goto the convergence section.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Jun 18, 2009 | Philips 60PP9202 60" Rear Projection...
Kp-46wt500 shadow and slanted images with rainbow colors
  • Screen looks 3D
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Mar 04, 2009 | Sony KP-46WT500 46" Rear Projection...
Double picture & color problem
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai2_bing.gif,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 22, 2009 | Sony KP-53XBR45 53" Rear Projection...
Bent picture
Not sure if you fixed your problem already. But the answer is a color convergence problem. You can try adjusting manually via the remote and if that doesn't work it is most likely the two main IC chips that control the color convergeance. It is also possible that not only the IC chips have gone bad but also there are a couple of resistors that usually burn out with the ICs as well. They will need to be replaced. This isn't something that I would attempt on your own. Typically a TV technician will charge between 300 and 400 to fix at your house.
Mar 15, 2008 | Philips 60PP9363 60" Rear Projection...
Convergance problems?
did you adjust the convergence
on the menu?
Jan 11, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Panasonic 52"problem
You need to change the two convergence IC's - Generic part# STK392-110, Panasonic part# C5AA00000203. You might have problems using the generic #, I would use the Panasonic #
Sep 26, 2007 | Toshiba 46HM95 46" HDTV
Bent picture
The convergence circuits straighten out the edges of the picture, putting the 3 colors exactly where they should be for the picture to look normal. There are usually 2 large IC's that handle the 6 convergence channels and if one of them burns out then one of the colors bends dramatically. If the power supply for the convergence circuits stops working, then all 3 colors bend in, the colors do not line up with each other and the image looks almost 3D, and the adjustments in the convergence menu will have no effect. I would bet that is the case with your set - the convergence power supply has quit working. If you do not have experience troubleshooting power supplies and realigning convergence circuits in projection TV's then allow a qualified tech to handle it for you.
Aug 07, 2007 | Philips 51PP9910 51" Rear Projection HDTV
Cannot adjust convergence, screen has rainbow effect
You probably need to change out the semiconductors. The parts are STK392-110. There are two of them, one for horizontal and one for vertical. Search it online more.
Dec 28, 2006 | Panasonic PT-53WX53 53" Rear Projection...
Toshiba TZ43V61 43" Rear Projection Television Logo
149 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
