Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
RCA D52W20 52 in. will not power up
My problem is the green light blinking 3 times and no power up issue. I intend to replace the capacitors that have been written about previously. The big problem is I am not which PCB these are located on. Facing the back of the TV with the cover pulled off I think it is the left hand board in the rear. Would this be correct ?
  • aleaa81 Dec 28, 2008
    rca d52w20 will not stay on. it powers up, 10 seconds later green indicator power light goes out, then does same 2 more times till after 3rd time, it shuts off completely. is this the flyback? is there a code for 3 times reffering to it be the flyback? please help soon!!!! :o
    thanks!!
  • theo317 Dec 29, 2008
    My problem is the green light blinking 3 times and no power up issue also! Light blinks 3 times, but not lighting up! I thought i might need to replace the capacitors, but i dont know for sure. What can I do??????
Replace the flyback unit
Posted on Dec 30, 2008
My RCA D52W14 wont turn on it makes a weird noise and the power light blinks as it's making the noise three times than the blink stops and noise too
Hi
Thanks for using FixYa. On the Deflection board there are 3 capacitors CP 114, 120 and 150. 3 blinks occur if any of them is puffed up on top. To resolve this issue you'll have to replace all the 3 capacitors CP150 2200UF 16, other 2 are 220UF 35v they will be green with gold writing on them. Also re solder all pins on Fly Back Transformer (FBT). Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 12, 2010 | RCA D52W19 52" Rear Projection Television
52" rca hdtv monitor power flashes 3 times after pushing it and tv does not turn on.
Hi
Thanks
Rylee
Aug 10, 2010 | RCA R52WM24 52" HDTV Projection Television
I have a RCA D52W17 rear projection T.V. When I turned the power on the green light flashed 3 times then shut off and now it won't go on at all.
Hi
Thanks for using FixYa. 3 blinks in your RCA D52W17 rear projection are caused due to 3 capacitors (CP114, 120 and 150) which are located on the deflection board. If any of these capacitors goes bad you’ll have to replace them with the exact same ones. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 21, 2010 | RCA D52W19 52" Rear Projection Television
Green to red blinking light when plug in rca lcd
It is the capacitors on the power supply...They blew on ours...took it in a they replaced 7 for less than 100.00. Common problem with this tv because it gets hot. Hope that helps.
Nov 20, 2009 | RCA L42WD22 42 in. LCD Television
RCA R56WH78 Green LED Blinking
Ck 3 capacitors on deflection board cp150 2200uf 16v use 25v if it is puffed up on top it is Bad other 2 are 220uf 35v cp114 cp120 resolder all pinns on FBT flyback transfomer.
Nov 12, 2009 | RCA R56WH76 Projection Television
Problem with d52w20
On the Deflection board there is 3 capacitors cp114,120,150 if any of them is puffed up on top replace all 3 capacitors cp150 2200uf 16 other 2 are 220uf 35v theywill be green with gold writing on them. Resolder all pinns on FBT also.flyback transfomer.
Feb 18, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Come on and goes off
3 bad capacitors located in front of deflection board cp150 cp111 cp114 they are green with gold writing on them if cp150 is bubbled up on top it is bad. 2200uf 16v. so replace all 3 capacitors.
Nov 22, 2008 | RCA HD52W59 HDTV Projection Television
3 green blinks
Look on Deflection board cp 150 2200uf 16v capacitor and there is 2 more capacitors 220uf 35v replace both of them. Green and Gold writing on caps.
Sep 09, 2008 | RCA D52W19 52" Rear Projection Television
Blinking green power light & shut down
There are (4) 1000uf @35V capacitors all together on the DM board that need to be replaced some models have 1000uf @ 16V but they are all right beside each other and all rated at 1000ufs the voltages will be stamped on the capacitor along with the uf ratings.
Apr 07, 2008 | Mitsubishi WS-55515 55" Rear Projection...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
167 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
