Question about Samsung Digimax L730 Digital Camera
Samsung L730 wont extend lens and dosent turn on right
My Samsung L730 wont turn on right. The lens doesnt extend, the screen stays black, there are three bleeps and it wont turn off without me having to take the batteries out.I have the same problem, I droped my camera, I turned it on right after I had droped it to check if everything was ok. The Lens popped out and everything seemed to be ok. When I tried to turn it on 2 days after, the lens wouldn't pop out, the sceen would stay black and the camera produces 3 beeps. I have to take the batery out for the camera to turn off.
  • Anonymous Feb 19, 2009
    I have the same problem. Out of nowehre, I can't turn on or of my Samsung L730 camera.. It makes 3 beeps and simply wont do anything. my pover button is on, at least light is on, but nothing goes on. I do not know what to do. I love this camera, and haven't had any problems until now. Thank you.
  • 100 Answers
The connectivity from battery to the device is bit misaligned along with the misalignment of some other parts due to dropping. just needs servicing to work properly.
Posted on Dec 27, 2008
    Sergeant:
    Novelist:
  • 327 Answers
The internal circuit got misallighned or may be cracked and needs reparing or replacement.also try replacing the batteries.but most probably replacing the device is much advisable as reparing this will be more then new device.
thanks.
  • 15,935 Answers
Try removing the batteries and memory card. Let the camera set for awhile. Put the batteries back in but not the memory card, restart the camera. Does it work know? If it does, turn the camera off put the memory card back in. Turn the camera on, does it work now? If it doesn't, replace the memory card.
My Samsung SL202 isnt working the back screen stays black when i try to turn it on and it makes a sizzling noise then then lens comes out but dosent pop back in
that is a lens error in the alignement of the lens;
its may due to some dust in motor lens block ***'y and probly needs to be clean ...
hope that will help
regards Alan..
May 14, 2010 | Samsung SL202 Digital Camera
L730 wont turn on, lens stuck half way
Hi, Lens is jammed, lens motor gearbox requires restting. If you in the U.K I can help you out.
p.m me at kiddo242@hotmail.com
Aug 09, 2009 | Samsung Digimax L730 Digital Camera
The lens on my L730 digital camera does not open.
Hi, I had exact the same problem with mine Samsung L730. I opened it and took the 2 flatcables from the circuit board (to the lens-unit) out of there connectors. After I put them back in again, the camera worked. I geuss it was a bad electric connection of the lens-unit. Maybe this will solve your problem. If the camera is older than 1 year and has no warrenty, just try this. Good luck.
May 23, 2009 | Samsung Digimax L730 Digital Camera
My samsung digital L730 wont turn on
Just fixed mine, if the lens is out that's the problem we had, it was jammed and not allowing it to switch on, we gently pushed it back in, then switched on, the lens came out a bit then jammed, pushed it in again & kept doing it until it cleared the blockage.
Works fine now!
Hope it works for yo
Jan 03, 2009 | Samsung Digimax L730 Digital Camera
Met the same problem. I disassembled camera and found a lot of sand in lens transmission. I couldn't move lens even by hand. It was strongly jammed. I had to disassemble lens block completely to remove all sand. Now camera fully functional.
Dec 15, 2008 | Samsung Digimax L730 Digital Camera
Samsung L730
This camera would have to be tested more, but it sounds like a ccd or sensor problem.
If this camera was made around the year 2000 or after a bit, then it could be a ccd problem common with many Sony made ccds in this period.
A loose connection internally could also cause similar problems.
Aug 01, 2008 | Samsung Digimax L730 Digital Camera
Samsung L730 stuck
I tried turning it on, removing the battery, replacing the battery, and turning it on. This didn't work. When I repeated this but also removed the memory card, it did work.
May 22, 2008 | Samsung Digimax L730 Digital Camera
Samsung Digimax L730 Digital Camera Logo
289 people viewed this question
Top Samsung Cameras Experts
Computer Links
Jerry Z
Are you a Samsung Camera Expert? Answer questions, earn points and help others
