Question about Russell Hobbs 9376 Classic 2-Slice Toaster
Our R-H 9376 Toaster suddenly stopped working. The handle won't stay down and the heat doesn't come on. It's as if the electricity was off. I've replaced the fuse in the plug but it seems ok. Tried it in another socket too.
Can anyone help with a possible solution?
  • Anonymous Feb 04, 2009
    I have exactly the same problem but haven't tried replacing anything in it yet.
  • scotslads Mar 28, 2009
    It turned out after dismantling the toaster that a tiny piece of metal had broken off - it was about 2mm wide by 10 mm long and folded in half like a sort of spring and had broken at its weak point. It was impossible to solder or fix it back on so for the sake of the tiny thing the toaster could only be thrown out. Sad.
Possibly a GFI on an outlet of the same circuit as the toaster needs to be reset?
We had the same problem and so came here. When I read "replaced the fuse in the plug" my husband asked about the outlet GFI switches (he replaced the outlets last year, so he remembered they had GFI switches). One GFI on the toaster's circuit had "blown" and so needed to be reset. Before relegating the toaster to the recycling bin, check the it by plugging it into an outlet you know is working.
Posted on Mar 28, 2009
Toaster won't turn off
its broken, retun it to the place you brought it and demand a refund
Nov 22, 2013 | Russell Hobbs 18117 4-Slice Deluxe Toaster...
Russell-Hobbs 18140 4 slice compact toaster
See the diagram attached:
You will see the fuse you will problema 1) Ground 2) Live wire touching the chassis 3) Heating elements in short 4) Control Relais in short. 5) Test Diodes,You must test every components.God bless you
May 17, 2012 | Russell Hobbs 18140 4-Slice Compact...
Green wire where does it go
If the connected end is attached to the toast holder and NOT the heating element, then this is a ground wire, and the other end should indeed connect to the case (body) of the toaster.
It may be attached with a screw (typically the screw is also green) or it may be attached to a simple metal tab (on the body) with a notch in the tab to accept/hold the wire.
If this helps, be sure to hit the "thumbs up" for me.
If not, use the "add comment" button and we'll get you sorted out.
Apr 17, 2010 | Russell Hobbs 9376 Classic 2-Slice Toaster
I bought my toaster in New Zealand without its a box but neither did I receive any instruction booklet all its details or to know what the buttons on the side are for. Neither did I receive a form for the...
All I needed was a printable copy from the web of the instruction leaflet that goes in the box with the toaster when you buy one. I fixed my problem WHEN I SAW I HAD TO PAY to ask a question!!!!!
I'll have a look in the shops when I see a toaster here.
Thanks, but no thanks
Jan 13, 2010 | Russell Hobbs 9376 Classic 2-Slice Toaster
Russell Hobbs Toaster has just stopped working
get your volt ohm meter out unplug it and disassemble it check your heating elements if there is no resistance the elements are bad. ONLY if you are comfortable with ac voltage!!! turn your meter to check ac voltage VERY CAREFULLY make sure nothing is shorted plug toaster in press toast button down. this should send voltage through thermostat to the coils . if you measure voltage across toaster switch when it is depressed the switch is bad. check your thermostat same for it if there is voltage across it it is open (bad).
Jan 12, 2010 | Toaster Ovens
Russell hobbs toaster 9379 bread carriage handles won't stay down to toast
bought a new toaster I would like any account you have created for me to be deleted. thank you
Dec 22, 2009 | Russell Hobbs 9379 Classic 4-Slice Toaster
Require replacement wire which triggers the catch when the operating handle is pushed down. Where can I buy it?.
Russell Hobbs products are firmly placed at the budget end of the market and many of their products have little or no spares availability as they're often not designed to be repaired.
However, they do supply spares for some models if you're unable to fabricate the part yourself, see web address below:-
http://www.russell-hobbs.com/parts.shtml
I hope that you've found my answer to be useful and ask only that you return the favour by rating my answer.
Sep 24, 2009 | Russell Hobbs 9206 Classic Coolwall...
Bread will not stay down
Be sure the temp/time dial is not on zero.
Mar 11, 2009 | Russell Hobbs 9376 Classic 2-Slice Toaster
Russell Hobbs 9209 Classic toaster
I had the same problem which I managed to solve. The electro magnet that holds the toast lever down takes its power from a poor joint.
Remove the bottom of the toaster. You will see 2 wires encased in a heat proof sleeving going from the small circuit board. One of these wires dissapears up inside the heating element board about mid way along the board. You will now have to remove the metal covering by twisting 6 tabs. This is best done by taking off the black knobs you use to push the toast down - if you can - I couldnt, so I had to use long nosed pliers to bend the tabs and then with difficulty, remove the metal cover. YOu should now see the terminal that the wire is connected to. It is this connection that fails either between the wire and coonnector or connector and heatin element on the reverse side. I put a small bolt through the hole and used a nut to tighten the pressed fitting. I didnt use solder because I thought that it would just melt!
Anyway, my toaster worked after that. Russell Hobbs failed to give me any advice at all.
I hope that has helped.
Neville
Welwyn Herts
Aug 25, 2008 | Russell Hobbs 9209 Classic 4-Slice Toaster
Russell Hobbs 9376 Classic 2-Slice Toaster Logo
534 people viewed this question
Top Russell Hobbs Kitchen Appliances - Others Experts
Jerry Greenberg
Jerry Greenberg
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Russell Hobbs Kitchen Appliances - Other Expert? Answer questions, earn points and help others
