Question about Proscan 26LB30QD 26 in. LCD HDTV
I have a Proscan 32LB30QD flat screen HDTV and can not get the base off for a wall mounting. I have tried just about everything, does it come off?
  • carlton1801 Apr 02, 2009
    The base originally just popped on. Only see 2 screws. Have taken them out. Base WILL NOT come off. This is a Proscan 32LB30Q.
Remove the 4 screws above the base. The base will slide out.
two_4beach
Posted on Jan 10, 2009
Why vertical lines on half of screen after moving Proscan 39" LED TV?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Sep 14, 2014 | Proscan 32LB30QD 32 in. LCD TV
Proscan 32LB30QD Color Problem
Try resetting it to factory settings and see what the color looks like.
Nov 20, 2011 | Proscan 32LB30QD 32 in. LCD TV
I have a Proscan 32 in LCD Model # 32LB30Q . I had TV mounted base misplaced where can I order replacement base
You will have to order it from Proscan. The part# and web address should be in your owners manual.
Jul 14, 2011 | Proscan 32LB30QD 32 in. LCD TV
Trying to hookup vhs analog player to hd proscan
your toshiba player should have output composite video and audio which are color coded Yellow for video, red and white for audio same goes for proscan hdtv. connect between the two keeping in mind color of cables. If the toshiba player is really old you can connect the RF cable output to antenna input to the proscan tv and watch taped programs from the player on channel 3 of the proscan tv. If then you want to keep the hookup and still watch HDTV connect the antenna to the toshiba vcr and when you shut off the vcr you can now watch the hdtv channels as usual because now you are bypassing the antenna to the Proscan tv. Hope this Helps..
Dec 29, 2009 | Proscan 32LB30QD 32 in. LCD TV
Wall mount screws don't fit in my proscan 32lb30qd
The PEERLESS kit should be supplying the Metric M4, M5, M6 to cover most of the screws used for mounting the mounting plate to the back of the TV.
Dec 18, 2009 | Proscan 32LB30QD 32 in. LCD TV
Wall Mount won't fit screw pattern (405mmx200mm
for $19.99 you can get an adapter.  Do a search for TV mount adapters 200x400 on amazon, or tiger direct, or the shopping site of your choice.
Feb 18, 2009 | Proscan 32LA25Q 32 in. LCD TV
Looking for a wall mount that fits the ProScan 26LB30QD
I purchased a Level Mount DC30SJ from Walmart online, then called Level Mount and they sent an adapter plate for no charge. It works great and was easy to install.
Feb 16, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
I can not remove the bottom stand off the Proscan TV Model 26LB30QD to mount on wall. Any suggestions?
I have this model (ProScan 26LB30QD) and recently removed the base. There are 4 phillips head screws on the rear panel of the TV just above the base. Remove them, pull the TV from the base, and replace the screws in case you need to use the base in the future. I suspect the problem others are having is that they only removed 2 of the screws.
Nov 22, 2008 | Proscan 26LB30QD 26 in. LCD HDTV
Proscan 26LB30QD 26 in. LCD HDTV Logo
493 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
