Question about Sony FD Trinitron WEGA KV-36XBR800 36" TV
Sony VEGA KV-40XBR800 d Board failure
I ordered the d board from the Sony website (part A-1300-319-A) and need to know how to replace it. Can you help with locating the instruction guide?
Sony kv-40xbr800.......doesn't turn on......standby light blinks 6 times....what might be the problem?....is it worth fixing?
Posted on Sep 02, 2010
    Genius:
  • Sony Master
  • 1,689 Answers
I suggest you order the service manual for your set. Depending on the board, it may need calibration. You will need the proper tools and setup to follow through. The service manual will have the details. Depending on the board that is being replaced there can be a lot involved.
Did you verify that the board you are buying is in actual fact the failure??? Many times, I have seen people order and replace boards and the new board was not the fault, or it was damaged because there was a serious fault somewhere else.
Jerry G.
Posted on Jan 09, 2009
Sony vega kv-36xbr250 screen black - can feel static - has sound
The tv 1 or 2 long LCD inverter board it is dead.These 1 or 2 long LCD inverter boards help the LCD screen panel to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy those 1 or 2 LCD inverter boards for the replacement.
Mar 21, 2011 | Televison & Video
My sony kv-40xbr800 blinks 6 times, no video no audio, it wont turn on, whats going on?
The problem is on the 'A' circuit board. It is the IC504.Or, it is a low voltage drop or a short. Replace the "A" board. It is the front board on your right when you are at the rear of the set when you remove the cover. Look it up on the net. PS Don't touch the chassis while it is on...HIGH VOLTAGE !!!
Aug 02, 2010 | Sony FD Trinitron WEGA XBRKV-40XBR800 40"...
I have a Trinitron KV-40XBR800. Won't come on.
the indicator lamp flashes a determined amount of times then there is a pause, then lights the same amount of times again, by what you describe there is a power supply or a deflection circuit problem.
Jul 28, 2009 | Sony Televison & Video
My sony standbt light is on. no pitcure
The "D" board has probably failed. Most of those boards are not available from Sony but can be sent to Sony for Refurbishing. The 'D" Board has the Deflection , Protect, and most of the PowerSupply incorporated on it. Most of those Boards are also Double Print/Multi Layered style boards that make it difficult to repair at a component level.
Best thing to do in mt opinion is to call Sony at 100222SONY and see if they can refer a Service Facility to you if you are willing to put 600.00 to 800.00 into it.
Hope this helps,
skyassoc
Jun 22, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Sony Vega Service Codes
KV-32HS510 and KV-27HS420, seven times blink error code shows problem in Horizontal deflection circuit.
There are many possibilities like dry solder joints, weak capacitors, Horizontal transistor short or flyback transformer fried etc.
If you have little experience of TV repair and good solder skills and have necessary tools to test / check defective parts, then you can make it. you also need to have related service manual to see board location, schematics and part numbers.
Dec 12, 2008 | Sony FD Trinitron WEGA KV-27HS420 27" TV
Sony Trinitron Vega KV-34HS420
it's better if you bring you're tv to sony service center and ask to an authorized repairman
May 07, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
RE:Control Board Failure
well..the 'D' Board would show up on a parts list, authorized by the maker. You are encouraged to procure a proper service manual, which will go a long way to clear up any mysteries on this issue.
Mar 17, 2008 | Sony FD Trinitron WEGA XBRKV-40XBR800 40"...
Sony kv-40xbr800
Exact same problem. KV-40XBR800 wont turn on, blinks six times. I am in the process of changing both Ic's part# MCZ3001D with part# MCZ3001DB. Ordered them frm ebay and waiting for the new parts to arrive.
here are the pictures of both chips and after i removed them from the d board.
As soon as i receive the new ones i will put them in. I can't wait to see what happens and i wanted to say thanks to all of you out there for putting this thing up. Thank you very much.
Nov 05, 2007 | Sony KV-40XBR700 40" TV
Sony FD Trinitron WEGA KV-36XBR800 36" TV Logo
4,938 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
