Question about JVC TH-M303 System
Tray issues I have the JVC TH-C30. It will not release any of the 5 DVDs inside. The manual doesn't cover this problem which I think could be fairly common. Help?
I have had this a few times and it is a pain. You have to completely remove the DVD unit from the chassis (ribbon cables and all). Once out, you turn it upside down and you will see a set of gears that drives the trays in/out. Manually rotate the gears to reset the tray position (one will likely be out of place when you open it up or a DVD will be skewed causing it to bind). This is not for the faint of hearted or non-mechanically enclined. This particular DVD changer unit is troublesome and finicky to deal with. I have also found that copied DVD's cause this to occur due to some issues with disc detection.
Posted on Jan 25, 2009
It seems that the dvd player is jammed. Cant get dvds out or in. Wont play. Is there some kind of reset or something I can do to fix it. Thanks
its very common for 1 of those 5 trays to get stuck in the unit usually with a disc as well --you will have to manually go in while its unplugged elevate the tray by spinning 1 of the 2 large gears near the front of the mech and reseat the tray
Aug 31, 2010 | JVC TH-C5 System
JVC TH-C30 dvd movies skip
Check your formatting on the DVD recorder, you need to finalize the disk to be playable on "any" player. That should solve the issue. Your JVC is looking for specific code as it reads the disc, when it's missing or not understood by your JVC it will either stop play or skip over it's interperated missing info. Hope this helps
Jun 23, 2009 | JVC TH-C30 System
How do i unlock a jvc home stereo
On the unit, press the stop button and the cd eject button at the same time. The screen will say locked still. Release them and press them together again at the same time. The screen will now read unlocked. You can then eject the cd.
Oct 15, 2008 | JVC TH-C60 System
Universal Remote
I do not know if it works but you can check the website, I am very happy with my Logitech Harmony remote. Probably overkill but you will love what you can do with these.
Jun 26, 2008 | JVC TH-C30 System
No power
I have a TH-C30. I had the same problem where the unit just stopped working - no standby light and no recognition of power at all. After checking this forum and another, I opened the unit, found the ceramic fuse where the power comes in and went to Radio Shack. They have a T1AL250V fuse pack that is a 1 amp, 250 volt, 5 X 20 mm SLOW BLOW glass fuse which is a better fuse for this common problem. Their RS number is 270-1063 and a pack of 4 costs about $3. Put new fuse in and the problem was solved.
The repair took minutes - 3 screws on the back and two screws on each side. Lift the cover from the back (it is slip-hinged on the front) and replace the ceramic fuse. It slips out with a little help and the new one snaps in place.
Jul 21, 2007 | JVC TH-C30 System
How do i unlock my jvc th-m505 dvd digital theater system?
Hold the STOP button and push the EJECT button.
May 15, 2007 | JVC TH-M505 System
JVC TH-C30 System set region 4
you will have to change your DVD player for a all region DVD player.good luck.
Apr 11, 2007 | JVC TH-C30 System
Tempremental playing dvds
In response to your jvc-a75r DVD player, sometimes the solution might be less complex than it may appear. Had the same problem with my Samsung s321,the machine refused to read DVD's but would play CD's no problem. Simply opened up the cover(usually)4-6 small screws, and found my dog's hair inside of the player covering the laser eye.Electrostatic ionization attracts dust,etc. into the player remarkably well sometimes. Carefully used a cotton swap to remove debri. PLayerworked fine afterwards ...Good luck!
Feb 27, 2007 | JVC TH-A75R System
JVC TH-M303 System Logo
145 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
shaun taylor
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
