I am a second owner for a ge tv that i am trying to use a universal remote to get it working. they are asking for a manufacturer code number which i don't have. how do i find that?
  • 5,138 Answers
G.E. Codes for universal remotes 000-054-003-004-006-022-052-055-087-164-165-166-167-168-181-193-213
Posted on Dec 27, 2008
We have a naxa converter box with a GE universal remote searching for the code
About 17,100 results (0.72 seconds) Search Results
    GE Universal Remote Codes and Instructions ' direcTutor
    www.directutor.com/content/ge-universal-remote-instructions
    Enter the three or four digit code for your device using the number buttons in the GE Universal Remote. After your code is entered the INDICATOR LIGHT will ...Missing: naxa
    Apex Digital TV Converter Box DT250 code ' ManualsOnline ...
    tv.manualsonline.com/support/...digital/tv-converter-box/code-1082992
    Nov 15, 2008 - Brock Search data: Universal remote control code apex dv converter... 4 I NEED CODE FOR APEX CONVERTER BOX FOR GE UNIVERSAL ...
    Trouble programming Universal Remote to a DTV Converter ...
    www.fixya.com/.../t2045188-trouble_programming_universal_remote_d...
    Apr 21, 2009 - So I'm trying to program my GE Universal Remote to work with my Digital Stream Converter Box but I can't find the codes to do it... If someone ...
    Control It All With Universal Remote Codes - Digital Landing '
Feb 08, 2016 | GE Televison & Video
My wave cable hd dta remote will not turn offandontv...repair guy said to ask vizio
Use the following instructions and code list to program your VIZIO Universal Remote Control. Press the TV (or device) button and hold for 5 seconds until the LED flashes twice. LED will remain lit. Find the programming code for your TV (or device) in the code list and enter it using the Number Buttons.
try a universal remote and program it, from the manual.
3 Digit Universal Remote Codes For TV Codes For Universal Remotes
4 digit GE universal remote control codes with code entering instructions
http://www.remotecodelist.com/
http://cdn.vizio.com/documents/downloads/vizio-universal-remote-codes.pdf
Feb 03, 2016 | Vizio P50HDTV10A 50 in. Plasma HDTV
I need help i have a GE universal remote RC430A Date code1636 I need to program the remote to the tv but i don't have the code. Please help.
Look inside the battery compartment and check the label. There may be a version code listed on that label. The GE remotes were manufactured by Jasco and the code lists are here: http://jascoproducts.com/support/ge-universal-remote-codes . Use the correct code list for the version for your remote. Note: these codes work for remotes sold in 2006 and later. For older GE remotes that use a 3-digit code, try this site: http://www.eliztech.com/remotes/ge-new-3digit-tv-codes.php .
I hope this helps.
(the remote control codes will often be limited to TVs that were sold at least 6 months before the remote was programmed. If your TV is newer than the remote, you may need to update your universal remote.)
Jul 10, 2015 | GE Televison & Video
Have a GE universal remote model number 24922-CL3 1349 what codes do I need to use so it will work with my RCA ColorTrak Plus 1996 model tv with model number F27638BC
If your GE remote is universal, you should be able to search all of its codes for one that will work with your RCA TV. If you search is unsuccessful, you may have to try another universal remote. Not all remotes contain all codes.
Sep 29, 2014 | Televison & Video
I need the code for ge universal remote rc24993-c to connect to a sony television please
Universal remote allow you to control multiple electronic devices with a single remote. You can use the remote to work your TV,DVD player, cable boxes and other devices from the comfort of couch.Philips is a popular manufacturer of universal remotes.to program a GE remote for SONY TV,you will either need to input the device code or perform a code search
direct entry
first.turn on your TV manually. next.press down and hold set-up on the remote.the red indicator light will stay lit.after that.press the TV device button to let the remote know you wish to program a television then.enter your device four digit codes on the remote..GE list several codes for SONY television including 0002 0006 0007 0018 0107 0114 0310 0312 0502 0601 0704 0719 0803 0806 0810 0901 0911
..if your remote needs 3 digit codes remove only the number zero in the beginning of the codes finally.test the remote to ensure it works.with the turned on,press the channel button and see if the TV responds..if it is work the remote programmed and you are done,if it doesn't work try the different code......
IF THIS SOLUTION HELPS YOU PLEASE DON'T FORGET TO RATE MY ANSWER THANK YOU
Mar 09, 2011 | Televison & Video
Need a remote or tv code
Most universal remotes will work and the code will always come with the remote. There is not one set of universal codes that come with the TV. The codes are remote specific, so if you are looking for a code refer to your remote instructions and manufacturer and not your TV literature. Your best bet to get full functionality is to get a logitec harmony remote. They usually cost a bit more and take more to program but they are the best I have found to absolutely get all the function you could ever get because you can program as many extra buttons as you want. Another option is to call the manufacturer, their number will be listed in the user manual. They can send you the original remote. It may cost somewhere in the range of $15-$50.
Dec 11, 2009 | Televison & Video
Remote code for GE TV M#31gt660
It depends on which universal you are trying to program. There is not a set code for all remotes. Every universal manufacturer has there own set of codes. Thanks for using fixya.
Nov 15, 2009 | GE 31GT660 TV
Want to get the codes to operate the ge universal remote
Call the manufacturer to your tv and ask them for a remote code for that particular universal remote.
Aug 07, 2009 | Olevia LT32HVM 32 in. LCD Television
Universal remote
Codes for Panasonic TV.....171,148,054,170,062,374,381,437,003,070. You can Goggle the programming info...Just ask...How do I program a GE Universal Remote... There are about 7 steps...easy if these codes work....good luck...I have a remote that none of the given codes are working........
Nov 22, 2007 | GE JASRM24912 Remote Control
Universal Remote Code for Dynex 20" TV/DVD
I just bought a 32" dynex lcd and saw that i couldn't program my two $5 ge remotes to work it. From reading in this forum and others I'm not the only one with the problem, I thought I was stuck with only the dynex remote. But the dynex website tells you how to get universal remotes to work,
It tells you to try the codes for Orion, Emerson, Memorex, Sansui, Sylvania, Zenith. The second orion code worked for me. both my ge remotes look and work the same but one uses a four digit code and the other uses a three digit code. I used 0135 on one and 135 on the other. There is a good chance that if you try the codes for the brands dynex lists you will find one that works. The 0135 or 135 might work for most dynex tv's.
If you have a ge remote and haven't programmed it for volume punch through you might try it. It allows the tv volume to be controlled using the ge remote even when it's set to something other than tv.
Nov 04, 2007 | Televison & Video
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
