Question about Kodak EASYSHARE G610 Thermal Printer
Easy share g600 printer will not pick up paper
Printer will not pick up paper. ihave to feed it by hand. Ive faned the paper before i put it in,made sure there was not to much paper in loader,made sure the wheels were clean.
  • Anonymous Feb 14, 2009
    I have the same problem. I'm on my 2nd printer and the problem is the same. Paper won't feed in.
  • can1225 Mar 29, 2009
    The file is sent to the printer and the transfer button blinks and the printer tries to pick up the paper but does not. I hit the ok/print button and it tries to pick up the paper again but with no success.
SOURCE: have kodak easyshare g600 printer dock
Here is how I solved this problem. If you pull out the paper tray, you will notice two small, white, push pins under and to the right of the pinch rollers. Dip a cotton swab in isopropyl alcohol and use the swab to push each pin in and out a few times, thus cleaning the pins and the holes that guide them. Give it all a minute to dry and reinstall the paper tray.
Posted on Dec 23, 2007
Healeyman
  • 1198 Answers
SOURCE: kodak easy share g600--paper doesn't get pick up
Try putting a taller stack of paper in the printer. As they get older, the wheels lose traction. Clean the wheels you can see with a damp Q-tip.
Posted on May 01, 2009
SOURCE: Printer dock does not pick up paper.
I cleaned the wheel as a previous user had advised - I also pushed up the metal catch that sits under the printer and lifts the paper cartridge and it started to print. My replacement printer however didn't respond to this, however at least I have one that works.
For how long it will continue to do so is another question...!
Regards,
D
Posted on Jun 03, 2009
  • 2976 Answers
SOURCE: Paper won't feed into printer
Make sure the paper doesn't have a curve in it. Also, fan the pages to make sure they aren't sticking together. Load shiny side up. Try taking about 10 sheets out
Posted on Jun 29, 2009
SOURCE: Kodak easy share printer dock series 3 faults
got same error, took the clear cover off the paper cartridge and kinda' force fed the paper thru. To my surprise...it worked.
Posted on Jul 06, 2009
The photo paper does not feed into printer. I
Get hold of the photocard and try, with your fingers, to curve the end that goes into the printer first so that it doesnt resist as the machine tries to pick it. Just curve/bend it little upwards, not downwards. Usually this kind of problem is temporal and happens especially when the card is a bit too hard for the machine.
Dec 09, 2009 | Office Equipment & Supplies
My G600 easy share G600 will not pick up the paper to print my pictures
Try to take off the paper tray of the printer dock
Get a damp lint free cloth and clean the rollers on the printer dock
try to print again
Aug 10, 2009 | Kodak Easyshare Printer G600 Thermo...
Kodak Easy Share printer dock will not print pictures
If you have too much paper in it, the paper will stick and you will get a false reading.
Aug 09, 2009 | Kodak Easyshare Printer G600 Thermo...
Easy share G600 says it is out of paper.
***** Check for a paper jam***** if none then >>>>>>unplug the power cord, wait ten seconds plug back in,,,, hit the paper load button
Jul 30, 2009 | Kodak EASYSHARE G610 Thermal Printer
I have an Easy Share printer dock series 3 that has paper loaded
To prevent misfeeds and to make sure your pictures look their best, we recommend that you keep the feed roller clean. IMPORTANT: Unplug the power before cleaning the feed rollers.
  1. Unplug the AC power cord from the power outlet.
  2. Remove the paper tray from the printer, and leave the paper tray door open. IMPORTANT: Do not use cotton or cotton swabs to clean the feed roller.
  3. Lightly moisten a lint-free cloth with water.
  4. Use the moistened cloth to gently wipe clean the surface of the feed roller. Advance the feed roller with your thumb as necessary, and continue cleaning.
  5. Let the feed roller dry fully before plugging the AC power cord back into the power outlet.
  6. Insert the paper tray into the printer, then press the Print button to resume printing.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 26, 2009 | Kodak EASYSHARE Plus Series 3 Thermal...
Kodak easy share g600--paper doesn't get pick up
May 01, 2009 | Office Equipment & Supplies
After you load paper printer says no paper loaded. It catches paper but does not send it through.
YOU HAVE FAN THE PAPER BOTH ENDS LONG WAYS FAN THE PAPER, WIDE OR SIDE OF THE PAPER NEEDS TO BE FANED,
ASSIST THE PAPER INTO THE FEEDER MAKE SURE THERE IN NO FORIEGN OBJECT IN THE FEEDING AREA MAYBE PENCIL OR PEN FELL DOWN THERE,
STICK YOUR HAND BEHIND THE PAPER AND PUSH THE PAPER FORWARD UNTIL PAPER STARTS TO FEED YOU HAVE TO DO EVERY TIME YOU LOAD NEW PAPER UNLESS YOU PLACE NEW PAPER BEFORE IT RUNS OUT OF PAPER, THIS IS A PICKUP ISSUE FOR THE PRINTER,
ROD
Feb 02, 2009 | Canon PIXMA MP460 All-In-One InkJet...
Will not pick up paper
Take a wet cloth and clean the front grabbing roller by rotating roller on the wet cloth. You may have to do several times and after printer has not been used for a while.
Dec 10, 2008 | Kodak Easyshare Printer G600 Thermo...
Printer fails to feed paper for printing
try gently rubbing the take up roller with a damp cloth - let dry and try with no more than fifteen or twenty sheets of paper in the feed tray
Oct 29, 2008 | Kodak Easyshare Printer G600 Thermo...
Have kodak easyshare g600 printer dock
Dec 14, 2007 | Kodak EasyShare Color Photo Printer Dock
Kodak EASYSHARE G610 Thermal Printer Logo
334 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
