Question about Acer Aspire 3610 Notebook
Acer Laptop problem
Hey im not good with computers but i have an acer aspire 3610 notebook and ive been having probelms with it. Latley even though it have plently of dick space it has been very slow and keeps freezing if i open up more than one programme at a time. Also when watching DVD's it will play fine for 20mins or so and then start skipping....after that i just take out the DVD put it back in and then it plays fine again for another 20mins. I have no idea what the problem is or what to do! can anyone help! thank you so much!
  • 2,961 Answers
Re: Acer Laptop problem
What must be happening is there are programmes and services running in the back ground and depending on how much memory you have installed all these things take up memory allocations. The graphics card when running just minimal programmes like word run at 8MB memory but when running games or dvd the card can run at 64MB of memory so take that off 256MB ogf memory if thats what you have fitted, minus the memory your programmes and services take it doesn't leave much. added with a processor speed of around 1.5GHZ it can make the system slow up if doing more than one thing at a time. Also check back to when this started and go to system restore and look to when it roughly started and see if windows did any updates, if so restore to before the update and see if it still happens.
Posted on Apr 20, 2007
0 characters
3 Points
I have an Acer 3610 laptop that wont boot up, im able to get into the setup, but it still wont boot up
From BIOS remove the option for hiding the startup information and write down the messages that you see on the screen.
Feb 28, 2011 | Acer Aspire 3610 Notebook
How do you use your webcam on an acer aspire 5517?
go into start all programs then go to acer chrystal eye webcam. i just found mine on the acer apire 5517 so im assuming all the acers with webcams have pretty much the same folder.
Jan 14, 2010 | Acer Aspire 3610 Notebook
Acer Aspire 1360 + Shut down frequently
is it hot when your laptop shut off ?
if it is, try to clean you cpu fan and heatsink
Apr 23, 2008 | Acer Aspire 3610 Notebook
Acer5520 webcam
download & install new driver from acer,
though it is one of the worst site to get help from
good luck
Mar 10, 2008 | Acer Aspire 3610 Notebook
Acer 3000 not loading
firts put the original harddrives back in place :)
then you need to enter the 3000's bios If I remember right
thats done by pressing f2 or del in a acer. it should tell you what button is correct on the bootup screen.
Then you need to change the boot order to haveing the dvd/cd drive before the harddrive, since right now its booting strate from the harddrive.
Then you should be able to restore the operateing system with the disks that came with the laptop and or from a normal xp or vista cd/dvd.
good luck!
Feb 14, 2008 | Acer Aspire 3000 Notebook
Acer aspire 3610 drivers
go to this link below and download the drivers need for your aspire notebook 3610.
Good Luck, Kindly POST back with your results.
Jan 04, 2008 | PC Laptops
Sound Recorder Help
Computer speakers do not work.
The above solutions should get ya back up to hearing from your speakers again.Good Luck/Please dont for get to Vote, Thank You
Dec 18, 2007 | Compaq Presario 700 470024-192 Notebook
Acer Aspire 3610 Notebook Logo
94 people viewed this question
Top Acer PC Laptops Experts
Brian Sullivan
Brian Sullivan
Henk de Ruiter
Henk de Ruiter
Are you an Acer PC Laptop Expert? Answer questions, earn points and help others
