Question about Toshiba (P000204210) Motherboard
Toshiba L300 145 System Unit Motherboard problem
Toshiba L300 145 after getting water on keybord stoped working. Now makes like 1 click when you power it with cable, and don't have battery inside. Is it dead already ?
  • Anonymous Dec 27, 2008
    The whole laptop is already open and tooken apart. The main board is infront of the hot air blower... Already for like 15 minutes. But this happend like a week ago... And till now it never worked....
    President:
  • 1,179 Answers
I think the water may have damaged it already. You could try opening it up and drying it out. May or may not work but it's worth a try before shelling out $$ for a replacement. Sorry. Hope this helps.
Posted on Dec 27, 2008
Half keys stoped work
the ribbon cable to your keyboard has come loose fron theconnector on your motherboard
Feb 04, 2013 | HP ProBook 4710s Notebook
When i am working on internet then system will be power off before this problam he is infacted some water at the keybord
If water went into laptop while it was on or you turned it on whilst it was still damp then you may have had a minor short which has created a small crack in the solder which only shows itself after the laptop is working for a while and heats up. When it does this it will expand and that breaks the connection. Difficult to locate where this could be. If you were competent enough you could disassemble the laptop and bake the motherboard but I would not advise this unless you absolutely knew what you were doing
Jan 10, 2013 | Toshiba Computers & Internet
I have a LOGITECH X540 5 1 140W one day i played music in the morning and came home from work and it totally stoped working i went through properties to fix it but nothing is working i even pluged it...
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
make sure you have an earth ******** before touching any parts inside your computer
hope this helps
May 28, 2011 | Computers & Internet
Hi I have a Toshiba satellite pro model pc laptop. Unfortunatly by accedent my PC wetted as my kid urinated. my system is not power up till now.. i tried many times but it is dead.. not at all power up.....
1. In this case your motherboard must be fried or power unit on the motherboard.
2. So its better to take to a repair shop or toshiba service center.
3. Motherboard or fried parts have to be replaced.
Mar 27, 2011 | Toshiba Computers & Internet
I have pluged for charging the laptop in 32 amp socket and after some time the laptop stoped working and it is not switching on. can i know what could be the resoan for not working or damge and how...
1. Take the battery out, drain the power out of the laptop, put battery back in place and see if it turns on.
2. If that doesn't fix it, open it up get a measurement unit and see if you have any power on the mother board. If no power, mobo might be gone.
Nov 12, 2010 | Toshiba Satellite Pro L300 Notebook
Wireless logitech S520 keybord not talking
2egoo.com offers products and services of wonderful time value for the people and try and make a large customers. Please feel free to take a look around and contact us in case you have any queries. We have been a manufacturer representative and distributor of compatible consumer electronics Accessories?fitting, especially of laptop computer accessories- Laptop Hinges(Left&Right)~ Screen video cable: Camcorder Battery Charger , power tools batteries and chargers, and other products.To find out more, go to the website Click: www.2egoo.com/ ********Replacment Emachines E625-5192 DC Power Jack******** ********Compaq 241438-001 Hindge for$24.99******** $$$$$$$$$$Toshiba Satellite A200-1VT Power Jack expense $8.91====== ======HP G60-100EM keyboard cost twenty five======
Jul 04, 2010 | Logitech Wireless Access Duo Optical...
Keyboard suddenly didnt work
First make sure battery works fine .
Reattach battery .
Then uninstall wi fi keybord driver.
Then reinstall from disk which come with keybord when you purchase.
Installing driver fix keybord problem .
Let me know if you need further assistance.
Thanks.
Oct 28, 2009 | Belkin F8E206 Keyboard
I connected keybord to my toshiba satellite model ,but some keys like (O,P,....)not writing o or p , its writing numbers
hey man go in control panel-regional and language options-keybords and language-change keybords(and there change u keybord language),If this dosent work try to unistall u keybord drivers and install them again.
Jul 01, 2009 | Computers & Internet
WHEN I START MY COMPUTER KEYBORD AND MOUSE NOT WORKING PROPERLY.
hmmmm maybe you have a motherboard defect.... or try to change your mouse or keyboard with a new or borrow it from your friend then try it... if it has the same problem your motherboard is damaged.. ^^
Feb 03, 2009 | Intel D101GGCL Motherboard
Copier Machine stoped to print and copy
Open the right side door and check the transfer/separation corona unit. It may be a broken corona wire, and make sure corona unit is sitting properly.
Jun 04, 2008 | Toshiba e-Studio 350 Copier
Toshiba (P000204210) Motherboard Logo
1,607 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
