Question about D-Link DWL-7100AP 802.11a, 802.11g/b Wireless Access Point
Dlink dwl 7100ap problem
Hii,
ive had the router for some years now but for the last week have had it unplugged, when ive plugged it in again all it does is make a high pitched squeel noise with nothing happening (no lights and cant connect to it) over the week it was unpluged it hasnt been moved so i doubt any physical damage, ive checked the circut boards which also looks in fine condition have you any advise?
thaanks pete
    Scholar:
  • 67 Answers
If your unit has a reset button this is your first recourse otherwise you would be best to treat yourself to a new router as computer parts and accessories only ever have a limited life span. Then at least you know you will get a few years of trouble free use. I use a Buffalo myself but would steer clear of Netgear (one I had lasted only 4 months). Belkin are also good. D-link as so far as I have heard are so-so at best.
Posted on Dec 27, 2008
I am using DLINK DWL-7100 Wireless AirPremier Access Point in unsecured mode. I cannot reach the logon page to enable security (192.168.0.50). Just keeps timing out.
To secure the router, first you have to access the router through web browser (Internet Explorer) by typing the IP address of your router in the address bar, which is usually 192.168.1.50 (default) The default administrative user name and password (unless you've configured otherwise, the default username is admin and bno password). If you cannot access it wirelessly, try accessing through wired connection. Otherwise, you can simply resetthe router to factory default setting, press and hold the reset button for few seconds (It is at the back of the router near the DC Power Jack). The LEDs will then blink and the routers factory settings wouls be restored.
Please note that after RESETTING THE ROUTER to defaults, ALL SETTINGS WILL BE LOST AND YOU HAVE TO RECONFIGURE IT. Generally, after hard reset you get the connectivity, however, you have to make the connection secure etc.
Please, refer the product guide/manual and make configurations as per the details provided by your Internet Service Provider (ISP).
Feel free to contract me for further assistance
CreativeTECH
Dec 31, 2010 | D-Link AirPremier DWL-7100AP Wireless...
Hi, My d-link dl-604 suddenly stopped working. When I plug it in, only the power led and #4 lights are up. None of the other leds are responding nor the internet is not working as well. Please help. Thanks
The following reset procedure will completely restore the default settings on your D-Linkmag-glass_10x10.gif device including your password. This procedure applies to the DI-514, DI-524, DI-604, DI-614+, DI-624, DI-754, DI-764, DI-774, DI-784, DI-804V, DWL-700AP, DWL-800AP+, DWL-900AP+, DWL-1000AP+, DWL-2000AP, DWL-2100AP, DWL-6000AP, DWL-7000AP, and DWL-7100AP.
Step 1 Locate the reset pinhole on the back of the unit.
Step 2 With the unit powered on, press and hold the Reset button.
Step 3 Hold the Reset button for about 10 seconds.
Step 4 Release the Reset button.
Step 5 The unit will reboot. Allow 20-30 seconds before reconnecting.
Step 6 The device is now at factory defaults.
Note: Do not recycle power during the reset procedure.
The default user name for most D-Link devices is admin and the password is left blank.
Hope this helps! Give me thumbs please!
Aug 23, 2010 | D-Link DI-604 4-Port Cable/DSL Router...
Setup is unable to detect card however windows
You aren't very descriptive. Either way. I'm assuming when you say Setup, you are referring to the driver installation setup. Delete/uninstall the driver. Unplug the adapter. Now, start the setup. When the installation goes along, eventually it'll ask for you to insert the card, thats when you insert it. It should then work, if you finish the setup. If thats not the issue. Heres a possibility. You are running windows Vista, or running Windows Vista 64 bit, or maybe XP 64 bit. Either way, you are likely using a 32 bit driver, on a 64 bit machine. Or vise versa. If not then you could be using a vista driver on an XP machine and the XP machine doesn't know what to do with it. I suggest going to dlinks website. There are 3 versions of this wireless card, and that also could be the issue. The first one they released is here http://support.dlink.com/products/view.asp?productid=DWL-G630 and that only has drivers for XP and 2000. http://support.dlink.com/products/view.asp?productid=DWL-G630_revB rev B. Also only XP and 2000. http://support.dlink.com/products/view.asp?productid=DWL-G630_revC rev C. also again XP and 2000 BUT includes a Vista 32 bit driver. I hope i helped. Not bad for free...
Jun 09, 2009 | D-Link AirPlus DWL-G630 802.11g/b Wireless...
Why cant i connect my dlink
Forget the D-Link drivers!!! I suffered with this same DWL-G630 issue for two years, trying different settings, reloading drivers, all with no solution. My card kept dropping it's connection, or wouldn't connect at all until I removed then replaced the card. Finally, I read on another forum this card uses the same chipset as an ASUS card, and to try the ASUS drivers. I downloaded and manually installed the drivers from here:
ftp://ftp.asus.com.tw/pub/ASUS/lan/wifi-g/wifi-g.zip
Unzip it, but DON'T run the setup.exe file, because it will try to install the ASUS program. If you open the unzipped folder you will find another folder called "Drivers". Just use your Network Settings (from your Control Panels) to manually update the driver of your DLink card, and navigate to the Drivers folder just mentioned. Reboot -- you'll probably have to reconnect to your access point/router one last time, but that's it! It's good as gold after that.
I was used to losing connections 5-8 times PER DAY (I'm 15 feet from the router!) and now I've been connected non-stop for two weeks and counting!!
Mar 20, 2009 | D-Link AirPlus DWL-G630 802.11g/b Wireless...
Dlink wireless router software download
Click the link below for D-Link Downloads
http://www.dlink.com.au/tech/Download/download.aspx?product=DSL-2750B
or try the link below
Click or copy the link to D-Link Support and past to your address bar
After page opens type DSL in the first box on left
Then in second box scroll down to your model number
May 23, 2008 | Acer D-Link 2.4GHz Wireless Router 802.11b...
D-link router
I believe it is a setting on the router.. There should be a timeout setting that needs to be altered. I cant tell you which setting, but this was happening to my network as well.. I used to be a Dlink fan, but have since moved to Linksys.. If buying a new router for you is an option, go for the Linksys WRT54G/GL/GS series. Sorry I cant be of much more help.
Dec 12, 2007 | D-Link DI-514 / DWL-520 Kit...
Forgot my password
The following reset procedure will completely restore the default settings on your D-Link device including your password. This procedure applies to the DI-514, DI-524, DI-604, DI-614+, DI-624, DI-624M, DI-624S, DI-754, DI-764, DI-774, DI-784, DI-804V, DWL-700AP, DWL-800AP+, DWL-900AP+, DWL-1000AP+, DWL-2000AP, DWL-2100AP, DWL-6000AP, DWL-7000AP, and DWL-7100AP. Step 1 Locate the reset pinhole on the back of the unit. Step 2 With the unit powered on, press and hold the Reset button. Step 3 Hold the Reset button for about 10 seconds. Step 4 Release the Reset button. Step 5 The unit will reboot. Allow 20-30 seconds before reconnecting. Step 6 The device is now at factory defaults. Note: Do not recycle power during the reset procedure. The default user name for most D-Link devices is admin and the password is left blank.
Feb 16, 2006 | D-Link AirPro DI-764 Wireless Router
Forgot my password
Feb 16, 2006 | D-Link AirPlus DI-614+ Wireless Router
D-Link DWL-7100AP 802.11a, 802.11g/b Wireless Access Point Logo
335 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
