Question about Mitsubishi WS-55315 55" Rear Projection HDTV-Ready Television
Protector glass on a mitsubishi 55in hdtv 1080 #ws-55315
Hello, I have a mitsubishi 55in hdtv 1080 #ws-55315 it has like a protector glass front that i broke and i need to get it replaced do you know what that part of the tv is called and where i can find it at thanks so much
  • 4 more comments
  • ikis Jan 26, 2009
    I have this TV as well. The front screen is cracked because some **** (me) let something knock against it. Dah!
    I am not too keen on leaving the screen off and have the replacement screen in hand. Do you, ROLCHP know the procedure to do this. I am legally blind but capable of doing this but want to be sure of the procedure before I dig in.
    I appreciate any help .
  • Dowwie Jan 31, 2009
    I have this same problem. Can someone please send me the procedure to replace the front protective screen?
  • synakowlou Mar 04, 2009
    just tell me how to remove the front screen without cracking it.
  • jeffkrall Mar 23, 2009
    Can anyone on here tell me where to order a new protective screen. If we broke it once, it could happen again so I kind of want to replace it. Thanks.
  • bstrobe Apr 16, 2009
    How do you take the protective screen off without bending or breaking the decorative molding on the outside of the tv?
  • Dowwie May 11, 2010
    What was the procedure for removing the front glass?
I have the same tv and I took my clear shield off and never put it back on.  The picture is much better without it as it will reflect light and objects in the room making it difficult to see the pic clearly.  I was told by a service tech that the primary purpose of the glass or shield is to prevent damage to the screen from objects, water etc.  If you have no small children in the home you can enjoy a better pic.
Posted on Jan 20, 2009
MITSUBISHI WS-55315 WON'T TURN ON WITH REMOTE OR START BUTTON
do the self check and find the error code if set shows power and then goes total dead shortly after.
May 02, 2012 | Mitsubishi WS-55513 55" Rear Projection...
I have a mitsubishi WS-55315 parental lock is on.and i have no original remote is there a fix
You are going to have to have a Mitsubishi remote to do it--with that contact Mitsubishi and ask for the 4 digit code to enter to do the hard reset of the set--puts everything back to factory original when set was new.
Mar 14, 2012 | Mitsubishi WS-55315 55" Rear Projection...
Mitsubishi hdtv 1080 ws-a65 screen broke need replacement
there are 2 functionality screens and 1 screen protector (on some)
front screen = lenticular
back screen = fresnel
very front screen = screen protector (you can replace w plexiglass)
the fresnel and lenticular are very specific.. contact your local repair center for a new one. you can cut them from old screens but have to do just right (fresnel is a lens type - pic will be distorted if off center)
maybe find a old junker tv to pull screens from because new ones are about $100 a piece
Jun 03, 2010 | Mitsubishi WS-65311 65" Rear Projection...
Ws-55315, screen turned to fuzz
If it was the lamp there should be nothing. press the menu button if the menu does not come up the issue is with the tv. If the menu does come up try a second source a dvd player or game system. If the issue is only with the original source than the original source needs to be replaced.
May 05, 2010 | Mitsubishi WS-55315 55" Rear Projection...
Mitsubishi 65413 loses convergence calibration
That model Mitsu doesn't accept 1080p input or 720 p input.You would need to chnge the output resolution on your bd player to correct this.
Dec 01, 2009 | Mitsubishi WS-55315 55" Rear Projection...
I have a mitsubishi ws 55315 and i need to program my remote to the att uverse motorola cable box.
hi i have a couple of codes here for your mitsubishi tv just try them 0005 0151 0051 0004 0009 0254 0022 0141 0180. hope this would help! goodluck!
Sep 22, 2009 | Mitsubishi WS-55315 55" Rear Projection...
HD UPGRADE MITSUBISHI WS-55315
Check your manual, I have the same set and you need a
WD 5000 HD upgrade panel, I believe.
This TV is HD upgradeable, it is NOT HD ready, like you have
been told by other responder......
Jan 22, 2009 | Mitsubishi WS-55315 55" Rear Projection...
Mitsubishi Mod # WS-55315
On this model the timer led blinks when the tv is off if you have the timer set to turn it on. You can get the manual here.
Mar 13, 2008 | Mitsubishi WS-55315 55" Rear Projection...
How do I remove the outer protective screen on my Mitsubishi WS-55315?
There are trim pieces around the edges that can be removed by sliding a knife underneath and lightly prying. They should remove fairly easily, don't force them as they may break. Use the knife on the cabinet side and pry toward the center of the screen.
The tear on the inner screen may be best left as is.
lexan would be better than plexi as it is tougher, but try to get anti-glare if possible. Anti-glare plexi would be better than regular lexan.
Feb 17, 2008 | Mitsubishi WS-55315 55" Rear Projection...
Mitsubishi WS-55315 55" Rear Projection HDTV-Ready Television Logo
351 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
