I do have problem with NV-GS60 camcorder when recording a seen i can see it clear in the lcd display, but trying to play back the seen it shows thick horizontal lines on lcd display. any idea of what been wrong with it?? thanks
Clean the heads(use the specified cleaning tape sparingly).
Change tape. Using Panasonic video tape? It sounds like no. You might get by with Sony... Try Panasonic.
The tapes are different thickness, durability and therefore suitability for cameras. Try to get ME -type tape( metal evaporated) instead of MP( metal particle) as the particles tend to flake off more readily. The blue often means no signal(video) was recorded in that space(on the tape). Let me know it it helps.
vac8
Vac8,
thanks for the reply. I already cleaned the video head but still the same. i'm just wondering if it's a mechanical problem, for i have fix 1 before but different symptoms.The previous problem i have with the same model is when you record a seen, you can see it clear in the LCD display. but once you've played the recorded seen , only half of the display shows the recorded video and the other half is black blank.I check the mechanism and found out that one of the tape guide is missaligned. Now the problem i'm dealing with is when i record a seen and played it. it will display the recorded video but it also produce thick horizontal lines in it.
"Panasonic NV-GS60 with horizontal lines appear on screen" I have New Solution
