Question about Audiovox 1187111pl Universal Fit Video Console Trim Ring for Vod1021 / Vod1022 / Vod1023 Lcd Monitor Pewter
Dvd is stuck in the player- eject button not working
Dvd is stuck in the player and eject button not working
  • 240cpa May 11, 2010
    Check in the back of the unit. Sometimes there is either a reset switch or a release switch. If worse comes to worst, unplug the unit and take the outer case off and then pull the CD out.
    New Friend:
I had this problem and the solution was simple. The unit had been very tightly secured to the roof of our vehicle. Loosening the bolts holding the unit to the ceiling allowed the unit to flex slightly I believe and the eject has worked since.
Posted on Dec 27, 2012
    Problem Solver:
Have you tried to see if there is a reset button on your unit? if so then hold the reset button down for a few seconds and then try to eject the cd if that don't work then you might have to get the unit repaired also if you cross the yellow wire with the red wire behind your unit where it connects to your vehicle it will automaticly eject your cd when you turn it on.
Posted on Jan 09, 2009
19 in. Coby TFT LCD TV with side-loading DVD player. How do I remove a stuck DVD?
Hi Joanne, The eject button ( micro switch ) on the TV is defective. Please get it changed and the stuck DVD will come out.
May 28, 2015 | Coby Televison & Video
DVD stuck in my Panasonic DMR-E30
Hi Rock.
I had the same problem like this on my machine. The best way to fix it is to turn the machine off completely and hold on the eject button then turn the power on. You want the first thing the player does is to eject the disk without trying to read it first.
I hope it works let me know if it doesn't and i'll try and recreate the problem on my player and see what i can do to get the disk out.
The last resort is to manually take the disk out but lets cross that bridge if my suggestion above doesn't work.
Feb 18, 2008 | Panasonic DMR-E30 DVD Recorder
Eject button is stuck
Get in touch with the manufacturer's product support and ask them.
May 07, 2015 | Televison & Video
My dvd player is stuck on one dvd and wont let me eject, change disc, or even stop the current dvd. display reads "locked" whenever i press any buttons. can only turn on and off the device.
Hi, For some reason the disk will not play. You push the eject button over and over again, but the disk slot will not open. Here's one solution...
* 1 Turn off the DVD player. Wait a few minutes, turn the DVD player back on, and
then press the "eject" button. If this does not work, turn it off and unplug
the DVD player...while you keep pushing EJECT button plug the DVD and turn it on (your hand still on the eject..) is should come out..
* 2 ..if it does not eject , unplug the DVD player again, Remove the screws off DVD on the sides and take off the DVD casing.
* 3 Look for the DVD holder inside the DVD player. This device holds the DVD in
place while the DVD player reads the disk.
* 4 Push the stuck DVD disk toward the front of the DVD player until the DVD
ejects. Remember the DVD player is not on and some force ( gentle ! ) must be applied.
* 5 While it is open,plug it on and place a DVD disc just to see if mechanism works properly..
* 6 Replace the casing and the screws. Plug the player in and turn it on. Put
another DVD in to test whether the player is finally working ..
Hope this helps!..
Take care and please
Remember to rate/vote and give us 4 Thumbs Up
to continue f
or Helping out the Community :)
Jul 09, 2011 | Televison & Video
I have 2006 honda odyssey. i cannot use dvd system, because i cannot eject dvd. how can i eject dvd?
To eject the dvd from the dvd player you have to push the eject button on the dvd player, if the dvd is stuck inside the dvd player you have to get it checked by a service technician
Feb 27, 2010 | 2006 Honda Odyssey
DVD will not Eject
answer - had the same issue turned out to be 3 dvds in it, Remove the 4 screws holding the dvd player to the roof. wire harness will hold it up. There is an fm transmitter on top held on by three screws. remove the little screws and push the transmitter to the side. you winn now see the stuck dvds. push the extras out with a small screw driver. once they are out the eject button will eject the last dvd.
just worked for me hope this helps.
Jul 04, 2009 | Jensen 8.5'' Overhead DVD Player Package...
Audiovox 1187111pl Universal Fit Video Console Trim Ring for Vod1021 / Vod1022 / Vod1023 Lcd Monitor Pewter Logo
695 people viewed this question
Top Audiovox Car Audio & Video Experts
xxxxxx xxx
Jaime Hernandez
Are you an Audiovox Car Audio and Video Expert? Answer questions, earn points and help others
