Question about Memorex MVD2050-BLK DVD Player
Memorex MVD2050 problem with buttons on machine
The buttons on the player itself work erratically. Power off/on and disc tray open/close work only when there is no disc. Play does not work at all. Returned one player to RadioShack today, the replacement player has the same problem. Corresponding buttons on remote work fine.
  • thodgdon Jan 12, 2009
    petraman7 is kinda right. The machine has an inherent problem. If you use the HDMI cable to connect it to, presumably any TV (the store tried several) this problem arises when the TV is turned on. Use the left-right-video cable and everything works fine. I'm very surprised I found no mention of this on any other forums! So, if you're really looking forward to the upconverting feature of this inexpensive machine, you've got a trade-off to consider. Use the remote for all the functions, including disc eject or turn off the TV to get the machine's buttons to work.
    Genius:
  • 1,175 Answers
Hi..
No offense but Memorex is junk.
Get you money back and try walmart or someone else
Posted on Jan 12, 2009
My memorex dvd/cd player only plays black and white dvds
see this causes: and fix it . God bless you
  1. Disc loaded upside-down.
  2. Transportation lock engaged.
  3. Dirty, scratched, or defective disc.
  4. Dirty or damaged objective lens.
  5. Loading (mechanical) not completed reliably.
  6. Damaged lens suspension or damaged lens cover preventing free movement.
  7. Dirt, gummed up lubrication, or damage in sled drive mechanism.
  8. Dirty/defective limit switch or sensor.
  9. Defective spindle motor.
  10. Spindle table height incorrectly set.
  11. Bad component in optical pickup.
  12. Cracks in ribbon cable to optical pickup.
  13. Need to adjust servo (or less likely, optical) alignment.
  14. Faulty power supply, electronics, or control logic.
  15. Bad connections including missing/erratic optical deck shield.
  16. External interference.
Sep 23, 2012 | Memorex MVD2050-BLK DVD Player
I forgot the password to our dvd player. It is a Memorex MVD 2037 DVD player. Any suggestions?
The default password is 1234.
or..
Memorex MVD 2037 & Memorex MVD 2051
1. Turn on the Player.
2. Press the Open / Close button, (keep tray open)
3. Press the Clear button.
4. Press 1,3,6,9.
5. Press the Region you want, 0 for Region free.1 for Region 1 and so on
6. Turn your player off and then back on.
N.B if the hack does not work you may find you have to ommit step 3 and try again.so the hack will be
1.Turn on the Player
2.Press the Open / Close button , (keep tray open)
3.Press 1,3,6,9
4.Press the button for the Region you want, 0 for Region free, 1 for Region 1 and so on.
5.Turn your player off and then back on.
Alex
Feb 01, 2011 | Memorex MVD2037
MVD2050 will not turn on. We have a DVD stuck in it. We turned the power off and back on after 60 minutes but nothing happens.
Hello K4, hi you can manually get the disk out, but you need to remove the cover. As for the power thing, you have a power supply problem, would you like to service it yourself or call a technician, If you will service it yourself, this are the things you should check:
  1. fuse
  2. open wirings
  3. shorted or over heating rectifier diodes and voltage regulator
  4. bulging filter capacitors
  5. Switching regulator IC, check for the output pulse using a scope.
  6. replace the bad parts, then test.
Apr 28, 2010 | Memorex MVD2050-BLK DVD Player
SCREEN IS STUCK ON HELLO AND WILL NOT OPEN
On my DVD player, the cover on the disk tray was setting too high. I removed the cover, cleaned the glue off and reset it. This time it was flush with the tray. It now opens and closes just fine.
Another possible solution is to unplug and replug-in player. You still may have to do this after using my first solution.
Note: My DVD player also starts showing "hello"
Note: This solution was also listed under
"My DVD Wont Open" (sic)
Aug 14, 2009 | Memorex MVD2050-BLK DVD Player
Installed memorex mvd2042 dvd player, receive message "root"
Aha. I just found a solution. Press DVD menu on the lower left.
Dec 29, 2008 | Memorex MVD2042 DVD Player
MVD2050 remote control
If you point the remote at a video camera and press any button on the remote while the camera is recording you should see the emitter flashing on playback. This will confirm that the remote has indeed failed or working. I did this and found the remote working... Now on to the player.
Sep 02, 2008 | Memorex MVD2050-BLK DVD Player
MEMOREX MVD2040 UNLOCK CODE
This is all I could find ..... Memorex DVD-2000 C/P / MVD-2020 / MVD-2022 / MVD-2027 / MVD-2027 A / MVD-2028 / MVD-2029 / MVD-2030 / MVD-2037 / MVD-2051
  1. Open the disc tray
  2. Press CLEAR
  3. Press 1, 3, 6, 9
  4. Enter region (0 = multi-region)
  5. Close the disc tray
  6. Turn the player off
Memorex MVD-2042
  1. Press OPEN/CLOSE
  2. Press 9, 7, 3, 5 (or 1, 3, 6, 9 for the "suffix B, C, D" model)
  3. The setup menu will appear
  4. Press RIGHT to move the cursor to highlight the regions
  5. Select region using UP/DOWN (0 = multi-region)
  6. Press ENTER
    (or try the instruction for MVD-2020 above)
Memorex MVD-P1072
  1. Turn on the player (without a disc inserted)
  2. Press SETUP
  3. Press 9, 2, 1, 0
  4. Select region (0 = multi-region)
Jan 16, 2008 | Memorex MVD2040 DVD Player
Memorex MVD2050-BLK DVD Player Logo
135 people viewed this question
Top Memorex Televison & Video Experts
 Grubhead
Grubhead
Are you a Memorex Televison and Video Expert? Answer questions, earn points and help others
