Question about Kenmore 22422 Top Load Washer
Clicking Sound / Kenmore Elite Catalyst
Once we start the washer the pre water cycle will begin and the washer will fill with water. Once it's supposed to move to the first cycle all we hear is a clicking sound. From the back of the washer it appears to be coming from the bottom left of the washer.
    Problem Solver:
  • 7 Answers
Sounds like ur coupler is bad easy fix 4 dollar part
Posted on Jan 07, 2009
Kenmore elite he5t front loading washer door locks, unlocks, then locks again before beginning cycle
This is aself test procedure on the door locking mechanism . You will also hear a click, the drum will make a partial turn,and the door will unlock berore locking again. Once the door has locked a second time the washer will begin tumbling and adding water. The sensing process will continue until the correct amount of water is added to the load.
Feb 12, 2013 | Kenmore Elite HE5t Washer
KENMORE ELITE WITH CATALYST FILLED WITH WATER AND WILL NOT DRAIN AND SPIN
REPLACE THE DOOR SWITCH . IF THAT DOES NOT WORK REPLACE OR CLEAN THE DRAIN PUMP..
Apr 25, 2017 | Kenmore Washing Machines
My washer begins the cycle and than stops and does not unlock when i stop it
Possible that fault is connected with the controller unit. The door is not released even after the cycle hass completed and so there can be some delay in releasing the same. You can try and see if the connections from the controller unit is intact.Also make sure the door locks are free.
Check this link for some clues: washer door lock.
Jun 26, 2012 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore catalyst elite washer fills but does not
the reset is to unplug the washer for 5 minutes, if that doesn't reset it u may have a defective motor controller circuit board
Aug 02, 2010 | Kenmore Elite HE4 Electric Dryer
CANT DRAIN OR SPIN WATER OUT OF MY WASHER
Set it toward the end of any cycle - it will sense the water level and pump it out before moving on.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 26, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore Elite HE3 fills but won't spin
do you hear any sound while stops??
like ticking sounds?
Jul 15, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite Calypso washer won't fill with water!
i assume that the warer is turn on at the warer valves if so then do you have voltage at the water valve if not then water pressure switch could be bad or main control board could be bad
Apr 24, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE3 washer
set the washer to fill. open the lid and depress the lid switch. might be in the rear of the cover or on the side. watch to see where the water level comes to. once the tub is filled, the water height switch operates the timer motor for the different cycles.
Sep 10, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore 22422 Top Load Washer Logo
196 people viewed this question
Sal De GO PATS
fordexpert
Ed Mac
