Question about Kenmore 23822 Top Load Washer
Kenmore Washer 110.26912690 series 90
The washer fills and agitates fine but won't drain or spin
in wash or rinse cycle.
  • norm_swn Dec 27, 2008
    Thank you for your quick response even through this holiday season!
  • Anonymous Mar 29, 2014
    Won't wash, spin or agitate
  • 145 Answers
Hi Norm. Welcome to FixYa.
The first thing to check with the kind of symptoms your machine exhibits is the operation of the lid switch. Make sure that the pin/plunger on the lid itself has not broken off, and check the actuator lever on the switch itself. It is REALLY common on your model for the actuator arm to break off or crack, and this will cause no spin/no pump problems. Your machine is built by Whirlpool and the part number for the switch assembly is a 3849238. You can get it at any local whirlpool parts center in your area.
I hope you find this info helpful and thank you for allowing us to serve you.
Happy New Year from the FixYa crew!
Posted on Dec 27, 2008
Tip
Washing Machines will not rinse or spin
If the water won't drain out of your washing machine, either something is stuck in the drain hose or pump, or the pump is broken. Both fixes are simple if you're even just a little bit handy with tools. We're showing the repair on a Maytag washing machine.
What is wrong with a washer that does not spin?
If your washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. (Note: Direct-drivewashing machines do not have belts.) To diagnose the problem, do the following: 1Check the washing machine's spin cycle.
How to Drain Washing Machine That Won Drain Family Handyman
Washer Doesnt Agitate or Spin
Error codes in front load washers
Washing Machine Not Rinsing How To Fix
My washing machine stops at Rinse Does not DRAIN or SPIN
What causes a washing machine not to drain and spin?
If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing.
SOLVED Why won my washer spin or drain Kenmore 110 Series Washing Machine
Maytag Washing Machines will not rinse or spin Google Search
on Dec 12, 2017 | Washing Machines
Kenmore 90 plus series washer won't spin, barely agitates, will drain - but makes loud noise
It sounds like the transmission is done. Can't pinpoint what it is exactly, but I would start there.
Aug 21, 2012 | Kenmore Washing Machines
Kenmore 90 Series Heavy Duty Washer - Agitator doesnt spin
THIS IS A TYPICLE PROBLEM . BETWEEN THE MOTOR & THE TRANSMISSION THERE IS A COLLECTOR ASSEMBY (THREE PIECE
SET) REAL EASY TO GET TOO EASY TO FIX . ALSO COST EFFICENT
Sep 21, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 90 series washer will get stuck in between cycles
Sounds like the timer has failed. It's a common problem.
Part number 8545379, $83.69 from SearsPartsDirect.com
Feb 04, 2009 | Kenmore 24032\24036 Top Load Washer
My Kenmore Washer Model 100, 90 series fills and agitates but
most common solution is to replace the lid switch. (the machine thinks the lid is still open)
Dec 26, 2008 | Kenmore 23822 Top Load Washer
Kenmore stack washer and dryer
gabehart....sounds like belt is slipping. Replace it. The water pump is on a separate smaller motor so is not affected by the agitator/spin motor.
Jun 04, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 90 series that wont agitate or spin
Could be the door switch, do you hear a clicking sound when you close the lid?
Does the motor hum at all in drain/spin?
Mar 12, 2008 | Kenmore 45981 Washer
98702 Washer Drain/Spin Dead.
My Kenmore 98702 washer Fills and agitates as expected but stops at the end of cycle failing to drain or spin
Dec 05, 2007 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 23822 Top Load Washer Logo
546 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
