Question about Maxtor Hard Drive
Old gateway computer
6gb drive set drive as slave but only 1.84gb is showing
  • 3 Answers
Some hard drives had a jumper setting to show a lower capacity so it could be recognized by older BIOS implementations are you sure you set it as slave and didnt maybe set the cap limit jumper instead?
Just a thought.
Posted on Jan 03, 2009
Shows that speakers are not plugged in and there is no sound. What is the problem?
You may be able to access the ability to change audio settings through the control panel. There are choices that allow for choosing externally attached speakers. If the system does not know to send the audio signals to those speakers, then no sound will come out.
Feb 18, 2014 | Gateway DX4860-UR14P Desktop Computer;...
How can I attach a Samsung hard disk HD080HJ/P to a Dell Optiplex 755 Core 2 Duo E4400 PC computer? There seems to be no master/slave settings on the hard drive.
Newer sata drives do not rely on the master/slave settings that old IDE drives used. Remove the old drive from the bad computer and plug it into an available slot in the new computer. Boot the new computer. Under My Computer/Computer the second drive will show up with the next letter available. Alternately you can buy an external hard drive dock that connects via usb and use that to transfer your files.
Dec 01, 2012 | Samsung (HD080HJ/P) 80 GB SATA Hard Drive
How do you transfer hard drive from old comp. to new?
For just the data, get an ide to usb converter and connect it to the new computer, and just drag and drop.
You cant move an entire hard drive to a new computer because of driver issues, but you can use windows built in files and settings transfer utility.
IDE to USB: http://www.newegg.com/Product/Product.aspx?Item=N82E16812232002
Dec 30, 2009 | Gateway 700 XL PC Desktop
Take Three: I have an older Maxtor Hard DriveTake Two: I have an older Maxtor Hard Drive (Model 90645D3). I need to transfer some files from it (Win98SE) to new hard drive (WinXP Pro). I asked earlier and...
Jumper off will set the drive to slave. If you can connect both drives to the same ribbon cable with the master on the end & the slave to the second connector. Look at your bios as win is booting up to see if shows the drive as slave, you will not be able to copy windows as a operating system off of the drive, but should be able to copy files.
Good luck on your endevors.
Lee
Nov 12, 2009 | Maxtor Hard Drive
Connect it on hardisk enclosure then removed all pins
then connect it usb this serves as an usb flashdisk
How to Install hard drive for gateway E 4300
rachellem775, before you install the hard drive into your computer.. you need to check the setting on the hard drive that you're going to install.. on the hard drive itself it has a sticker with the settings, you need to make the 2nd hard drive that you're going to install as a SLAVE drive.. you can check that on the sticker.. after that, you can connect the cables to the hard drive next to the main hard drive.. that would make the old hard drive as the main drive and your new harddrive as the slave drive.. you can interchange the settings, check the sticker on your hard drive.. all hard drive have that setting information..
Sep 24, 2009 | Gateway E-4300 PC Desktop
How do i transfer data from windows 98 formatted drives 2 xp ones
Set up your old drive as a slave and copy the data. Good luck.
Jun 19, 2009 | Computers & Internet
Old Hard Drive Installation as 2nd Drive
First check your boot sequences. If you want to get it to boot from the defuct PCs HDD you will need to see which is booting first. Bios will remember the actual hard ware by serial etc, not by which is master and slave.
If you just want to run the programs off that drive, then are you running windows?
check out the computer management tools (found in the administrator tools section of the control panel) and there you should be able to use disk management to see what drives are there.
Here you can change drive letters and will be able to see if the drives are being picked up by windows
Jun 06, 2008 | Computers & Internet
Slave Drive not recog in my computer but it is disk management with no drive letter
A quick thing to try Is
remove the 80gb from ide cable and power plug and set the 20gb back as master.
boot into windows from 20gb 1 time ,
then shut down hook the 20gb as a slave and the 80 back up as master
Allow windows to find new hardware , "watch closely down by clock ". It will tell you when windows has finished and will say you might need to reboot before new hardware will work properly
After rebooting Both should show inside My computer
Good Luck I hope this helps
Nov 14, 2007 | Quantum Fireball Lct20 (QML20000LD-A) 20...
La Cie porsche drive not showing up on my computer
is the drive set on slave or master or cable select if this is the case then chane jumper setting toi master if booting with it on secondary ide but if on first ide then slave and if you have got files on these drives move them off then goto disk manager and delet partition then create new partion and sormat drive then set active in manager properties now reboot machine then open my computer to find the new drive hey presto working hdd
Mar 08, 2007 | LaCie (300803) 60 GB Hard Drive
Maxtor Hard Drive Logo
67 people viewed this question
Top Maxtor Computers & Internet Experts
Computer Links
Phillip Whisenant
Phillip Whisenant
Alun Cox
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
