Question about Acer Aspire 5500 5570-2609 Laptop
Acer startup on startup my acer aspire (just bought it today) has the bar across the bottom, showing clean up in process, it seems to be stuck on 12/12 please wait. been like that for hours. there wasnt a small leatlet showing the easy startup procedure in the box although the main booklet keeps refering to it.
Ok I bought more ram for My Aspire T180 pc and it seems to have slowed it down any ideas?
- check your task manager if you have a lot of processes running
- to lessen it down, if your using windows 7 type msconfig on start search
- disable startup applications that you do not use and restart the system
- also check if you have two anti virus running on your PC
Jul 21, 2011 | Acer Aspire™ T180 PC Desktop
Hi, when I turn on the Acer Aspire 5920, the acer screen comes on, the bar across the bottom moves, then it goes to a blank dark screen with a blinking cursor. I have tried turning off and turning on and...
Check if your hard rive indicator light is flashing (has disc shape icon or can shape icon next to it). If it is then put in your windows disc and do a startup repair. Make sure it is booting from the disc drive first. if it isnt flashing then you may have a dead hard drive. Try taking the hard drive out and putting it back in.
Mar 19, 2011 | Acer Aspire 5920-6727 Notebook
How can i getthe bios for may acer aspire one series model zg5
Things You'll Need:
  • Acer Aspire laptop
  1. 1
    Click the "Start" button found at the bottom left hand side of your desktop. Select "Turn Off Computer" in the "Start" menu options.
  2. 2
    Click "Restart" in the "Turn Off Computer" dialog box to reboot your computer.
  3. 3
    Watch your computer's reboot display closely. Press "F2" when you see the system keys display at the bottom of the screen, just before the Windows splash screen appears, to access the BIOS panel.
  4. 4
    Make any needed changes in the BIOS and hit the "F10" key to save your changes and exit the BIOS. Your computer will complete the startup process and launch Windows.
Read more: How to Access an Acer Aspire BIOS ' eHow.com http://www.ehow.com/how_5809235_access-acer-aspire-bios.html#ixzz1E2WkwLWf
Feb 15, 2011 | Acer Aspire One PC Notebook
My laptop sometimes gets stucked. i mean everything is frozen what to do?
1.first you do one thing diasble the all start up process(run-msconfig-startup-diasble all)
2.between the 2 or 3 days clean the temporary and prefetch file also.
3.otherwise simply create the restore option yourself by start-program-accessoriess-systemtool-restore
Nov 17, 2010 | Acer Aspire 5315 Notebook
My acer aspire battery
first, you must release your harddisc drive. and see what is happen for next minutes, after you insert that batteray and plug in your adaptor, to your laptop. See indicator lamp, blinking = still charging into baterai. Light ON = full charging. And charging process, see your laptop, what did you press any button for charging batteray?
If you still press any button, clean all hardware inside of bottom case and upper case.
Sometimes dirty can disturb that process.
Sep 07, 2009 | Acer Aspire 5100-5022 Notebook
Startup Repair Problem
GoTo:
All Programs > Accessories > System Tools > Schedule Tasks
Then...
1. Right Click on Startup Repair. Click Properties.
2. Deselect "Enable".(It is given at the bottom of the properties dialog box).
Aug 23, 2009 | Acer Aspire 7720 Notebook
Acer Aspire blank screen
yes its a virus that's blocking explorer
a complete clean xp installation is needed to fix this problem.
rate plz
Mar 09, 2009 | Acer Aspire 5315 Notebook
Acer Aspire 5610 boot issue
The Video Chip or VIdeo board was faulty, you need replaced motherboard or video board 9if it has), unless you can find components level repair tech near you.
Nov 27, 2008 | Acer Aspire 5610-4648 Notebook
Acer comp
Reboot the computer and during startup start pressing the F8 key until the boot menu appears. Then select "Last Known Good Configuration". The PC will reboot on it's own and hopefully be fixed. Hope this works for ya.
Sep 05, 2008 | Acer Aspire 5100 Notebook
Acer Aspire 5100 will not start right
It seems your hard drive has corupted.
This sucks, all you have to do is push ALT F10 and then go through the reseting menu, you will loose everything on there though except the original data.
Jun 24, 2008 | Acer Aspire 5100-5033 Notebook
Acer Aspire 5500 5570-2609 Laptop Logo
174 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
