Question about Panasonic PT-51G44 51" Rear Projection Television
Dark screen screen dark even with brightness turn up to the max
  • Anonymous Jan 13, 2009
    my laptop screen is too shadow i can hardly see the words an images
    Problem Solver:
  • 5 Answers
You must adjust the blue and green located in the front of the tv.
Posted on Jan 25, 2009
4 Suggested Answers
techman
  • 3130 Answers
SOURCE: brightness
Yes there is, you can very carefully take off the back of front speaker grill and the wood cover behind this. There you will see several controls I think six total, three on the top and three right below it, you want to turn up whats called the three screen controls for the red blue and green but you will need a B & W picture on the TV so you can balance the greay scale. if you do not balance the grey scale the TV will not look good. if you do not think you can do this adjustment properly, please play it safe and call in a tech to do these adjustment for you. Good Luck
Posted on Mar 23, 2007
  • 556 Answers
SOURCE: tv light too dark- LG -rt 44sz21rb
lamp is probably going out
Posted on Aug 14, 2009
ladywinn
  • 5138 Answers
SOURCE: Samsung HLS5086WX-XAA after 1 years it's showing dark
Light Engine or the DMD board 1-800-638-3328
Posted on Jan 14, 2010
Dim screen acer 5100-3019
Try going into power option settings and taking the brightness to the max there. Start, control panel, power options, then you should see a setting for battery and for plugin. Hope this helps.
Jun 21, 2014 | Acer Aspire 5100-3019 PC Notebook
Hi Guys, I have a JVC 32T55EKS TV & the picture is overly dark. When the picture goes through the set-top box the picture gets even darker. The brightness is turned up fully & I have accessed the...
U turn on the contrast level to the max,if still not watchable,tv cathoray tube is dying,radiaton is disappearing.Time to buy another tv.
Feb 14, 2011 | JVC AV-27230 27" TV
Tv screen is very dark after turning brightness all th way up
You bulb is shot. They are expensive, time to get a new plasma.
May 04, 2010 | Panasonic PT-51G44 51" Rear Projection...
Tv light too dark- LG -rt 44sz21rb
Aug 08, 2009 | Televison & Video
Toshiba 35A44 Screen dark despite max brightness setting some OK
could be the sharpness, color, brightness, or a combination of them
May 05, 2009 | Toshiba 35A44 35" TV
Hatachi 53FDX01B
The screen drive or filament voltage is low
increase the the screen drive first.
mounted on the flyback transformer.
guy9
Nov 13, 2007 | Hitachi 53FDX01B 53" Rear Projection...
JVC AV27320 Screen too dark
Check the lumans circuit. may be jungle IC
Nov 02, 2007 | Samsung HC-P4241W 42" Rear Projection...
Screen too dark even with all brightness settings set to max
The picture is very dark it is mostly due to 1 power supply output is low. 2 voltage on crt g2 pin is low. 3 video output supply is low. 4 some components in luminance section might be defective or loose. 5 finally crt getting weak is set is old. good luck
Sep 21, 2007 | JVC AV-27430 27" TV
Dark image
Flyback transformers usually have 2 adjustable rods - 1 is for focus the other is for screen (G2) voltage. try turning Clockwise the Screen adjust with brightness-contrast at max. Till you see white diagonal lines, then go back until the lines disappear - then tune the brightness to your desired level.
Apr 27, 2007 | LG Flatron Ez T710BH 17" CRT Monitor
Panasonic PT-51G44 51" Rear Projection Television Logo
231 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
