No volume control with analog input on a denon 3805
I have a Denon 3805 connected to a blu ray S550 using the Analog inputs. I receive great sound however I have no volume control. I have checked the EXT IN button and I didnt have it on, so I tried it withit selected and not selected as well as with the receiver set to Autoand set to Analog only. The display shows Analog so the receiver knowsit is receiving the analog signal. However I still have no volumecontrol. The volume level is acceptable for regular viewing but if Iwant to crank it up at all I am stuck. The volume stays at the onelevel no matter what I do. The only change I get with the volumecontrol is when I lower it all the way so the volume displays _ _ _then the volume mutes or turns off. When I rotate the knob to get thedisplay to the next number the volume kicks on at the same level as itwas previously. There is no fading down or fading up to a certain level.
I went through the system setup and currently I only have the left andright front speakers and a center speaker. I dont have the surroundshooked up yet as the room is not completely finished. I have the frontand center speakers set to large with subwoofer set to on. This is setfor both the receiver and on the S550 player. I have the SW set to+10db and I tried changing all the channel levels to max to see if Iwould get a louder volume. Still no change. As I said before when Iturn the left knob to select the various inputs I hear the sound fromthe analog input and I still get the same volume level regardless ofthe input selected. The only change I get is the momentary muting ofthe sound when the receiver switches to the various inputs.
One thing I did notice was when I got to the TV input I heard the soundfrom the cable box as it is connected to the receiver via the coaxialdigital input and that input is assigned to the TV input. I getsimultaneous sound from the cable box and then the sound from the BluRay player. I am assuming the analog input receives the signal from thesource whenever it is sending a signal so that is why I am hearing thetwo channels simultaneously.
Anyway I hate to be one of those people that have long posts but I amfrustrated that I cant control the volume and it appears others havethe same hardware and can control the volume so I dont know why I cant.I am assuming its a simple setting somewhere but I cant figure it out.Sorry for being a pain in the ****. Any assistance I get from here isappreciated.
Thanks
  • RSN04 Jan 05, 2009
    I have the exact same setup - S550 and Denon 3805 with analog mulichannel connections. Same exact problem - no volume control. I will try a full reset and see what happens.
  • Dick
    Dick May 11, 2010
    Is it possible you have the muting function on? This unit allows you to set a muting level. The muting button should be the sixth one up from the bottom right on the remote control.
You're likely connected wrong. Double check, but I believe you aren't using the EXT IN connections but are hooked up in the Pre Out jacks. That would leave you with sound, but no control. Connect the player to the EXT IN jacks and all should be okay.
Posted on Sep 11, 2011
    President:
  • 948 Answers
Page 87 in the instruction manual gives the procedure for resetting the microprocessor. Turn off the power. Hold the buttons Pure Direct and Direct. When the entire display flashes at one second intervals, release the buttons. I hope that helps, good luck to you.
Posted on Jan 02, 2009
I cant connect my Denon avr 682 to my pc via optical??
I would change your setting on your receiver to digital. its probably on analog. look for a button that says that. You might have to change your input have a look at the rear and see if it says, DVD optical or CD and choose that input.
Dec 09, 2012 | Denon AVR-682 Receiver
I have a Denon 2800 hooked up to a Pioneer DV-C302D and while DVD's thru the Denon, the sound will come on and off. At the same time the Denon will be switching between analog and digital mode. Is one of...
It's a cable or connection.
The Denon apparently has an automatic selector to choose the digital input over the analog input if both are present (my Pioneer does this). The random switching is telling you the digital input is intermittently dropping out and coming back. You don't say if you're using the optical or coaxial digital interface. Coaxial is less prone to connection problems. If you use optical, make sure the ends are clicked in and there are no small radius bends in the cable. Tight curves reduce the optical power. Either way, check the connections and wiggle them to see if you can cause the problem to return.
Jan 18, 2010 | Denon AVR-2800 Receiver
How do i connect the xbox to the receiver using hd cables? which plugs in the back should the xbox cables go into?
which ever connection you have available. I think the 3805 has 3 component video inputs. If any of them are available use that input and tune the receiver to that input when you want to use the XBOX. You can even relabel it XBOX if you want in the menu but remember when using the remote it will still be VCR or whatever input you plugged it in as or reassigned it as. Remember renaming the input and reassigning it are 2 different things.
Also remember to assign the audio (digital or analog) to the same input as the component video.
If I helped please comment.
Nov 30, 2009 | Denon AVR-3805 Receiver
Can't record out from a digital input
It only passes the signal it see's. Digital for Digital and Analog for Analog. Try running a Standard analog RCA from your Cable box to the receiver then try and record. Hope this helps. If you still have an issue, post a comment and I can help you further.
Sep 18, 2009 | Denon AVR-3803 Receiver
Denon avr 3805 2 zone configuration, I added optical sound from TIVO and now zone 2 is not working. I did the test of the speakers and they all work. I have configured the main for 5 channel stereo.
Zone 2 needs an analog input to work, if you pulled the analog from tivo, put it back on. Digital will not pass on zone 2. If your analog is still connected as well, go into your receivers settings for audio and select "auto" not "digital" Check the settings on tivo as well. make sure it's audio output is set to "auto" if available. If it's not, it's default is "auto" and will output simeltaneously on all outputs. Hope this helps. If you need more help, post a comment and I will help some more.
Jul 05, 2009 | Denon AVR 3808Ci Receiver
Selecting a Blu-Ray Player
If Denon blu ray has coaxial or optical out for audio, then your Denon receiver will process this signal and will give you 7.1 out sound.
Jan 24, 2009 | Denon AVR-4802 Receiver
HDMI on PC but not on Denon AVR 3805 -
For this situation you will have to take audio output from the TV to an input on the Denon
Jan 11, 2009 | Denon AVR-3805 Receiver
How to connect BLU-RAY DVD player to Pioneer Plasma TV via HDMI
The best possible solution to your problem is :
Connect your blu ray player directly to the HDMI input of you Plasma and watch HD video....
and connect the 5.1/7.1 sound thru the optical or the coaxial link directly to your AVR 3805.
You will not loose anything on the Blu-Ray.
The sound is best processsed by the AVR3805, while the video, which is the real upgrade (BluRay) in terms of resolution of picture would be processed by your plasma.
Connect and Enjoy
Dec 16, 2008 | Denon AVR-3805 Receiver
Connecting Sony BDP S550 Blu-ray player to my Denon 3802 receiver.
The only thing you need is an optical audio cable (toslink) connecting the Blu-ray blayer with one of the three inputs on the AVR3802. Then assign this input in the system menu to the input you like (e. g. DVD) and that should be it. The Receiver automatically detects the sound format from the Blu-ray and changes from stereo to DTS, DD5.1, 7.1 or whatever.
Regards
Thomas
Nov 01, 2008 | Denon AVR-3802 Receiver
168 people viewed this question
 Grubhead
Grubhead
