Busther I need to get the Recovery Console onto my hard drive. How do I do that.
  • Stephen Medley
    Stephen Medley May 11, 2010
    You must give us a clue as to your operating system, brand and model. Happy to help if would specify. Steve
    Scholar:
  • 67 Answers
You can follow the following Microsoft article to get into recovery console:
http://support.microsoft.com/kb/307654
And this will help you in using recovery console advanced commands:
http://support.microsoft.com/kb/314058
Posted on Dec 27, 2008
Recovery the master boot record
Restart your computer with the Operating system Setup disk in the CDROM drive. If you are prompted to press a key to start the computer from CDROM, do so quickly. Otherwise it may try to boot from the hard drive. After a few minutes, you'll see a prompt to press the R key to start the Recovery Console. When Recovery Console starts, it will prompt you to enter a number corresponding to the Windows XP installation that you need to repair. In most cases, you'll enter "1" (which will be the only choice). If you press ENTER without typing a number, Recovery Console will quit and restart your computer. Enter your Administrator password. If you don't enter the correct password, you cannot continue. At the Recovery Console command prompt, type fixmbr and then verify that you want to proceed. Your damaged MBR will be replaced with a shiny new one, and you should then be able to boot your system normally. In some cases, you may need to repair the boot sector in addition to the MBR. If your system still doesn't boot properly, repeat the steps above, but issue the fixboot command instead. Hope this helps
Jul 02, 2011 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Hdd mbr is lost
Restart your computer with the Setup disk in the CDROM drive. If you are prompted to press a key to start the computer from CDROM, do so quickly. Otherwise it may try to boot from the hard drive. After a few minutes, you'll see a prompt to press the R key to start the Recovery Console. When Recovery Console starts, it will prompt you to enter a number corresponding to the Windows XP installation that you need to repair. In most cases, you'll enter "1" (which will be the only choice). If you press ENTER without typing a number, Recovery Console will quit and restart your computer. Enter your Administrator password. If you don't enter the correct password, you cannot continue. At the Recovery Console command prompt, type fixmbr and then verify that you want to proceed. Your damaged MBR will be replaced with a shiny new one, and you should then be able to boot your system normally. In some cases, you may need to repair the boot sector in addition to the MBR. If your system still doesn't boot properly, repeat the steps above, but issue the fixboot command instead. Hope this helps
Mar 29, 2011 | Seagate HDD 40GB 7200RPM ATA100 2MB...
Instal screen freezes at 99%,cannot get to diag screen
Try accessing the recovery menu 'safe mode'.
Press and hold the power button until the systems shuts off. (wait 2 seconds)
Press and hold the power button again until you here 3 beeps. Let go.
It should ask you to connect your controller via usb and press the PS button in
the middle of your controller. There will be a menu with 6 options.You need 6.
You will need to have the latest firmware on a usb stick. Download the firmware from the playstation official website onto a usb stick. Once prompted by your system you will need to insert the usb stick into the PS3. Good luck..
If this doesn't work:
Your HARD DRIVE (aka: Hard Disk), located on the left side of the unit, has crashed. You will need to replace the HD.
When you replace your hard drive, you will need to have the latest firmware on a
PS3. Good luck..
You will need 2.5" Sata Hard Drive.
Jan 28, 2011 | Sony Playstation 3 (PS3) Console
On my PS3 when I try to update it, its keeps on saying error code 8002F994 and that the data is corrupted. Im tying to updated it to 3.5
Your HARD DRIVE (aka: Hard Disk), located on the left side of the unit, may have crashed. You will need to replace the HD.
PS3. Good luck..
Before you replace the hard drive, try:
the middle of your controller. There will be a menu with 6 options. Update using option 6.
PS3. Good luck..
Safeboot corrupted (error 92h)
Check the BIOS setting to see if the hard disk is detected. If not either the hard disk controller or the hard disk is faulty.
First thing I would try is to remove the hard drive and connect it to an USB hard drive adapter and then plug this adapter into a working computer's USB port. If this computer sees this hard drive as an external hard drive and you can open the various folders and files, then I would backup your data.
If the hard drive is not detected then the hard drive is dead and data cannot be retrieved with this method.
Retrieving data from damaged hard disk is possible. There are companies that can remove the disk platters from the damaged hard drive and with special equipment may be able to recover your data, but it will cost you an arm and a leg for their services.
Jun 24, 2010 | HP EliteBook 2530p Notebook
My hard drive burnt out. The hard drive test says failed and the operating system won't boot. I placed a leftover hard drive from my Playstation 3 into the laptop and now it says no operating system found....
Try the recovery console from a windows xp recovery/install disk:
To run the Recovery Console from the Windows XP startup disks or the Windows XP CD-ROM, follow these steps:
1.Insert the Windows XP startup disk into the floppy disk drive, or insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer.
Click to select any options that are required to start the computer from the CD-ROM drive if you are prompted.
2.When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
3.Select the operating system you want to repair (you may have only one option).
4.When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
5.At the command prompt, type the appropriate commands to diagnose and repair your Windows XP installation. From here I would try "chkdsk /r" and "fixboot"
For a list of commands that are available in Recovery Console, type recovery console commands or help at the command prompt, and then press ENTER.
For information about a specific command, type help commandname at the command prompt, and then press ENTER.
6.To exit the Recovery Console and restart the computer, type exit at the command prompt, and then press ENTER.
Once you've done this restart the computer and see if it boots up.
Apr 08, 2010 | HP Compaq Presario V6000T PC Notebook
Dell 700m wont boot with new hdd
Hi
Need to know how far it boots, eg past cmos screen, ??Win screen
Also some laptops will only accept hard drives up to certain sizes. Check in the Bios as to whether that size drive is actually supported.
Aug 12, 2009 | Dell Inspiron 700M Notebook
Gateway 7330GZ Not Booting Properly
Probably a virus, or your windows folder got corrupted. Try to use Knoppix (A linux distrobution that boots from a CD) to get all your data onto a pen drive or external hard drive. Download the Knoppix ISO at Knoppix.com and burn it onto a CD or DVD using MagicISO (magiciso.com). Insert the CD, and you should see the boot screen. Open the file manager, and copy all the files you want to keep from your hard drive to a pen drive or external hard drive. Then, reinstall Windows using a recovery CD (one might have come with your computer). Copy the files back, and PRESTO!
Feb 04, 2009 | Gateway 7330GZ Notebook
Help
No
You need to Go for Pc Recovery from HP it self or you can get the recovery cds for it.
Try :-
Opening Recovery Console
The following steps open a Recovery Console:
1. Shut Down Your Computer and as soon as you turn your computer On Keep pressing F10 key on the Key board,
You will get an welcome to recovery manager screen after that it will ask you if you want ot run recovery.
after that you need to follow the screen Instructions.
Or either try.
Using the Checkdisk Utility
Use the following steps start the recovery console and use chkdsk to resolve startup issues:
1.Open a recovery console. For more information about how to open a recovery console, refer to the section above: Opening Recovery Console .
2. At the C:\Windows> prompt in the recovery console enter chkdsk /r .
NOTE:If chkdsk /r fails to start from the selected prompt, type chkdsk c: /r (note the space before and after the drives c:). If you are using a recovery console or Tools CD, type chkdsk d: /r , or chkdsk h: /r .
Chkdsk starts.
The time required depends on the size of the hard drive (it checks unused portions of the hard drive) and the amount of software installed. When chkdsk /r completes the screen displays the size of the volume checked and the allocation units. If errors are detected the result are displayed as CHKDSK found and fixed one or more errors on the volume . This is normal.
3.Type EXIT and press Enter on the keyboard.
The PC restarts.
4.If you used the Recovery Console from a CD, while the PC is restarting, press the Eject button on the CD drive and wait a few seconds for the drive tray to open. Remove Recovery Console from the optical drive.
Oct 14, 2008 | HP Pavilion a350n PC Desktop
Need help
Sounds like a failing hard drive or corrupt file system.
Or possibly you have a non bootable disk in the floppy drive, assuming it has one as most laptops dont.
Is this Windows XP? If so, try booting from the XP cd. At the menu, choose R for recovery console.
In the recovery console, type in CHKDSK /R and let it run, it may take well over and hour to run, if it runs at all. If the recovery console is unable to load, or chkdsk wont run, you may have a failing hard drive.
Oct 23, 2007 | Computers & Internet
Computers & Internet Logo
Alun Cox
David Payne
David Payne
