Question about Sony Handycam DCR-TRV330 Digital Camcorder
Tape Won't Load
This problem started when I tried to use VCR mode to play back some footage. I saw a yellow flashing icon which looked like an "eject" symbol (upward triangle above a horizontal line), so I opened the tape deck and removed the tape. Then I tried to put it back in. Now, the cassette holder will not retract into the camera when a tape is inserted. I can close the metal frame fine, but it won't move back into the camera body like it's supposed to. The whole assembly works fine if I try the same thing with no tape. It opens, closes, moves in and out just fine. When I close the metal frame with a tape inserted and it doesn't retract, I have to "fake" closing the main body of the camera and then the metal frame opens up again. It's a problem with the camera, not the tape. I've tried the same thing with other tapes and had the same problems. I've tried leaving it alone for a few hours and it hasn't changed. It had plenty of charge when the problem began.
  • LenMatheson Nov 01, 2007
    Same problem, with C31:40 error message. Tried the fix regarding the video head without success.
  • Anonymous Nov 04, 2007
    i can not close the tap door
This sort of helped,,... slam it against the wall... pick up the pieces, throw em' in the trash, buy a new camera!
Posted on Feb 07, 2008
    Champion:
  • 287 Answers
Try this quick fix. check and see if the video head is bound. I have seen alot of these stick. put your figure on the top edge of the head only and see if is free spinning on not. sometimes you can more it one way or the other and free it up. this problem could also just require a tape path cleaning. anything sticky on the tape path or head will cause this.
Posted on Sep 18, 2007
VCR won't eject tape or play & powers off
It sounds as though it's jammed. If you're mechanically inclined you can unplug the unit, take the cover off, and manually eject it. Just look for the motor that drives the load basket and manually spin the shaft. The guide-posts should retract towards the tape and the basket will then lift and eject. Just be aware that whatever bit of tape that's out of the cassette won't spool back in. You will have to do that bu hand once it's out.
When you're done, plug it back in and let it cycle then put an old cheap tape in and see if it works. If not, take it in for repair.
Nov 08, 2007 | Emerson EWR20V4 DVD Recorder/VCR
Dvd player will not eject or play dvd. It just keeps spinning and says "reading." I've tried unplugging for 2 minutes, pushing close/open and stop at the same time(hold for at least 3 seconds)....
Plug the power cord back into the electrical outlet and turn the player ON. Attempt to open the disc tray. Depending on the model number of your DVD player, simultaneously press the POWER + STOP + EJECT buttons. If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons.6 Jan 2013
Solved: DVD is LOCKED will not eject. please help. Manual ... - the ...
https://community.sony.com/t5/Home-Theater.../DVD-is...will-not-eject.../td.../55919.
or try this link. Dvd player will not eject or play dvd Google Search
Oct 18, 2017 | RCA DRC8295 DVD Recorder/VCR Combo
Panasonic VCR 7350 displays error messages and cant insert tape
There is either some damage to the mechanism or the mode switch is faulty. If you know what to look for taking the top cover off might show what part of the mechanism is damaged.
If it is the mode switch then it will need to be replaced. This can't be done without the service manual as the vcr needs to be set up. And they are never set up in the eject position.
Sep 27, 2017 | Panasonic AG-7350 VHS/S-VHS playback VCR
Player shows ejects symbol and shuts off after about 45 seconds
the timing will be out of line, thats whats putting in shut-down mode. dis-engage the tape carriage from the running cogs and manually put it in eject mode, re-align the main cogs to their pointers. there should be one on the cogs and on the chassis to help you re-align then re-engage the carriage to its cog.
Jun 13, 2008 | Sony SLV-D251P DVD/CD Player w/Built-in...
Error flashing
We looked at your online manual and figued out that it was a formatting error. Then went through the steps to fix the problem. Camera working fine now.
Apr 01, 2008 | Sony Handycam DCR-TRV18E Mini DV Digital...
Playing back footage on pc
don't know u're cam, but usualy the camera haz to "close" the dvd sesion, so that the computer/dvd player .... to be able to play it ...
Ofecourse u can play the video on PC, using cd/dvd data recovery software, that accesses the data directly and not track based ... (that in the case that the dvd got damaged and the recorder can't finish it ...)
Feb 17, 2008 | Video Cameras
Cannot remove progressive scan mode
press stop and keep hold of the stop button while you eject the dvd, it worked for me, i played around with it and found pressing stop and holding it while ejecting works
Sep 30, 2007 | Televison & Video
mini DVs sometimes can't be access using usb interface, try to look if u have a firewire interface, be sure your laptop supports IEEE1394. power dvd is the best player for dvd files. -r means recordable, not rewritable (rw). if ur not familiar with video editing, you may not be able to burn it to disc, but you can play and watch everytime.
May 17, 2007 | JVC GR-D250 Mini DV Digital Camcorder
Sony Handycam DCR-TRV330 Digital Camcorder Logo
213 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
