Question about Philips CDR770 CD Recorder
Disc indicates "disc full" after only a couple minutes of recordi
I've had my Phillips CDR 880 cd recorder for nearly ten years. As recently as last week it was working fine.
This week, I attempted to complete a compilation cd-r that I was
making from various sources. I had successfully, last week, recorded
about ten selections and had filled about 46 minutes of the music cd-r
disc. This week, when I attempted to record another selection onto
the disc in the recorder, it stopped recording after a minute or so and
registered 79:00 of material, as if the disc was now full, which of
course was impossible.
I inserted a new blank disc but the same thing happened when I
tried to record.
  • 56 Answers
Brand of disk or bad laser alignment can cause this. if you have changed brands of disks go back to the others and if you have not then laser alignment is the most likely cause and can be fixed by a certified technician in this field.
Posted on Dec 27, 2008
I don't founr cd 74 mn 650mb, what use the DENON CDR M30 ??
If I understand your question, it can play any kind of music CD but it can only record on CDR-Audio or CDR-Music discs only.
• Only audio CD-R/RW discs can be recorded with this unit. "Use Audio CD" will be displayed when a disc other than one
for use with audio such as a CD-R/RW disc for use with a personal computer or another type of disc is loaded. (See "Discs that Can Be Used with this Unit" on Page 5.)
• CD-R discs can be recorded to only once. The recorded information cannot be erased.
• The recorded information of CD-RW discs can be erased. When this disc has been finalized, erase after the finalization removal operation has been performed. (See "Cancellation of CD-RW disc finalizing" on Page 28.)
• Recording mistakes made with CD-R discs cannot be erased; therefore, it is recommended that a CD-RW disc be used until you are accustomed to the recording operation.
If you desire 74-minute blank disc just Google "cd-r audio 74". The unit will also use 800MB 80-minute CD's.
Jan 31, 2011 | Denon CDR-M30 CD Recorder
I have a Marantz CDR 615 and it won't let me record anything-any help would begreat thanks
What kind of error are you getting? Does it attempt to calibrate then display the entire disc as being full? If that try a blank that will tolerate recording at the 1x speed. Nowadays the only thing you will likely find are discs meant for audio recording or data discs that can record at speeds as low as 1x. If you can find some of the earlier kodak, Ampex/Quantegy, japanese maxells, etc then you will be okay. Also it may not be obvious but the cdr 615/620 will not record on cd-rw's
I bought one of those new and had nothing but trouble out of the phillips cdd2000 module that had to be replaced 3 times (3rd time at my expense of $300) but Superscope in Aurora, IL was good about support. Ironically I seam to remember a class action suit against Phillips over their very flaky cdd2000 drives.
Oct 01, 2010 | Marantz CDR631 CD Recorder
Phillips CDR 570
Let's start with an assumption... you're using ReWriteable discs.
What specific message do you get when you try to unfinalize it?
When finishing a recording, what does it display instead of "update" when you stop?
May 04, 2010 | Philips CDR796 2-Disc CD Recorder
My problem is my phillips cdr 770 wont accept the cds that i bought they are maxell 80 min normal cd r but the recorder saying wrong disc use audio cd so what cds do i use ????? am stumped it should use...
THE PHILLIPS CDR 770 WILL ONLY RECORD ON "MUSIC" CD'S.I USE A MEMOREX MUSIC CD FROM WAL-MART, IT'S A 40X700MB 80 MIN, IT WORKS FINE, HOPE THIS HELPS, GOD BLESS, PAUL
Sep 29, 2009 | Philips CDR770 CD Recorder
I nead a new manual for a phillips cdr 775 dual recorder
http://www.usersmanualguide.com/philips/home_audio-video__cd_recorders/cdr775_00
Choose your specific model and language. Downloads in pdf format.
Good Luck,
BB
Jan 05, 2009 | Philips CDR775 2-Disc CD Recorder
Phillips cdr 785 audio recorder will not record. i am using digital audio cdr blanks.unit is 6 years old...has not been recording for 3 years.
time to buy new one or upgrade software
new cd/dvd formats came out maken it hard to play record or watch on outdate equipment
they remolded the cd/dvds with a new gloss
May 13, 2008 | Audio Players & Recorders
Wrong disc
Some audio cd's work better than others. I have experienced some problems with the Maxell brand so I switched brands. It can be quirky. Sometimes you get a bad lot of discs. I have had no problems since that bad lot of discs.
Mar 05, 2008 | Philips CDR770 CD Recorder
RECORD DROP OUT
Just bought this CDR 570 and not use yet.
Reading the instruction manual - yes, life experience has taught me some really useful stuff! -
Under 'Discs for recording' on page 7 it says at end of section
IMPORTANT:
To ensure proper working of the set we recommend the use of PHILIPS audio CDR and audio CDRW discs only'
Roughly translated I read this to me - 'don't blame us if the set don't work using other (non-compatible) discs' !!
Oct 02, 2007 | Philips CDR570 CD Recorder
Philips CD Recorder
Have you tried cleaning the lazer lens with a cleaning disk?
May 19, 2007 | Teac CD-RW880 CD Player / Recorder
Philips CDR770 CD Recorder Logo
139 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
