Question about Epson Stylus Photo R200 InkJet Printer
Both Red Lights Flash together green light off - no printing
Over 2 years ago I disabled the Epson Software monitor, and installed the SSC Service Utility. Also at that time I replumbed the waste ink to a bottle outside the printer so bottom ink absorption pads are dry. I have a CISS system on it that has worked perfectly for 2+ years. Suddenly I get two simultaneous red flashing lights on the printer and it will go through it's startup dance with the ink cartridges, but then just sits and flashes at me and won't print. Any clues?
  • 159 Answers
Mine did that too but my power went out in the house.
So diconnected it and uninstalled ssc utility.
Then reinstalled.
Worked fine after that. Hope it works for you.
Posted on Jan 16, 2009
2 red lights blinking
Please see this solution I posted up earlier on another R230 query
Oct 09, 2009 | Epson STYLUS R230 InkJet Photo Printer
What should I do, my Epson stylus R230 is not printing and the 2 red lights are blinking? What button on the SSC utility service should i click on?
Run SSC. Menu Configuration. Select installed printer. Select printer mode to Epson R220/230. Close dialog box by clicking cross sign at top right of dialog box. Icon will show at bottom right of dekstop. Right click, select protection counter. Show current value for checking waste ink counter. Click Reset protection counter. Turn off printer. Turn on again. Usually SSC doesn't work at Vista.
Epson r230 general error
Blink alternately or not? If alternately, the message is not "general error". but "service required" It's true to reset waste ink counter. But, i think it's not service required. when trun on printer ready? But when start to print red lights blink at same time? Problem with chip at ink tank. Check connector at chip and at head carriage. It's may be dirty, and not good connection. try to use another chip.
Jun 22, 2009 | Epson Stylus C86 InkJet Printer
Green and red light permanantly on.
Green and red light on : ink out error / chip doesn't recognized. If u use SSC, and said "Coomuniaction error", it's normal. Replace ink tank, or use CISS chip.
Jun 11, 2009 | Epson Stylus 680 InkJet Color Printer
C43 stylus does'nt print while red and green lights stay on
If the light are flashing, it mean waste ink full. You must clean waste ink pad, and reset the counter. You can use SSC, find at indoreset.blogspot.com. But,.. you said the light are on. try to resinstall driver. after printer recognised by comp, check status monitor. Green light on is power on, and red on mean chip error/ink out error/cartridge error.
May 29, 2009 | Epson Stylus C43SX InkJet Printer
R230 Epson Printer
I cant print coz of my printer (R230 Epson Printer) blinking 2 red light. Printer dosnt ready. It say-Service required. how can I release this problem. Plz tell me.
Apr 17, 2009 | Epson STYLUS R230 InkJet Photo Printer
Epson Stylus photo 810/ink jet printer
Hi Alan
I expect by now you've solved this problem - but just in case .....
The waste ink "protection" counter has exceeded its limit and needs resetting. You can do this easily by using the SSC utility - download from:
http://www.ssclg.com/epsone.shtml
Install it, and double click the ssc printer icon in the bottom right corner (System Tray). Choose Configuration and set your printer type (810), then close the ssc window. Now right click the ssc icon in the sytem tray and choose Protection Counter. You should see that the current count is above the limit; then choose reset to set it to zero. Turn the printer off then back on again. This will stop the lights flashing and restore normal operation.
May 17, 2008 | Epson Stylus Multifunction Inkjet Printer/...
Epson r230 2 red lights blinking and wont print
download the epson ssc service util
http://www.softpedia.com/get/System/System-Miscellaneous/SSC-Service-Utility.shtml
install it set for r230 then using the tray icon right click the tray icon choose protection counter from the menu then choose reset protection counter then turn off the printer then turn the printer back on
Dec 16, 2007 | Epson Stylus RX425 Multifunction...
Printer lights flashing.
the secret there is that you have to RESET the printer's "internal counter" by a utility software called "SSC Service Utility" go get it and install...
Oct 30, 2007 | Epson Stylus C46 InkJet Printer
Epson Stylus Photo R200 InkJet Printer Logo
258 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
