Question about Panasonic LF D521 (LF-D521U) DVD-RAM/DVD-RW Burner
DVD drive troubleshooting
Hello, I have a panasonic LF-D521 DVD drive. It plays disk DVD's ok, but whenever I insert a DVD cartridge it keeps ejecting. I did the test where you unplug the data cable and turn on pc, to see if it ejects during boot and it didn't eject. Any idea's other than trying different media? thanks plopdog
Make a firmware flash to a111 (the original one)
Posted on Jun 17, 2007
    President:
  • 2,961 Answers
Can you explain a dvd cartridge please?
Posted on May 04, 2007
My Panasonic- Dvd A560EN , Before it was played smoothley all kinds of dvd and cds. currently can not play any disk; even disk inside it says "No Disk" (rarely I am using this player)...
Hello
Its Laser Pickup Unit is either dusy or damaged. Just insert a cleaning disc into it and play it for atleat three times and check. If this process does not help you; have to repalce its Laser Pickup Unit with same type and number. This is a common fault with most DVDs irrespective of which companys' are they are. OK.
Jul 01, 2011 | Televison & Video
Missing driver for lf-d211a
if this is on a windows based operating system
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
Hope this helps
May 04, 2011 | Apple LF-D211A Panasonic / 4.7GB DVD-RAM...
Will not accept disk. keeps popping out.
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or the drivers may have been corrupted or you might have a virus run your antivrus program you might have to physically unplug the leads for this cd/dvd burner then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Apr 06, 2011 | Panasonic LF-D D211V (LF-D211V) DVD-RAM...
@Hello - whenever I try to insert a disk to play it starts reading it (display reads READ...READ and then it stops and displays HO7 and won't play the disk at all. I've had the unit a few years but have...
H07 is a common error code for Panasonic DVD players. It means the traverse unit (spindle motor/laser assembly contained in one block) has failed. Usually it is the spindle motor part of this unit which fails first, (i.e. it doesn't spin the disc at all) causing the problem, but sometimes the laser can also fail as well. Because the motor and laser are contained in one device block, the whole part has to be changed, and this can only be done by an authorised service centre. The only trouble with that is the cost. Many DVD drives experience this (different brands giving different error codes) so it's not just confined to Panasonic.
There are only 2 ways to go here; either be prepared to spend a fortune in a workshop service to have the traverse block replaced/aligned (which would include a brand new laser), or simply buy a new player - which would give you a new remote AND an optional extended warranty if available; this would be considerably cheaper than repairing the old one.
Don't be put off from owning Panasonic - they are generally good products.
Feb 24, 2011 | Panasonic DVD-RV32 DVD Player
Dell demension 3100 dvd plays any disk ok but will not burn
when you try to save or burn any data to disk, you should use burning programs just like nero or any other burning program. at the time when you click the button burn, it always ask you to insert disk such as CD/DVD +R or RW
Mar 25, 2010 | Dell Dimension 3100 PC Desktop
The dvd slot wont open. the last disk that i put in it still plays fine but i cant open it to put a new disk in.
Hello there:
normally go to my computer and look for your player and click on eject,
but if this doesent work get a small paperclip and on the dvd player look for a small hole and insert it and press firmly and this will open the drive door ok. this should help you out ok?
best regards mike.
Aug 25, 2009 | Toshiba Televison & Video
Toshiba sd-r2002 - won't recognize blank CD when trying to write files to a CD
right click on the drive.... go to properties... under tab recording, remove tick "enable CD recording on this drive" and press apply... after that tick "enable CD recording on this drive" and press OK.
It should work.
Jun 01, 2009 | Toshiba SD R2002 CD-RW/DVD-ROM Burner
Wont play dvd's.
If this happens when you insert a DVD disc then most likely the laser assembly is failing in the DVD drive. In most cases it will probably still play CD's. The part number needed is LSVQ0087 and isn't cheap as seen on the following ebay posting. Please take a moment to rate my answer. Thanks.
http://cgi.ebay.com/Panasonic-LSVQ0087-BLOCK_W0QQitemZ390013781267QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item5acea20513
May 10, 2009 | Panasonic PV-DF2004 20 in. TV/VCR/DVD...
Panasonic dmr es10
Some DVD recorders don't like certain types of media. Does this happen with all blank dvd+rw disks or just with that specific brand? If it's that brand then you should just use a different one.
Jan 07, 2008 | Panasonic DMR-ES10 DVD Recorder
PANASONIC dmr-es10
The DVD RAM drive is mis-aligned and does not load the disc correctly.
contact our local service center for a quote
Dec 14, 2007 | Panasonic DMR-ES10 DVD Recorder
Panasonic LF D521 (LF-D521U) DVD-RAM/DVD-RW Burner Logo
234 people viewed this question
Top Panasonic Computers & Internet Experts
micky dee
Steve Allison
Steve Allison
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
