Question about White Sewing 1740 Mechanical Sewing Machine
My bobbin keeps getting tangled up when I sew
The bobbin is tangleing no matter if I straight stitch r try to zig zag
  • 2 more comments
  • drea0436 Dec 23, 2008
    i'm a newbie at this sewing stuff... but yes everytime i strait stitch it tangles up at the bottom and i just dont know what to do
  • Anonymous Mar 12, 2014
    decorative stitches don't work. There are some arrows in red next to the bobbin that show up and down. Could this be to widen to a zig zag?
  • Anonymous Mar 20, 2014
    machine has never been cleaned inside
  • Anonymous Mar 25, 2014
    I have a singer zig zag 758 and I need to know how to fill and install bobbin.
    Novelist:
  • 192 Answers
Take the thread out of the top and bottom and turn the handwheel by hand to see if the machine will rotate smoothly.
Rethread, making sure that the thread is in the bobbin tension slot and that the upper thread is in the tension and the take up lever.
Sorry for the delay in response. I just found the sight this evening.
Posted on Nov 14, 2007
If thread is bunching up under or at the bobbin (White 1740) and it clanks, check if the needle thread has come out of the upper arm. It can easily slip out of the slot. I have wound a narrow band of tape on the slot to prevent the thread from escaping. Leave enough opening to put the thread through when threading the machine.
Posted on Jan 19, 2011
    Problem Solver:
  • 23 Answers
When you wind your bobbin make sure you use even tension. Do not wind it to tight or to loose. Do not overwind it. Make sure that you are thread the bobbin correctly. Also do not sew at top speed. Use a slow to moderately slow speed.
Posted on Nov 19, 2008
Perfect straight stitch but small tight zig zag
try adjusting the tension
make sure the thread is not caught on anything, sometime the thread can get caught on the notch on the spool
take the bobbin out and put it back in
could also be a problem with the cam that does the zig zag stitch
if the problem keeps happening the machine needs to be checked
Jan 06, 2016 | Sewing Machines
Bobbin unthreads my needle and will not sew
Try changing the needle to a new one, size 12, a dull or bent needle will cause this.
Jan 28, 2015 | Sewing Machines
My Kenmore 19233 refuses to zig zag stitch past 2mm wide. At 2mm it is a reliable stitch, moving toward 7mm it is a straight stitch with one or two zig zag blips.
Do you have it on zig zag or maybe it is in one of the hem stitches. Make sure you have not selected a special stitch. Sometimes with a small width setting it looks like no zig zag, then when you increase the length you see it is not.
Oct 20, 2014 | Kenmore 19233 Computerized Sewing Machine
Baby lock pro BL40, bobbin thread tangles, tried new bobbin, cleaned under plate, needle is straight, what to do?
make sure the bobbin is turned the correct way in the bobbin case
make sure the top thread has not come off the thread take up lever
could also be a timing problem
Jul 28, 2014 | Sewing Machines
Tangled thread on wrong side. The thread on the
I'm guessing it is because the tension is not just right, the bobbin might not be the right size, the thread type top and Botton might not be the same, or you just might need put in a new needle the right size.
Aug 09, 2017 | Brother CS-6000
I have a Brother CS6000i sewin machine and I'm
Mmmm Are you using the right stitch? Like zig zag or straight stitch only with a medium stitch length? Check that and test again.
Sep 06, 2012 | Sewing Machines
Bernina activa 210 won't zigzag and has bobbin issues on straight stitch
it's very possible that the machine is slightly out of time & needs to be service at a sewing machine shop
is the fabric & thread & needle compatable with each other?
did you use every thread guide when threading the machine?
is the bobbin in correctly?
is the bobbin warped?
Mar 20, 2012 | Bernina Sewing Machines
Trying to sew light indoor outdoor material (zig/zag stitch) keeps getting tangled in the feed dogs and needle keeps sticking in the material from the top. It is mangling my fabric.
What size needle are you using? You should be using at least a #14 or #16. A #11 is too light duty. Try that and see if it doesn't make a difference.
Apr 14, 2011 | Brother CE5000 Computerized Sewing Machine
Tangled thread
Ask at the shop where you bought it, take a sample and arrange a time to meet & discuss if it is under warantee.
Jul 30, 2009 | Brother CS6000i Computerized Sewing...
Suddenly zig zag stitch not working?
Because it is almost a straight stitch but the needle continues to move in a zig zag fashion is reason to believe it is in a long stitch. By changing the number of stitches per inch there will be a very noticeable looking zig zag stitch.
Mar 25, 2017 | Brother XL-2610
White Sewing 1740 Mechanical Sewing Machine Logo
756 people viewed this question
Top White Sewing Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
