Question about Zoom X6 (5590) DSL Modem (55900003)
IPod connection to Zoom ADSL X65590 router
Have WEP 64 bit encryption on above router. iPod touch detects zoom router but will not connect (locked sign). Does not ask for password. Tried to connect manually but get lost asks for :-
IP address (automatically found)
Sub net mask (found automatically)
Router ?? zoom
DNS ?
Search domain ?
URL ?
Client ID ?? password
Changed encryption from WEP to WPA
Posted on Jan 07, 2009
You have to log in http://10.0.0.2 at the button/under of your router tells you the generic name and password you need to enter, just follow the instructions, you'll be able to change your settings
Posted on Jan 03, 2009
I have ipod touch,3 GB. I am not able set up WiFi connetion to my Zoom ADSL X6 router. I enter the pass word but it keep rejecting the connection. I have three other PC that seems to connect remotely with...
You could try restoring your Ipod touch to factory settings and then retrying to connect it to your wifi. Or your wireless card receiver may be broken.
Mar 01, 2011 | Zoom Computers & Internet
I changed from 64 bit to 128 bit back to 64 bit in 1 hr. It was an accident, and now my laptops will not recognize my router. My cable company has tried everything over the phone.We have changed the...
When you changed the WEP encryption from 64 bit to a stronger 128 bit encryption the encryption code gets changed and when you changes it back to 64 bit the new 64 bit encryption code will be different to the old 64 bit encryption code, that is why your laptops cannot connect to the router. The laptop wireless card needs to be configured with the new 64 bit encryption code before it can connect to the wireless router.
I suggest you configure the wireless router with WPA or WPA2 encryption, this is a much stronger encryption method than the old WEP encryption.
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
Sep 12, 2010 | Computers & Internet
UNABLE TO CONNECT IPOD TOUCH TO MY COMPUTOR
the computer may have some problems reading the driver for your iPod
Mar 08, 2010 | Zoom X6 Adsl Wireless Gateway Rohs Router
IPOD Touch asks for password; password unknown
To configure your router, open your web browser. Type the default IP address (http://10.0.0.2) into the Location field of your browser and press the Enter key. A Login screen will appear. Use the below to log into your router.
The default user name is admin
The default password is zoomadsl
You click on the icon labeled Wireless at the top of the screen.
Set the Wireless status drop down menu to Enable
The SSID will be set to zoom by default. You probably want to change that since everybody will know this type of network.
You can Hide the SSID if you would like by choosing True on the Hide SSID option. This will make it harder for people to know how to connect to your network. Just remember that you will not be able to see this as well.
Under the Encryption you will need to pick your Encryption type. If you pick WEP-64 bit then you will want to click the Passphrase box and place your passphrase and have it generate a random key. If the Default Key is set to 1 then you would use the Key1 key. Make sure you click on the Save Changes so that it keeps these setting.s
Hope that helps!
Jan 07, 2010 | Zoom X6 Adsl Wireless Gateway Rohs Router
Can't connect ipod to Zoom adsl x6 modem.
I found if I removed the WEP security on an X6 the Ipod connected without any problem.
I tried WPA and WPA2, and these won't connect either.
The password it wants it the one you used to generate your WEP code when you first set up the router. If you don't know what that is, then you'll have to reconfigure it with anew one.
Also, an IPod Touch may connect if you choose Other connection in it's network settings, and then tell it to connect to WEP.
Jan 03, 2010 | Zoom Computers & Internet
After installing the router it was working fine. I went in to set up wireless security and now the internet light stays red.
Probably means that the security is turned on, if the wireless doesn't work even after you have entered the right password then press and hold the reset button on the back of the router to restore it to defaults - factory defaults just like it was first powered on.
Oct 07, 2009 | Zoom X6 Adsl Modem/router Rohs...
I cannot connect to wifi in my ipod touch
Change the router encryption or create an encryption as WEP using your Zyxel router.
The connection in your college is maybe unsecured or no security?
- Try also to check the settings of your router make that unsecured or configured a WEP encryption to the router.
- Turn off the MAC filtering of the router (Under advance settings)
- Disable the wifi-protected setup of the router (Under advance settings)
- Refresh the network list before reconnecting to the network.
Note: As we try WEP encryption to some of the router, the IPod can connect to the network.
Mar 08, 2009 | Zyxel P660HW-D1 Router
Connecting laptop to internet
Reset the router and try again
Nov 10, 2008 | Zoom Computers & Internet
How do I find out my wep key
Looks like you will have to login to the router from the other computer to find the key.
Usually, the address to the router admin screens is one of the following:
192.168.0.1 Linksys
192.168.1.1 NetGear
192.168.10.100 Motorola
Generally 192.168.1.1 will work for most.
Default Login:
Login = admin
Password = password (default - if this doesn't work, then you will need to find it or initialize the router)
Go to the WEP security Screen
NetGear EXAMPLE:
Security Encryption (WEP)
Authentication Type *Automatic*
Encryption Strength *64bit* (64 bit is sufficient - the network overhead is less than 128 bit)
Security Encryption (WEP) Key (The active key below is marked with *)
Passphrase *Blank*
Key 1 abcdabcdab (64 bit examples = 10 hex digits 128 bit will be longer string)
Key 2 dcbadcbadc
Key 3 123456789a
Key 4 *Blank*
Click logout when finished
LinkSys Example:
Wireless Network Menu
Wireless Network Mode Mixed
Wireless Network Name (SSID) MyWireless
Wireless Channel 7 - 2.442 GHZ
Wireless SSID Broadcast Enable
Wireless Security
Security Mode WEP
Default Transmit Key 1 (This is the active key)
WEP Encryption 64 bits (or 128 bits)
Passphrase
Key 1 abcdabcdab
Key 2 dcbadcbadc
Key 3 123456789a
Key 4
There is no logout for the LinkSys. Just disconnect
Oct 27, 2008 | Computers & Internet
Connecting Ipod touch 8(GB) to Wi-fi
After fighting with this for the last couple of hours I have my ipod touch working with the netgear DG834G(v3) router. The fix is a bit odd and I am not entirely sure why it works but I thought I would share and hopefully it might help you out …
First I think that the WEP encryption simply does not work between these two devices and causes some very strange behaviour – the WEP 'authentication type' setting I had on the 'wireless settings' page was set to 'shared key' – I flicked this to 'automatic' & strength to ‘128 bit’ - hit apply and finally I found I was able to connect without an error message (after inputting the correct WEP key). Unfortunately the DHCP did not work correctly after this and I kept receiving IP addresses in the range of 169.254.x.x (an internal default) rather than my networks expected 192.168.0.x range. The Ipod touch couldn’t find any DNS servers or connect to the internet.
To get round this I set the router ‘security options’ to use WPA instead (WPA-PSK (Wi-Fi Protected Access Pre-Shared Key)) instead of WEP. Set the new WPA password at the bottom of the wireless settings page - again hit apply - and configured the ipod to use the new password and WPA PSK instead of WEP. This worked fine – although it does mean I have to change the settings on all my other wireless devices around the house!
The weird thing is that although the router isn’t using WEP encryption changing the 'authentication type' setting back to ‘shared key’ in the WEP menu breaks the WPA connection again – very odd? I blame netgear and their obviously crazy wep code :)
Nov 04, 2007 | NetGear DG834G Router
Zoom X6 (5590) DSL Modem (55900003) Logo
704 people viewed this question
Top Zoom Computers & Internet Experts
Prashant M
Prashant M
micky dee
Are you a Zoom Computer and Internet Expert? Answer questions, earn points and help others
