Question about RCA D52W19 52" Rear Projection Television
Tv will not come on immediately...
I have a RCA 53" projection television it takes pressing the power button about 5-7 times before the television will power up. this process takes about 5-10 minutes, with the green light coming on and going out three times before waiting about 30-45 seconds before pressing the power button again. this is rather frustrating, and i would like to know what parts i need to purchase to fix the problem.
Thanks Stressed
  • RCA Master
  • 5,138 Answers
3 capacitors cp150 2200uf 16v if it is puffrd up on top then it is bad ,other 2 caps cp114 cp120 220uf 35v they are green with gold wring on them located on Deflection board . Resolder all pinns on FBT on same board.
Posted on Dec 27, 2008
My TV won't turn on.
If this is a RCA Picture Tube Rear Projection, the Deflection Board will cause this problem. I do not know though if it is available.
Jul 18, 2009 | RCA D52W19 52" Rear Projection Television
Dead TV
hi there, this is a blown bulb. just replace the bad bulb and your TV will power up once more.
Mar 06, 2009 | Toshiba 53H71 53 in. Rear Projection...
Rca projection tv
Capacitor on Deflection board cp150 2200uf 16v if it is puffed up on top it is bad 2 more caps cp114 cp120 220uf 35v replace them if cp150 is bad.they are green with gold writing on them.
Dec 27, 2008 | RCA D52W19 52" Rear Projection Television
RCA D52W20 tv
3 capacitors On Deflection board cp150 2200uf 16v see if it is puffed up on top if so it is bad also replace 2 more caps in same circuit cp114 cp120 both are 220uf 35v they are green with gold writing.For Parts 1-800-223-3205. www.electronix.com
Problems powering up
These sets have alot of problems with poor solder connections resolder all pins on flyback transfomer, check 3 capacitors on power/deflection board cp(150) 2200uf 16v (cp120) 220uf 35v (cp114)220uf 35v they are green with gold writing.Also it is better to fix it Now because the longer you keep trying to play set it can cause more damage to it.
Dec 13, 2008 | RCA D52W19 52" Rear Projection Television
Service menu
How to Enter Service Mode
1. Turn on the main power switch to place this set in standby
mode. (LED will light in red.)
2. Press the buttons on the commander as follows, and enter
service mode.
PRESS these buttons in sequence
ON SCREEN DISPLAY---> (DIGIT 5) ---> (VOLUME +) --->STANDBY
Method of Cancellation from Service Mode
1. Set the standby mode (Press “ (TV STANDBY)” button
on the commander), then press “ (TV STANDBY)” button
again, hereupon it becomes TV mode.
Thanks
Oct 29, 2008 | Sony KP-53HS30 53" Rear Projection...
Sound, but no picture
Had the same thing today. Iwas playing with the auto demonstration of on screen displays. Press and hold the power button (5 seconds) on the TV. The auto display will play. Press the power button again (TV will go off). Turn power on again. you should now have the picture back
Nov 14, 2007 | Hitachi 53FDX01B 53" Rear Projection...
Tv cuts off and on.
Sounds like a bad SSB(small signal board) module. Better take it to a RCA AUTHORIZED service center.
Sep 06, 2007 | RCA D56W20 56" Rear Projection Television
RCA projection televeion problem.
take your tv to a tech for repairs the tv power supply or related circuit is defected.good luck
May 14, 2007 | RCA D61W20 61" Rear Projection Television
RCA D52W19 52" Rear Projection Television Logo
56 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
