Question about HHB CDR850 CD Recorder
HHB 850 needs repair
Any suggestions as to where I can get my HHB 850 repaired? Won't record any longer - reads "repair." Thanks in advance!
You can contact HHB service team on 020 8962 5000. Or visit their web site and go to support and complete an equipment repair form and they'l get back to you. You can also email the engineers whose names are listed in the contact section. Web site is http://www.hhb.co.uk/hhb/uk/support. Hope it helps
Posted on Feb 05, 2009
HHB CDR 850-No laser lit up...shouldn;t there be light ie. laser
YesI when the unit is first turned on the laser will emit a red light when scaning, if no beam is present it is time to replace your player, not cost effective to repair.
Mar 05, 2012 | HHB CDR850 CD Recorder
When recording disk reads repair
"REPAIR"
Because the disc was left in the unit after recording and the power plug was unplugged later, the track number and
recording time data have been cleared without being recorded on the disc.
While "REPAIR" is displayed, the track number and recording time data are repaired by tracking the recorded area. Further
recording or finalization is possible when the display returns to the previous condition. Tracking the recorded area takes about 40 minutes if the disc has been fully recorded.
Jan 29, 2011 | HHB CDR850 CD Recorder
DURNING FINALIZE MODE IT STOPPED WITH1:30 LEFT--- THEN I TURNED IT OFF AND TRIED AGAIN TO FINALIZE AND IT CAME UP WITH A READING OF---REPAIR--
That's a normal response to an interrupted Finalization.
http://www.retrevo.com/support/HHB-CDR830-CD-Players-manual/id/3875ci874/t/2/
The recorder was switched off/unplugged after recording without ejecting the disc. The recorder could not write essential recording information onto the disc.
While REPAIR is displayed, the recorder automatically examines the recorded area of the disc and updates the track numbers and recording time data. This process takes about 40 minutes for a fully recorded disc. Finalization or further recording is possible once the REPAIR message disappears.
Jan 23, 2011 | HHB BurnIt CDR830 CD Recorder
We ejected the cd accidentaly without finalizing from the HHB CDR850. we REALLY need this audio. what can we do?
sounds interesting
did the power fail during recording?
have you tried putting the cd back in the machine?
you should be able to finalise it as long as the PMA completed
the disc wont come out normally untill the PMA rec message finishes.
i have this machine myself.
there is a mode that will scan a disc if the PMA is missing
if power was turned off during recording it usually enters a "REPAIR" mode when turned on again.
this takes 40 mins to complete but the audio can be finalised as normal after it completes.
try putting the disc back in and see if it can be repaired or finalised
darren
Nov 14, 2010 | HHB CDR850 CD Recorder
Hi there, when recording analogue from mixer to HHB Burner 830 the blank cd does not read properly, and records blank even thou the connections are in the right ins and out (phono to phono) And the input...
I can only assume that it's not changing the analogue signal into a format suitable for transferring to a CD. Check the recording settings. Make certain the signal is being converted to say a WAV format or MP3 etc.
May 01, 2017 | HHB BurnIt CDR830 CD Recorder
Need owner's manual for HHB CDR-850 Where is reoaur cebter?
what is it you need? what is reoaur cebter? I have the machine and manual. My recorder died last night after 10 years. very disappointed!
Aug 07, 2010 | HHB CDR850 CD Recorder
MY HHB CR 850 NOT READING OR PLAYING JUST FLASHING CD?CDW?....
Machine is confused. The laser lens may have dust on it. open it up and gently clean laser with a Q-tip. My recorder died last night. I wanna' cry. it was very usefull to me with my music. Now I'm screwed after 10 years of owning it. Good Luck
Dec 10, 2009 | HHB CDR850 CD Recorder
Noise / Hum in recordings
hi, i once had the same problem with a kenwood cassette deck. it would play pre-recorded tapes perfectly but when it came to recording from another source i would get an annoying hum when playing back the recording, the fault turned out to be a faulty earth connection on the phono connectors on the rear, they were dry jointed and once resoldered the unit worked and the recordings were perfect. maybe you have the same problem? hope this helps?
Feb 14, 2009 | HHB CDR850 CD Recorder
HHB 850 CD Burner - lockup problem
I did find out how to do the manual eject, for a stuck cd. Open up the machine, looking at the front/top, on the lower left side of the cd transport there is a white plastic gear that can be turned with your finger, ejecting the cd.
Oct 30, 2007 | HHB CDR850 CD Recorder
About the HHB CDR 850 compact disc Recorder
You may need a new laser - it's a sony unit inside.
Aug 14, 2007 | HHB CDR850 CD Recorder
HHB CDR850 CD Recorder Logo
494 people viewed this question
Top HHB Audio Players & Recorders Experts
John
John
darren dillon
Level 1 Expert
Are you a HHB Audio Player and Recorder Expert? Answer questions, earn points and help others
