Question about Frigidaire GLEQ642A Electric Dryer
Lint sticks to the lint cover and lint filter.
I cleaned both the lint cover and the lint filter with diswashing soap. Now everything sticks to both of them and it is hard to remove. I have tried rinsing both of them numerous times to remove any soap residue. No improvement. I have a Frigidaire Gas Dryer Model FDG546RES1.
Any ideas?
Thanks for your Help
Craig
  • cwcj94 Dec 28, 2008
    Thanks blueextc3221!
    Goo Gone fixed the problem.
    Thanks Again!
  • 15,935 Answers
Use a degreased such as goo gone, or an aerosol electric parts cleaner/degreaser. It may look gone, but there is still scum built up in those tiny little holes.
Posted on Dec 26, 2008
Maytag drier lint screen will not go in all the way
Take lint screen out, look into slot and remove the sock that's blocking it....
Oct 12, 2014 | Maytag MED8000AW Maxima XL HE Steam Dryer...
Lint screen won't go down all teh way.
take the metal duct out that the lint filter slides down into,stick the metal strip through the hole in the side of the duct so that when it's in the bottom part of strip is flush up against the back side wall of duct and it should have like a half inch or so sticking out of the hole,but before you stick it in clean out the duct and with a thin long screw driver open the plastic cover that the filter slides through and poke out any lint in the slots that the filter slides in.so unplug the dryer,remove the bottom panel of dryer,remove the lint filter and screws that hold the lint filter duct in place they are 1/4 inch head screws,clean out the duct and the side slots up above the duct in the plastic area then slide the metal strip into the hole so that the bottom part that you first put into the hole fits flush up against the back inside wall of duct and the top of strip will be flush to the outside wall of duct and like around 1/2 inch or so still showing.hope this helps
Jun 02, 2013 | Kenmore Elite He5T Dryer Heating Element...
My frigidaire dryer start and a few seconds later an alarm sounds and E68 appears.
Remove your lint filter. Now remove the waffled plastic that covers the lint filter slot. Hint, its inside the dryer, and there's two screws holding it in. Be careful when you pull it out, because there's two wires connected to the metal strip on the bottom edge of it. That metal strip is either the temperature or moisture sensor, I bet. Don't drop the screws into the lint filter slot. If yours is like mine, you'll find that a lot of lint has built up around the contacts for those two wires. Carefully clean all the lint (use soft toothbrush), and reinstall. While you have it opened up, stick your vacuum's crevice tool down inside the lint filter slot and clean up all the lint in there as best you can. Problem solved. I think the build up of lint was shorting the two contacts, and this was screwing up the electronics.
Sep 12, 2010 | Frigidaire AEQ6000ES Electric Dryer
My Maytag washing machine leaves residue (lint? soap?) on clothes
us liqwid soap us les chang filter.to meny close can trap the dry stuf.
Jan 25, 2010 | Maytag PAV2300 Top Load Washer
We have a Whirlpool top loading washing machine that leaves the clothes covered with lint after each load. Delicate clothes that have elastic bands are covered with pieces of lint on the bands that are...
Your service man is right, the lint is filtered through the filter plugs on the bottom of the tub, and backflushed out during the spin cycle. This does not do a great job of filtering out the lint that came out of the clothes. So why is there so much lint? Three reasons: 1. Clothes being beaten against the agitator, tub, each other. The Whirlpool washer has a pretty decent way of agitating the clothes without too much damage, as long as there is plenty of water for the clothes to move through. As long as you make sure your load size and water level are correct, this shouldn't cause a lot of lint. I always have a larger water level than the load size calls for. 2. Lower quality material in the clothes. We definitely see this a lot, especially in the cheaper towels, rugs, sweaters, ect. Some of these have such cheaply made fibers, that they put out a lot of lint. 3. Laundry soaps. Most soaps are very caustic detergents and eat the fibers right out of the linens. There are some brands of washers that still use a type of metal in them that this soap eats right up, so in a few years the machine is junk. All of the washer manufacturers went to plastic outer tubs, as the soap was literally eating holes in the outer tubs in 2 to 3 years on some brands. This is one of the reasons we have so much of the micro lint that is so fine, it goes right through your dryer lint filter and causes lint build up in the venting itself. Years ago, at our shop in Hawaii, we tested naturopathic soaps for 12 years before we settled on the Melaleuca brand for our laundry soaps. Ph neutral, cleans the clothes better than any brand we have tested before or since, does not leave the sludge in the outer tub that most brands do, does not leave a hard aggregate in the tubs like some other brands do, is cheap and does not cause the allergys, athsma, skin rashes, ect. that most of the caustic brands are doing. We have used it for over 10 years now and see very little lint in our Whirlpool washer. Look it up online, join it, and buy the soap directly from the company. It sounds like you have done everything else correctly to the washer, that you could have. I am impressed, most people could not have done what you did. Hope this helps. Good Luck, Appliance Specialists
Jan 22, 2010 | Washing Machines
Dryer will not heat. lint filter is clean. dryer runs fine bosch dryer nexxt 500.
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Nov 08, 2009 | Bosch Nexxt 500 Dryer
Lint on dark clothes
no product i know of , try running machine without cloths with hot water and a lot of extra soap the unrestricted water movement and extra soap lubricates and helps to flush machine out, let machine dishcharge into bucket and if poor flow or lots of debris run again and see if this clears up you issue
Jul 07, 2009 | Washing Machines
LINT LEFT OVER CLOTHES
It has a self cleaning lint filter. Front loaders call for "Special" HE detergent .....and I would only use about a table spoon..You may be Cloging the special self cleaning lint filter ,with extra soap .Top loaders use a lot of water compared to front loaders. Let me know ,If I could help Again! Thanks
Dec 14, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Bosch axxis WTL lint indicator problem.
I have been struggling with this lint filter problem big-time. After reading the previous user's comment that his mesh holes had become clogged, I took a closer look at my filter and noticed that the tiny holes in the mesh were, indeed, clogged up. In fact, when I initially ran water on the filter it pooled up on the mesh like a solid plate...pretty good sign that air wasn't able to pass through the filter properly.
I used a soft toothbrush and soap to clean the filter, and when I ran water to rinse it off it the water passed right through the mesh. I popped it back in and, voila...That fixed it!!
Mar 08, 2008 | Bosch Axxis WTA 3510 Electric Dryer
Lint filter going off after 5 minutes then shutdown
Hello folks try this if you have not gotten this resolved. Your dryers have 2 sensor systems, the first one test the clothes for moisture, the second for the heat. The 1 sensor system drops resistance when the wet clothes are put in the dryer. the shutting down after 5 minutes and lint filter light coming on could be that the dryer isn't sensing the moisture. Now for the fun part, the entire inside of the drum and paddles is the moisture sensor. Try cleaning the inside of the drum with a cleaner to remove any detergent or fabric softner residue. This is crucial if you are using fabric softner sheets as they coat the drum. Also wash the lint filter with soap and water so the water goes straight thru instead of puddling up. Remember to also clean the condenser as this can trigger this issue as well. Hope this helps
Jan 02, 2008 | Bosch Axxis WTL 5410 Electric Dryer
Frigidaire GLEQ642A Electric Dryer Logo
111 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
