Question about Olympus WS-100 Digital Voice Recorder
Files on the computer in high speed, while normal on the Recorder
I transfered my files from the recorder. They all play normally on the device, but the files on the computer are fast speed, impossible to slow down and have a normal debit on a PC. Other strange thing is that the number of audio files is not the same between what is shown on the Recorder and in Explorer on the PC. Any idea?
  • 91 Answers
You can format the device, maybe if you delete files on the device from the computer , you cause inconsistence between them, i suggest to erase files using the buttons on the device. about the high speed check the codecs in your computer,
I can’t play a file that Windows Media Player supports. What should I do?Most likely, a required codec isn't installed on your computer. Typically, Windows Media Player automatically downloads any required codecs from the Internet and installs them. However, this may not happen for the following reasons:
• The necessary codec (typically, a non-Microsoft codec) isn't available on the codec server.
• You have an older version of the Player and your automatic codec-download option isn't enabled.
• The Internet security settings for your browser are set too high.
• You're not connected to the Internet.
If you have an older version of the Player (prior to Windows Media Player 9 Series), you can check your codec download setting by doing the following:
1.
In Windows Media Player, on the Tools menu, click Options, and then click the Player tab.
2.
In the Auto upgrade area, make sure Enable automatic codec download is checked, and specify how often you want the Player to check for updates.
You can change your Internet security settings (if you are logged on as an administrator or a member of the Administrators group) by doing the following:
1.
In Control Panel, open Internet Options.
2.
Click the Security tab, and then click Internet.
3.
In the Security level for this zone area, click Default Level.
If you can’t play the file after completing this procedure, restart your computer, and then try to play the file again.
If you still can’t play the file, try to play another file with the same file name extension. If you can play this file, then there is a problem with the file that you want to play. For more troubleshooting information, see the Windows Media Player Multimedia File Formats Web
Posted on Mar 03, 2008
I do not have an installation CD. I would like to download the audio files to my PC. How can I do so? Pam Sheppard
Normally, if you have a cable with USB connection for you device, the computer will automatically discover the device after it is plugged into the computer - plug and play. Allow Windows to load the driver and wait for it to tell you it is ready for use. Then check "My Computer" and look for the recorder icon. If the icon is visible, double click it and open the audio files you want to transfer to the computer. It's just a matter of cut and paste or copy and paste to your desired location in your computer.
Dec 09, 2010 | Olympus VN-4100PC Digital Voice Recorder
My computer does not recognize ny recorder as an external device
Install a VN recorder on VISTA
1. Make sure the device has been uninstalled in device manager
2. Make sure the old version of digital wave player is uninstalled.
{Delete Temp files in Internet Explorer --Tools--Internet Options --Delete Files-- Delete offline content--OK}
3. Install digital wave player (The newest Version).
http://www.olympusamerica.com/files/DigitalWavePlayer.zip
4. Install the 2.1.4 vista update
http://olympusamerica.com/cpg_section/software_results.asp?id=1291&os=w
5. Restart the computer.
6. Plug in the VN recorder to the USB port and turn the recorder on.
"Found new hardware" will appear,
7. install automatically.
This may fail, if you see VNUSB device, skip the final steps and proceed to Digital Wave Player to Download files from the Digital Voice Recorder.
If you will see "Other devices" listed in Device manager with "digital voice recorder" underneath it.
8. Right click on the "digital voice recorder"
9. Select update driver from the pop up menu.
10. Choose the browse computer Option
11. In the next window browse to the location that you downloaded the Digital Wave Player application to
12. Click Next
A security warning window will open,
13. Choose "install anyway" and the device will install.
When successfully installed you will see the "other devices" disappear and a VNUSB device with a "VN series device"
underneath it appear at the bottom of the device manager list. There will be a blue question mark next to the device. At this point you can close the device manager and the properties window and open Digital Wave Player. You will see the recorder listed underneath the recorder folder and be able to download and use the program normally now.
Jul 03, 2009 | Olympus VN-4100PC Digital Voice Recorder
Digital voice recorder connection problem
There are many steps in installing Digital Wave Player on VISTA, it is important to follow every step since installing Digital Wave Player on VISTA is dependent on this process.
12. Click Next
Jun 02, 2009 | Olympus VN-2100PC Digital Voice Recorder
I cant transfer files from recorder to my pc
12. Click Next
Mar 12, 2009 | Olympus VN-4100PC Digital Voice Recorder
Cant open or view folders on computer
12. Click Next
Mar 01, 2009 | Olympus VN-120 Digital Voice Recorder
File transfer VN-480PC doesn't work on notebook (Vista)
12. Click Next
Feb 19, 2009 | Olympus VN-480 PC Digital Voice Recorder
I want to transfer all files on DVD recorder to PC
There is no function on the EH65 to back up your files to your computer or an external drive.
The only thing you can do is transfer your cherished files to DVD-R then put them on your computer. Any other way, like playing the file and re-recording on your computer will result in poor reproduction.
Dec 17, 2008 | Panasonic DMR-E55 DVD Recorder
How do I transfer files to computer from Olympus VN-3100PC?
11. Browse to the location on your computer where you downloaded and saved the Digital Wave Player files from Step 3
12. Click Next
Nov 29, 2008 | Olympus VN-3100PC Digital Voice Recorder
Plzz
Formatting the Recorder (FORMAT)
If you format the recorder, all function settings will return to their defaults.
All files stored in the recorder will be deleted.
If you have important files that you want to save, connect the recorder to a computer and
transfer those files from the recorder to the computer before formatting the device.
1 Press the MENU button.
2 Press the FF or REW button to choose “FORMAT”.
3 When the PLAY button is pressed, “nO” is displayed.
4 Press FF or REW to select “yES”, and press the
PLAY button.
After “ARE yOU SURE” is displayed, “nO” will be displayed.
5 Press FF or REW to select “yES”, and press the
PLAY button.
“DONE” displays when formatting ends.
s It may take up to several tens of seconds to finish the initialization. Do not remove the battery or detach
the battery compartment from the recorder during that time. Otherwise data may be damaged.
s Never format the recorder from a PC.
s When the recorder is formatted, all the stored data, including locked files, are erased.
Nov 08, 2008 | Olympus WS-100 Digital Voice Recorder
Olympus WS-100 Digital Voice Recorder Logo
80 people viewed this question
Top Olympus Audio Players & Recorders Experts
pankaj rautela
pankaj rautela
leoz
Level 1 Expert
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
