Question about Hitachi 50SBX70B 50" Rear Projection Television
Red line & blue line don't match making picture blurry
Turned on t.v and picture was blurry. called a friend for some advice told me to check if red line and blue line were matched but they were not. Tried to adjust it but when it was almost lined up it would go back to the way it was and kept a blurry picture. T.V is Hitachi has a #43fdx01b
5 Suggested Answers
Ecollier2012
  • 3459 Answers
SOURCE: hitachi projection tv
Solution:
Your TV has a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed in but stationary.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence or magic focus section
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
You can get a repair kit that includes all the parts from www.TvRepairKits.com.
They have put together a kit for the Hitachi TV sets.
The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc.
Everything you need to fix it yourself. Its a fairly easy fix on the Hitachi sets.
Posted on Jan 29, 2009
ladywinn
  • 5138 Answers
SOURCE: Looks like the picture is in 3D...magic focus won't adjust green
Replace Both of your STK ICs they are Big Black ICs Also CK and replace these resistors RK42 3.3 /RK46 1.8 /RK50 2.7/ RK54 1.5 RK54 1.5/ RK58 3.9 /RK62 2.2
Posted on Feb 16, 2009
Ecollier2012
  • 3459 Answers
SOURCE: Convergence lines are SLANTED. Red line is above
Your TV most likely a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Using your original remote go-to the tv settings then goto the convergence section.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Posted on Jun 20, 2009
  • 8457 Answers
SOURCE: blurry picture the red, green line dont match
Ur convergence is dead.Must know how to solders?Must replaced 2 STK convergence ICS,and some or all it resistors.Tries Websites Tv repair World.com,Tvrepairkits.com to repair it ur self.The shop will cost u $300 for parts and labors.
Posted on Mar 19, 2010
Toshiba 150r6f color blue is missing
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
The transistor that your friend told you, can be located at the CRT base card [Video Output] itself.
Mar 01, 2014 | Televison & Video
LEFT SIDE OF PICTURE IS BLURRY AND COLORS DISTORTED
Does that set have whats called a color wheel, if so that maybe you problem, and replacement is how you fix it.
Apr 30, 2010 | Toshiba TP43H95 43" Rear Projection...
Toshiba 50H13 blurry picture with white line on right side
replace all the surface mounted electrolytic capacitors on the hyper module. also called the scan converter module. this is a common trouble. what a nasty job. good luck.
Jun 23, 2009 | Toshiba 50H13 50" Rear Projection...
Green screen with red and blue wavy lines
This is "NOT" meant as "expert" advice...as this is not my area...HOWEVER...I see no one has answered this yet...AND I got some good help from here a year or so ago that worked for me!
When I had a similar "green screen" problem with my SONY projection tv...the guy helped me by having me make "MINOR" adjustments to the red/blue/green etc knobs behind the panel. These were three small black plastic pieces and needed less than a 1/16 of an inch adjustment...try adjusting one at a time and giving it few seconds after each adjustment. It worked for me..at least for a while (till my wife gave it away to a friend because it was "too big"...ah! women!!! LOL)...hope this helps. (NON-expert help!)
Jan 11, 2009 | Televison & Video
Blurry, Multi-Color, Multi-Line
covergence problems and its not adjustable you need work done on the convergence board or a new board and realignment which can be timely.
Nov 01, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
I have a red and blue shadow in my picture
i think you need a new convergence board they rin from about 88.00 to about 140.00
Sep 08, 2008 | Akai PT5598HD 55" Rear Projection...
RCA 52937SG Blurry picture
on my rca there is a setting in menu called converage or something along that line looks like this #with blue red n white they all need to line up on the number sign this might help + there are other solutions
Dec 12, 2007 | RCA P52937 52" Rear Projection Television
Screen is curved inward on all 4 sides and there is a red, and a blue line that is curved at the top of the screen
This is a convergence problem.. possible deflection problem... you might need a tech to look at it...
Nov 19, 2007 | RCA HD56W66 56" HDTV
Screen
What you may have needed to do was adjust the green & blue crt screens to match the red. Go into your picture menu adjust, turn color all the way down to a black & white px. Now adjust each crt screen so that you end up with a true black & white px. Then adjust each focus control to get a sharp px, have your tv on a channel like the home shopping network so you can adjust each crt focus one at a time for clarity by cover the other 2 up. Then go back into picure adjust & turn color ahlf way up, you should see a better px.
Jul 01, 2007 | Philips 60P8341 60" Rear Projection...
KP-53s65 multipule problems, hoping for single solution?
sounds like 2 different problems here. first problem sounds tuner related. second sounds convergence related. third issue (cost effective to repair ?) at this point i would replace the set. i hope this helps
Mar 12, 2007 | Sony KP-53S65 53" Rear Projection...
Televison & Video Logo
24 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
