Question about Dell Vostro 1400 Intel Core 2 Duo T5270 80GB/1000MB PC Notebook
Blue Screen on Dell Vostro 1400
I have a blue screen appear almost a minute after I start the computer. It says "The system has failed". The keyboard and mouse also are unusable the entire time. Adding insult to injury, the 1 year warranty expired a few days ago so Im not able to just send it in. Im hoping to find a fairly inexpensive solution to this and am wondering if anyone else has had this problem.
  • 37 Answers
OK you can try a couple of things.
1. On booting the Laptop, hold down F8 key, then choose "Last known Good Configuration". Windows may now start correctly.
2. If this doesn't work, do the same, but choose "Boot into Safe Mode"
If neither works you may have to repair Windows...
Posted on Jan 05, 2009
My dell vostro 1015 has blue vertical line on screen can you please give me suggestion for repair it
Order replacement screen - the casing around the screen either 4 or 6 screws - Screen held in by 4 other screws - connector runs under keyboard (it's a flat ribbon type) - remove keyboard to access the connection. Assemble is reverse. (There is a You Tube video as well).
Sep 13, 2013 | Dell Vostro 1015 Laptop
No LCD Display on Dell Vostro 1700 - 17"
It sounds like you have been pretty thorough trying to resolve the lcd problem
A blacked-out screen doesn't necessarily indicate a broken monitor.
If the computer has run out of charge or is in hibernation or sleep mode,
if the screen is too dark, or if the display cable has come disconnected from the motherboard, the screen may appear black or fail to turn on. To fix a blacked-out laptop screen, troubleshoot the screen settings, check the LCD connector and see if the computer is awake and receiving power.
Touch the touchpad or move the external mouse to see if the computer is asleep or hibernating. If the computer fails to respond, press "Enter" on the keyboard. Press the power button if the screen remains black.
Confirm that the power indicator light, found at the front of the computer or above the keyboard, is glowing solid green or blue. Confirm that the power adapter is plugged into the computer and into a wall outlet. Confirm that battery indicator light is glowing solid green or blue. Hold down the "Fn" key. Press the up-arrow to see if the screen brightness increases.
Some computers also use the "F6" or "F7" keys to increase screen brightness.
Hold down the power button for 10 seconds to turn off the laptop.
Remove the AC adapter from the computer, close the screen, and then turn the PC over.
Slide the battery latch to eject the battery. Pull the battery out of its compartment. Turn the computer back over, open the lid, and insert the edge of a flathead screwdriver or other flat, solid object beneath the bezel above the keyboard. Wedge the edge of the keyboard bezel off of the top cover.
Work your way along the edge of the keyboard bezel to loosen it.
Pull the bezel off the laptop.
Trace the cable coming from the laptop screen to the connector found beneath the bezel. Reconnect the display cable to the motherboard if the cable has come loose from the connector. Line up the tabs on the bezel with the slots along the top of the keyboard. Insert the right edge of the bezel into the gap above the keyboard, and then push the bezel back in place. Turn the computer back on. If the laptop screen is still blacked out, connect an external monitor to the video port on the side of the PC to confirm that the video card isn't defective. If the external monitor works, the LCD screen could be broken. If the monitor doesn't work, the motherboard or video card might need to be replaced. Hope this helps
Dec 13, 2012 | Dell Vostro 1700 Notebook
The screen on my dell vostro 1400 is bright blue with a black stripe down the right center
Sorry Mccurdy19 sounds like the monitor is going out. Try updating your drivers for your video card and monitor.
Jul 13, 2011 | Dell Computers & Internet
Blue screen appear while formating..
Could you not format your computer? Usually, when formatting with XP blue screen appears for a few minutes and then it continues formatting. But if it is not your problem, try formatting your system again with another OS.
Dec 22, 2010 | Dell OptiPlex 330 Desktop Desktop Computer...
When i turn on my laptopi get a blue screen with no start up menu
press ctrl+alt+del to initiate the task manager ..choose new task ..and after that run browse..and inthe windows look for windows explorer...
this will allow you to back up any files from the C drive partition ..and than proceed to reinstall the operation system
Your system was corrupted by a virus or other malfunction and even if we find a way to use it ...(like that one mentioned) there will be never again in the whole functions..So..back-up and reinstall...
May 02, 2010 | Dell Vostro 1400 Intel Core 2 Duo T5270...
My Vostro 1500 will not turn on please!
Reset/replace the Ram/memory. Sometimes faulty and failing ram can keep a computer from booting up. If you have 2 sticks, take one out and then try to boot, then try with just the other stick. The flashing caps lock icon means a general failure, though it is most commonly associated with the motherboard.
Jun 25, 2009 | Dell Vostro 1500 Notebook
Problems with the Dell Vostro 1400 (Vista)
Hello Freebro,
First we need to diagnose:
- Try to change Memory sometimes they can cause blue screen.
- Try to change Hard Disk also can cause blue screen.
- Try to reformat and reinstall the O.S
Sep 20, 2008 | Microsoft Windows Vista Ultimate Edition
Logitech Cordless Keyboard
This could be either hardware or software related. If you could tell us what the exact blue screen is I can be more specific in my answer. The possible causes for this could be virus/malware, corrupted registry(which could be due to failing harddrive), faulty memory, or faulty motherboard.
BTW, the "reload" they did will not fix much, which is why you had the same problem within days.
May 10, 2008 | Computers & Internet
Dell Vostro 1400 Intel Core 2 Duo T5270 80GB/1000MB PC Notebook Logo
566 people viewed this question
Alun Cox
