Question about Sharp 25L-M100 25" TV
Lines on tv
Recently brought a 37" tv it has horizontal lines intermitant. its connected exactly the same as my old tv and that was a perfect picture any ideas anyone ime beggining to think i should of kept my old tv i spent all that money for something thats not as good as my 8 year old tv
  • 790 Answers
Hi
this not horizontal this is vertical line. this means defective vertical output IC and 1.5ohms resistor, Replace the two parts then test run, and happy viewing!
Thanks!
Posted on Dec 27, 2008
When tv is turned on you get poicture and sound but there are broken horizontal lines from top to bottom of screen. this occurs on all hdmi inputsincluding roku and dvd player.
How to fix lcd lines on Sharp tv screen, hdmi video board ...
? 3:43
https://www.youtube.com/watch?v=cHki4D0EwOo
May 24, 2014 - Uploaded by Tampatec
How to fix LCD lines on Sharp TV screen, hdmi video board easy ... Make Money From Your Broken Cracked LCD LED PLASMATV ... TV Repair Help for Vertical & Horizontal Lines on Your TV Screen ... Sharp Aquos LC-32 37 46 52DH65E 66E 77E - NoPic/Sound with ... Get video URL at current time.
comments on LCD Display Symptoms and causes. - YouTube
https://www.youtube.com/all_comments?v=DedJvyNm_s4
We have frequent outages causing the TV to turn on from standby mode when power returns. (These ..... Sharp LC-70LE650U 70-Inch Aquos TV TURNS ON WITH PERFECT PICTURE AND ..... It has thin horizontal lines on the top quarter of thescreen. ..... hey there, bought a 52lg60-ua had no image/picture but had sound.
? 2:01
https://www.youtube.com/watch?v=DedJvyNm_s4
Jan 28, 2016 | Sharp aquos 52 in lcd 1080p aquos 52...
Horizontal Green Lines On Screen. No Picture Visible. Problem is intermitent.
Are you certain of the connection? Sometimes the connector becomes loose or otherwise loses integrity. Maybe it's the cable (HDMI, right?)--or both the TV's connector and that. They may become worn.
Be careful with your LCD screen--they are more delicate than most people realize.....
Dec 16, 2013 | Toshiba Regza 52XV645U LCD TV
I have a Sony Trinitron 32 color tv KV 2168MTJ (quite old - 10 yrs old), and the standby light blinks exactly 200 times (just over 3 mins) before it turns on. Once it is on, it works perfectly. What's...
A poor solder connection on B+ is the line, Horizontal drive transformer or at the base of Horizontal Output transistor can caused that. Re-soldering these section can fix it..
Oct 23, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Vizio L32 LCD tv with video problems
Not exactly an Ideal fix , but running a fan into the back of your tv seemingly corrects this ... cooling failure ?
Jan 23, 2010 | Vizio VW32L 32 in. LCD HDTV
Toshiba 36A50 sound, light line horizonally on black screen
It is my guess that you have some intermitent solder connections in the Vertical output circuit.
Hope this helps,
Skyassoc
Jun 23, 2009 | Toshiba 36A40 36" TV
Horizontal lines across the top 3 inches of picture
Hi
what line started? from Left to right? or from top to bottom?
Thanks!
Nov 28, 2008 | Philips 32PT6441/37 32" TV
Horizontal white lines across top of TV screen
Vertical hold circuit is failing.
Check capicitor in vertical hold circuit. You should have solid knowledge of electronics repair before attemping repair. TV's can emmit harmful radiation, and produce voltages up to or in excess of 30kV.
Oct 07, 2008 | Televison & Video
Horizontal problems
Its may due to problem on IFsection or tuner,afc problem
Jan 12, 2008 | RCA D52W19 52" Rear Projection Television
Philips TV showing horizontal lines model 27pt6441/37
You likely have an elevtrlytic capacitor bad on the B+ line to the vertical ouput ic. If you continue to use the set like this it is likely the vertical ouput ic will fail.
Jun 26, 2007 | Philips 27PT6441 27" TV
Horizontal lines slowly moving down
Sounds like you have a power supply filtering problem. Perhaps a filter capacitor is going bad. If your set has a switching power supply oscillations from it are getting into the video. You need to have a tech to check it out for you. You should get an estimate first before having it repaired. Stargazer
Mar 12, 2007 | Philips 32PT5441/37 32" TV
Sharp 25L-M100 25" TV Logo
90 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
